openHAB 2.1 is out!
I believe with b5
check in the openHAB console:
bundle:list -s |grep -i smarthome
Perfect, thanks. Yes it was built with 0.9.0.b5.
openhab> bundle:list -s |grep -i smarthome
 94 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Config Core                          | org.eclipse.smarthome.config.core
 95 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Configuration Discovery              | org.eclipse.smarthome.config.discovery
 96 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Config Dispatcher                    | org.eclipse.smarthome.config.dispatch
 97 | Active   |  75 | 0.9.0.b5               | Eclipse SmartHome Config XML                           | org.eclipse.smarthome.config.xml
 98 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Core                                 | org.eclipse.smarthome.core
 99 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Core Audio                           | org.eclipse.smarthome.core.audio
100 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome AutoUpdate Binding                   | org.eclipse.smarthome.core.autoupdate
101 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Core Binding XML                     | org.eclipse.smarthome.core.binding.xml
102 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Core ID                              | org.eclipse.smarthome.core.id
103 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Core Persistence                     | org.eclipse.smarthome.core.persistence
104 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Scheduler Service                    | org.eclipse.smarthome.core.scheduler
105 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Core Thing                           | org.eclipse.smarthome.core.thing
106 | Active   |  75 | 0.9.0.b5               | Eclipse SmartHome Core Thing XML                       | org.eclipse.smarthome.core.thing.xml
107 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Transformation Service               | org.eclipse.smarthome.core.transform
108 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Core Voice                           | org.eclipse.smarthome.core.voice
109 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Console                              | org.eclipse.smarthome.io.console
110 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Console for OSGi runtime Karaf       | org.eclipse.smarthome.io.console.karaf
111 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome JavaSound I/O, Fragments: 169        | org.eclipse.smarthome.io.javasound
112 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Monitor                              | org.eclipse.smarthome.io.monitor
113 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Net I/O Bundle                       | org.eclipse.smarthome.io.net
114 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome REST Interface Bundle                | org.eclipse.smarthome.io.rest
115 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Core REST API                        | org.eclipse.smarthome.io.rest.core
116 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome REST mDNS Announcer                  | org.eclipse.smarthome.io.rest.mdns
117 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Sitemap REST API                     | org.eclipse.smarthome.io.rest.sitemap
118 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome SSE REST API                         | org.eclipse.smarthome.io.rest.sse
119 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Voice REST API                       | org.eclipse.smarthome.io.rest.voice
120 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Bonjour/MDS Service Discovery Bundle | org.eclipse.smarthome.io.transport.mdns
121 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Web Audio Support                    | org.eclipse.smarthome.io.webaudio
122 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Model Core                           | org.eclipse.smarthome.model.core
123 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Item Model                           | org.eclipse.smarthome.model.item
124 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Item Model Runtime                   | org.eclipse.smarthome.model.item.runtime
125 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Persistence Model                    | org.eclipse.smarthome.model.persistence
126 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Persistence Runtime                  | org.eclipse.smarthome.model.persistence.runtime
127 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Rule Model                           | org.eclipse.smarthome.model.rule
128 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Rule Runtime                         | org.eclipse.smarthome.model.rule.runtime
129 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Script                               | org.eclipse.smarthome.model.script
130 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Script Runtime                       | org.eclipse.smarthome.model.script.runtime
131 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Sitemap Model                        | org.eclipse.smarthome.model.sitemap
132 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Sitemap Runtime                      | org.eclipse.smarthome.model.sitemap.runtime
133 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Thing Model                          | org.eclipse.smarthome.model.thing
134 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Thing Model Runtime                  | org.eclipse.smarthome.model.thing.runtime
135 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Json Storage Service                 | org.eclipse.smarthome.storage.json
136 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome UI                                   | org.eclipse.smarthome.ui
