Hi
I try everything and I can start openhab 2
After upgrade via apt openhab stops working
I remove everything ( lost all my data) and try to fresh install openhab via apt but it still no working
I can’t get openhab on port 8080 8443 change the ports still nothing
If I run openhab-cli start --debug I get
sudo openhab-cli start --debug
A systemd service configuration exists…
Use ‘sudo /bin/systemctl start openhab2.service’ to start an openHAB service
Launching an instance in this terminal…
Launching the openHAB runtime…
Listening for transport dt_socket at address: 5005
Hit ‘’ for a list of available commands
and ‘[cmd] --help’ for help on a specific command.
Hit ‘’ or type ‘system:shutdown’ or ‘logout’ to shutdown openHAB.
Error in initialization script: /var/lib/openhab2/etc/shell.init.script: /var/lib/openhab2/etc/shell.init.script
in openhablog I get only
gru 19, 2017 3:45:02 PM org.apache.karaf.main.lock.SimpleFileLock lock
INFO: Lock acquired
gru 19, 2017 3:45:02 PM org.apache.karaf.main.Main$KarafLockCallback lockAquired
INFO: Lock acquired. Setting startlevel to 100
This totally disaster. I lost my all home automation !!!
I install manually openhab2 in /opt directory and still nothing.
Next find the script “shell.init.script” openhab-2.2.0.zip but it isn’t in apt packages !
copy script to /var/lib/openhab2/etc/ try to start… still nothing
openhab-cli info returns
Version: 2.2.0 (Build)
User: openhab (Active Process 4905)
User Groups: users root sudo
Yes I did still nothing…
I use openhab since four years (1.7 .1.8 … manually install) upgraded 2.0 to 2.1 via apt and there was no problem…
I appreciate your help very much, but the situation is very frustrating
ache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1479)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1435)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109)
Dec 19 18:00:40 openHABianPi karaf[7523]: at java.lang.Thread.run(Thread.java:748)
Dec 19 18:00:40 openHABianPi karaf[7523]: 2017-12-19 18:00:40,746 CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging]) ERROR Unab
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.plugins.util.PluginBuilder.findFactoryMethod(PluginBuilder.java:224)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.plugins.util.PluginBuilder.build(PluginBuilder.java:130)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.AbstractConfiguration.createPluginObject(AbstractConfiguration.java:952)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.AbstractConfiguration.createConfiguration(AbstractConfiguration.java:892
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.AbstractConfiguration.createConfiguration(AbstractConfiguration.java:884
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.AbstractConfiguration.doConfigure(AbstractConfiguration.java:508)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.AbstractConfiguration.initialize(AbstractConfiguration.java:232)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.AbstractConfiguration.start(AbstractConfiguration.java:244)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.LoggerContext.setConfiguration(LoggerContext.java:545)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.LoggerContext.start(LoggerContext.java:261)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl.doUpdate(PaxLoggingServiceImpl.java:213)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl.updated(PaxLoggingServiceImpl.java:158)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl$1ManagedPaxLoggingService.updated(PaxLoggingServi
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)
Dec 19 18:00:40 openHABianPi karaf[7523]: 2017-12-19 18:00:40,767 CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging]) ERROR Cann
Dec 19 18:00:40 openHABianPi karaf[7523]: at java.io.RandomAccessFile.open0(Native Method)
Dec 19 18:00:40 openHABianPi karaf[7523]: at java.io.RandomAccessFile.open(RandomAccessFile.java:316)
Dec 19 18:00:40 openHABianPi karaf[7523]: at java.io.RandomAccessFile.<init>(RandomAccessFile.java:243)
Dec 19 18:00:40 openHABianPi karaf[7523]: at java.io.RandomAccessFile.<init>(RandomAccessFile.java:124)
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.appender.rolling.RollingRandomAccessFileManager$RollingRandomAccessFileManagerF
Dec 19 18:00:40 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.appender.AbstractManager.getManager(AbstractManager.java:112)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.appender.OutputStreamManager.getManager(OutputStreamManager.java:114)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.appender.rolling.RollingRandomAccessFileManager.getRollingRandomAccessFileManag
