Before the update everything works perfectly , I logged in through myopenhab.org and use the basic Ui works also when I use the app on my iPhone is work , just after the update I had these problems . But just trying to troubleshoot make sure nothing changed . But I seriously don’t know what is going on
The remote URL I am using is Http://myopenhab.org , for my local URL I’m using my PI address which I have setup everything up with. My SSL certificates is currently on the off position and yes I have tried clear cache also . But like I’ve said even when I have sign in to my openHAB.org and go to basic Ui it still doesn’t work . So ai don’t know if I also have to update something within openHAB
Please try https://myopenhab.org/ instead and double check your credentials.
Give it a try and change the Ignore SSL certificates to ON.
What does the status say when you´re logged in to myopenhab.org?
Also check if your UUID and secret are still correct, here´s a info where to find them.
Do you have any errors in your openHAB log when trying to access your sitemap via myopenhab.org?
Are you able to see the dashboard when accessing https://home.myopenhab.org/start/index?
Are you able to open anything from this dashboard?
Let´s try to solve this issue first because it seems like there´s something wrong/broken between your locale oH and the oH Cloud that effect the connection via app.
No manybe you don’t understand , I can acces basic Ui but when trying to use a item through basic UI it still doesn’t work . So, using the app remotely it doesn’t work and logging in basic UI still doesn’t work .
Old thread but just run into the same problem described above. After upgrading to OpenHab3, the iOS showed BasicUI a few times then no longer, just a blank screen after the connection message at the bottom goes away (indicating a successful login). Removed and reinstalled the app several times but no dice.
A couple of interesting clues, which make me think it’s some issue with iOS and/or the app itself.
Tried with a different iPhone and it works flawlessly.
The same blank screen appears in Demo mode.
No difference whether local or remote.
BasicUI works perfectly from browser, both local and remote.
