Forgot everything. Just can’t see where i went wrong. Trying to set up openhab only with epson binding active.
Did everything like in the tutorial but get the following in debug when switching item in sitemap
[ERROR] [.o.b.e.i.EpsonProjectorBinding:366 ] - Could not find device 'hometheater'
[INFO ] [runtime.busevents :22 ] - epsonHorizontalReverse received command OFF
[INFO ] [runtime.busevents :22 ] - epsonMute received command ON
/opt/openhab/configuration/openhab.cfg
# Port of the Epson projector to control (optional, defaults to 60128)
epsonprojector:hometheater.port=/dev/ttyUSB0
/opt/openhab/configuration/items.demo
Switch epsonPower { epsonprojector="hometheater:Power:60000" }
String epsonSource "Source [%s]" { epsonprojector="hometheater:Source:ON,60000" }
Number epsonDirectSource "Direct Source" { epsonprojector="hometheater:DirectSource:ON,60000"}
Switch epsonMute { epsonprojector="hometheater:Mute:ON,60000" }
Switch epsonHorizontalReverse { epsonprojector="hometheater:HorizontalReverse:ON,60000" }
Switch epsonVerticalReverse { epsonprojector="hometheater:VerticalReverse:ON,60000" }
String epsonAspectRatio "AspectRatio [%s]" { epsonprojector="hometheater:AspectRatio:ON,60000" }
String epsonColorMode "ColorMode [%s]" { epsonprojector="hometheater:ColorMode:ON,60000" }
Number epsonColorTemperature "Color Temperature [%d]" <colorwheel> { epsonprojector="<hometheater:ColorTemperature:ON,60000" }
Number epsonLampTime "Lamp Time [%d h]" <switch> { epsonprojector="<hometheater:LampTime:60000" }
Number epsonErrCode "ErrCode [%d]" <"siren-on"> { epsonprojector="<hometheater:ErrCode:ON,60000" }
String epsonErrMessage "ErrMessage [%s]" <"siren-off"> { epsonprojector="<hometheater:ErrMessage:ON,60000" }
demo.sitemap
sitemap demo label="Demo House"
Frame label="Controls" {
Switch item=epsonPower label="Power"
Text item=epsonSource
Selection item=epsonDirectSource label="DirectSource" mappings=[20="COMPONENT", 32="PC", 48=HDMI1, 160=HDMI2, 65=VIDEO, 66=SVIDEO]
Switch item=epsonMute label="Mute"
Frame label="Flip Projection" {
Switch item=epsonHorizontalReverse label="Horizontal Reverse"
Switch item=epsonVerticalReverse label="Vertical Reverse"
Frame label="Info" {
Text item=epsonAspectRatio
Text item=epsonColorMode
Text item=epsonColorTemperature
Text item=epsonLampTime
Text item=epsonErrCode
Text item=epsonErrMessage
