Here is result
18:26:41.362 [WARN ] [us.internal.parser.EBusTelegramParser] - eBus buffer pos error! Can happen …
18:26:51.120 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:27:00.877 [INFO ] [ommandclass.ZWaveSecurityCommandClass] - Update networkKey
18:27:00.920 [INFO ] [ding.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
18:27:00.930 [INFO ] [ding.zwave.handler.ZWaveSerialHandler] - Connecting to serial port ‘/dev/ttyUSB0’
18:27:00.950 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zwave:serial_zstick:3f018aa3’ has been updated.
18:27:01.009 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zwave:serial_zstick:3f018aa3’ changed from OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyUSB0 does not exist to OFFLINE (BRIDGE_OFFLINE): Controller is offline
18:27:01.022 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zwave:serial_zstick:3f018aa3’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyUSB0 does not exist
18:27:01.124 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:27:01.451 [WARN ] [e.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.scale.internal.ScaleTransformationService@9cd65a’ with value ‘NULL’ failed: An error occurred while opening file.
18:27:11.306 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:27:21.300 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:27:31.963 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:27:42.732 [WARN ] [e.core.transform.TransformationHelper] - Transformation ‘org.eclipse.smarthome.transform.scale.internal.ScaleTransformationService@9cd65a’ with value ‘NULL’ failed: An error occurred while opening file.
18:27:54.040 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:28:01.722 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:28:11.372 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:28:31.561 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:29:21.130 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:29:21.639 [INFO ] [smarthome.event.ItemStateChangedEvent] - e_Temp_Room changed from 25.6875 to 25.5
18:29:29.863 [INFO ] [smarthome.event.ItemStateChangedEvent] - e_Temp_Room_Dis changed from 28.625 to 28.5
18:29:51.151 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:30:01.942 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:30:11.333 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:30:21.324 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:30:31.884 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:31:01.368 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:31:06.872 [WARN ] [connection.AbstractEBusWriteConnector] - Resend failed, remove data from sending queue …
18:31:11.040 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:31:21.386 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:31:31.325 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:31:41.349 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:31:51.346 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:32:01.893 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:32:11.356 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:32:21.419 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:32:23.227 [WARN ] [org.eclipse.jetty.http.HttpParser ] - bad HTTP parsed: 400 No Host for HttpChannelOverHttp@16d89f9{r=0,c=false,a=IDLE,uri=null}
18:32:31.666 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:32:41.640 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:33:01.298 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:33:32.330 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:33:41.390 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:33:50.436 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:33:59.413 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:34:06.995 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:34:15.174 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:34:23.252 [INFO ] [smarthome.event.ItemStateChangedEvent] - e_Temp_Room changed from 25.5 to 25.625
18:34:30.216 [INFO ] [smarthome.event.ItemStateChangedEvent] - e_Temp_Room_Dis changed from 28.5 to 28.625
18:34:31.682 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:34:41.165 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:34:51.180 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
18:35:07.297 [WARN ] [connection.AbstractEBusWriteConnector] - Slave CRC wrong, resend!
18:35:07.310 [WARN ] [connection.AbstractEBusWriteConnector] - Resend failed, remove data from sending queue …
18:35:21.767 [WARN ] [us.internal.parser.EBusTelegramParser] - eBus buffer pos error! Can happen …
18:35:31.316 [ERROR] [connection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
messages from ebus are OK
