I just updated OpenHAB with the configuration tool. Now the web interface is gone (both paper and habmin).
Is this my machine or is it broken?
thanks
Log is:
2017-05-01 12:41:37.878 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2017-05-01 12:41:37.892 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2017-05-01 12:41:37.903 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
2017-05-01 12:44:25.478 [ERROR] [org.openhab.core ] - FrameworkEvent ERROR - org.openhab.core
org.osgi.framework.BundleException: Unable to acquire the st ate change lock for the module: osgi.identity; osgi.identity="org.openhab.core"; type="osgi.bundle"; version:Version="2.1.0.201704302130" [id=167] STOPPED [STARTED]
at org.eclipse.osgi.container.Module.lockSt ateChange(Module.java:329)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.stop(Module.java:480)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decStartLevel(ModuleContainer.java:1623)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1542)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.SystemModule.stopWorker(SystemModule.java:248)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.stopWorker(EquinoxBundle.java:144)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.doStop(Module.java:626)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.stop(Module.java:488)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:186)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:159)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
EOF
Hit ‘’ for a list of available commands
and ‘[cmd] --help’ for help on a specific command.
Hit ‘’ or type ‘system:shutdown’ or ‘logout’ to shutdown openHAB.
openhab> log:display
22:59:54.336 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
22:59:57.450 [WARN ] [url.mvn.internal.AetherBasedResolver] - Error resolving artifact org.openhab.core:org.openhab.io.rest.docs:jar:2.1.0-SNAPSHOT: [Could not transfer artifact org.openhab.core:org.openhab.io.rest.docs:jar:2.1.0-SNAPSHOT from/to openhab (https://openhab.jfrog.io/openhab/online-repo-snapshot/2.1/): openhab.jfrog.io]
java.io.IOException: Error resolving artifact org.openhab.core:org.openhab.io.rest.docs:jar:2.1.0-SNAPSHOT: [Could not transfer artifact org.openhab.core:org.openhab.io.rest.docs:jar:2.1.0-SNAPSHOT from/to openhab (https://openhab.jfrog.io/openhab/online-repo-snapshot/2.1/): openhab.jfrog.io]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:720)[7:org.ops4j.pax.url.mvn:2.5.2]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:659)[7:org.ops4j.pax.url.mvn:2.5.2]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:600)[7:org.ops4j.pax.url.mvn:2.5.2]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:567)[7:org.ops4j.pax.url.mvn:2.5.2]
at org.apache.karaf.features.internal.download.impl.MavenDownloadTask.download(MavenDownloadTask.java:36)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:60)[8:org.apache.karaf.features.core:4.0.8]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_121]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_121]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_121]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_121]
Caused by: shaded.org.eclipse.aether.resolution.ArtifactResolutionException: Error resolving artifact org.openhab.core:org.openhab.io.rest.docs:jar:2.1.0-SNAPSHOT
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:444)
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:246)
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:223)
at shaded.org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveArtifact(DefaultRepositorySystem.java:294)
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:705)[7:org.ops4j.pax.url.mvn:2.5.2]
… 12 more
22:59:57.499 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-misc-restdocs, openhab-transformation-javascript, openhab-ui-habpanel, openhab-transformation-regex, openhab-transformation-jsonpath, openhab-transformation-xpath, openhab-ui-basic, openhab-transformation-map, openhab-ui-classic, openhab-ui-habmin, openhab-transformation-xslt, openhab-transformation-exec, openhab-ui-paper, openhab-transformation-scale’: Error
