Has anyone else run in to this issue where OpenHAB (I’m on 1.8.3) seems to stop seeing the Insteon FastOnOff command? Upon startup, it seems to work fine, often for a few days. Then all of the sudden it no longer sees when I use the FastOnOff. The PLM/Hub registers is just fine as it responds accordingly, but OpenHAB just doesn’t see it happening. To correct it, all I have to do is reload the items file and everything starts magically working again. I haven’t seen any real errors that would indicate something is going wrong.
Any thoughts or suggestions for how to troubleshoot? Thanks!
PS - As a temporary workaround, does anyone know of a way to automatically reload just the items file (say in a rule)? I know the system checks every x seconds for updates to the file and loads it automatically but I’m wondering if there’s a way to force a refresh/reload of the items file without making any changes.