137 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome UI Icons                             | org.eclipse.smarthome.ui.icon
138 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Classic IconSet                      | org.eclipse.smarthome.ui.iconset.classic
188 | Active   |  75 | 0.9.0.b5               | Eclipse SmartHome Exec Transformation Service          | org.eclipse.smarthome.transform.exec
189 | Active   |  75 | 0.9.0.b5               | Eclipse SmartHome JavaScript Transformation Service    | org.eclipse.smarthome.transform.javascript
190 | Active   |  75 | 0.9.0.b5               | Eclipse SmartHome JSonPath Transformation Service      | org.eclipse.smarthome.transform.jsonpath
191 | Active   |  75 | 0.9.0.b5               | Eclipse SmartHome Map Transformation Service           | org.eclipse.smarthome.transform.map
192 | Active   |  75 | 0.9.0.b5               | Eclipse SmartHome RegEx Transformation Service         | org.eclipse.smarthome.transform.regex
193 | Active   |  75 | 0.9.0.b5               | Eclipse SmartHome Scale Transformation Service         | org.eclipse.smarthome.transform.scale
194 | Active   |  75 | 0.9.0.b5               | Eclipse SmartHome XPath Transformation Service         | org.eclipse.smarthome.transform.xpath
195 | Active   |  75 | 0.9.0.b5               | Eclipse SmartHome Xslt Transformation Service          | org.eclipse.smarthome.transform.xslt
196 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Basic UI, Fragments: 200             | org.eclipse.smarthome.ui.basic
197 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome WebApp UI                            | org.eclipse.smarthome.ui.classic
198 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Paper UI, Fragments: 204             | org.eclipse.smarthome.ui.paper
208 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Automation API                       | org.eclipse.smarthome.automation.api
209 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Automation commands                  | org.eclipse.smarthome.automation.commands
210 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Automation Core                      | org.eclipse.smarthome.automation.core
211 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Automation Module Core               | org.eclipse.smarthome.automation.module.core
212 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Automation Media Modules             | org.eclipse.smarthome.automation.module.media
213 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Automation Module Script             | org.eclipse.smarthome.automation.module.script
214 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Automation Script Globals            | org.eclipse.smarthome.automation.module.script.defaultscope
215 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Automation Script RuleSupport        | org.eclipse.smarthome.automation.module.script.rulesupport
216 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Automation Module Timer              | org.eclipse.smarthome.automation.module.timer
217 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Automation GSON Parser               | org.eclipse.smarthome.automation.parser.gson
218 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Automation Providers                 | org.eclipse.smarthome.automation.providers
219 | Active   |  80 | 0.9.0.b5               | Eclipse SmartHome Automation REST API                  | org.eclipse.smarthome.automation.rest
i have deleted the folders…now what can i do…:frowning:
Delete only the CONTENT, not the folders.
After deleting the content restart openHAB and see if your problems are gone …
Like I said on the other thread.
Simply recreate those folders and restart OH.
mkdir /var/lib/openhab2/cache
mkdir /var/lib/openhab2/tmp
sudo chown openhab:openhab /var/lib/openhab2/cache
sudo chown openhab:openhab /var/lib/openhab2/tmp
sudo systemctl restart openhab2
thanks sir,i did the same, now the openhab is working fine
I struggling with the 2.0 to 2.1 upgrade on a windows 10 machine. im running powershell 5.1, however the very first command fails.
PS > Set-ExecutionPolicy Bypass
PS : Cannot find a process with the name ā€œBypassā€. Verify the process name and call the cmdlet again.
At line:1 char:1
  • PS > Set-ExecutionPolicy Bypass
  •   + CategoryInfo          : ObjectNotFound: (Bypass:String) [Get-Process], ProcessCommandException
      + FullyQualifiedErrorId : NoProcessFoundForGivenName,Microsoft.PowerShell.Commands.GetProcessCommand
Did you
Execute PowerShell with elevated rights (e.g. by right-clicking the start menu PowerShell entry and selecting ā€˜Run as Administrator’)
i did - a few times to be sure.
What happend when you type:
Get-ExecutionPolicy
Also check your .Net Framework.
If i’m right you need .Net Framework 4.5 or higher for Powershell 5.
guys, you really cant fix stupid.
Maybe i’m not being entirely fair on myself…
The instructions say:slight_smile:
allow scripts to execute by running this command (confirm the security prompt):
So i copied and pasted that entire line, including 'PS > ’
Now I’ve realised my mistake, its working almost perfectly :slight_smile:
All Items gone after update, deleted inside of cache and tmp folder, restarted service, still no items. Only way is to downgrade back to a 2.0 backup.
ThatĀ“s it for 2.1 on my RasPi…
:nerd_face:
Upgrade from 2.0 to 2.1 in openhabian work like a charme.
Thank you for your good work! :+1:
The only thing i have:
Channel not found for datapoint problem, hope we find a way to fix it soon.
[ematic.handler.HomematicThingHandler] - Channel not found for datapoint
Thank you to all openhab team
Aleady reported, take a look here: Homematic Binding: "Channel not found for datapoint" errors for definitely existing channels