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.appender.RollingRandomAccessFileAppender$Builder.build(RollingRandomAccessFileA
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.plugins.util.PluginBuilder.build(PluginBuilder.java:122)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.AbstractConfiguration.createPluginObject(AbstractConfiguration.java:952)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.AbstractConfiguration.createConfiguration(AbstractConfiguration.java:892
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.AbstractConfiguration.createConfiguration(AbstractConfiguration.java:884
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.AbstractConfiguration.doConfigure(AbstractConfiguration.java:508)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.AbstractConfiguration.initialize(AbstractConfiguration.java:232)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.AbstractConfiguration.start(AbstractConfiguration.java:244)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.LoggerContext.setConfiguration(LoggerContext.java:545)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.LoggerContext.start(LoggerContext.java:261)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl.doUpdate(PaxLoggingServiceImpl.java:213)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl.updated(PaxLoggingServiceImpl.java:158)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl$1ManagedPaxLoggingService.updated(PaxLoggingServi
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1479)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1435)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109)
Dec 19 18:00:41 openHABianPi karaf[7523]: at java.lang.Thread.run(Thread.java:748)
Dec 19 18:00:41 openHABianPi karaf[7523]: 2017-12-19 18:00:40,775 CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging]) ERROR Unab
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.appender.AbstractManager.getManager(AbstractManager.java:114)
Dec 19 18:00:41 openHABianPi karaf[7523]: 2017-12-19 18:00:40,782 CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging]) ERROR Unab
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.plugins.util.PluginBuilder.findFactoryMethod(PluginBuilder.java:224)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.config.plugins.util.PluginBuilder.build(PluginBuilder.java:130)
Dec 19 18:00:41 openHABianPi karaf[7523]: 2017-12-19 18:00:40,803 CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging]) ERROR Cann
Dec 19 18:00:41 openHABianPi karaf[7523]: at java.io.RandomAccessFile.open0(Native Method)
Dec 19 18:00:41 openHABianPi karaf[7523]: at java.io.RandomAccessFile.open(RandomAccessFile.java:316)
Dec 19 18:00:41 openHABianPi karaf[7523]: at java.io.RandomAccessFile.<init>(RandomAccessFile.java:243)
Dec 19 18:00:41 openHABianPi karaf[7523]: at java.io.RandomAccessFile.<init>(RandomAccessFile.java:124)
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.appender.rolling.RollingRandomAccessFileManager$RollingRandomAccessFileManagerF
Dec 19 18:00:41 openHABianPi karaf[7523]: at org.apache.logging.log4j.core.appender.AbstractManager.getManager(AbstractManager.java:112)
Dec 19 18:00:41 openHABianPi karaf[7523]: 2017-12-19 18:00:40,811 CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging]) ERROR Unab
Dec 19 18:00:41 openHABianPi karaf[7523]: 2017-12-19 18:00:40,818 CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging]) ERROR Unab
Dec 19 18:00:41 openHABianPi karaf[7523]: 2017-12-19 18:00:40,826 CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging]) ERROR Null
Dec 19 18:00:41 openHABianPi karaf[7523]: 2017-12-19 18:00:40,830 CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging]) ERROR Null
Dec 19 18:00:41 openHABianPi karaf[7523]: 2017-12-19 18:00:40,834 CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging]) ERROR Null
Dec 19 18:00:41 openHABianPi karaf[7523]: 2017-12-19 18:00:40,837 CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging]) ERROR Unab
Dec 19 18:00:41 openHABianPi karaf[7523]: 2017-12-19 18:00:40,840 CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging]) ERROR Unab
Dec 19 18:00:41 openHABianPi karaf[7523]: 2017-12-19 18:00:40,844 CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging]) ERROR Unab
Dec 19 18:02:01 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
only last lines
any advice how i can get access back
permissions on files seams to be fine
Ok
I restart and reinstall everything and it works
I still do not understand why apt upgrade don’t works properly.
I appreciate your help very much and thank you for your time:slight_smile:
I still have problem with wave controller
