I’m try to install OpenHAB 2.0 on my raspberry pi 3.
Install the to my openhabian-ua-netinst-20161216-git52cc420 with WIN32disk .
Enter the MicroSD to raspberry
Wait 55 Min.
Try to enter to the IP:8080 get Page cannot be Display.
Enter to SSH, LS command get file name “openHABian-install-failed”
looks like you did the right steps to set up a fresh openHABian.
As you already said, the anstallation failed. Could you please check the following file for relevant errors or where it it stopped?
/var/log/raspbian-ua-netinst.log
Please post the relevant parts of it so we can see what exactly failed. Please avoid posting an IP or any security-relevant information.
Unfortunately, I don’t have a openHABian rpi here to check my file.
2016-10-31 22:12:07.351 [SCHWERWIEGEND] [org.apache.karaf.main.Main] - Could not launch framework
java.lang.RuntimeException: Error initializing storage.
at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:77)
at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:31)
at org.eclipse.osgi.launch.EquinoxFactory.newFramework(EquinoxFactory.java:24)
at org.apache.karaf.main.Main.launch(Main.java:250)
at org.apache.karaf.main.Main.main(Main.java:175)
Caused by: java.io.IOException: Unable to create lock manager.
at org.eclipse.osgi.storagemanager.StorageManager.open(StorageManager.java:698)
at org.eclipse.osgi.storage.Storage.getChildStorageManager(Storage.java:1749)
at org.eclipse.osgi.storage.Storage.getInfoInputStream(Storage.java:1766)
at org.eclipse.osgi.storage.Storage.<init>(Storage.java:126)
at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:85)
at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:75)
