Openhab 2.2 problem after upgrade
Hi all
I have problem with start script after upgrade to openhab 2.2 if I run systemctl start openhab2, openhab 2.2 try to starts but with no success. In /var/log syslog I get
Dec 18 19:48:22 localhost start.sh[23567]: Launching the openHAB runtime…
Dec 18 19:48:25 localhost start.sh[23567]: null
Dec 18 19:48:25 localhost start.sh[23567]: Error occurred shutting down framework: java.lang.NumberFormatException: null
Dec 18 19:48:25 localhost start.sh[23567]: java.lang.NumberFormatException: null
Dec 18 19:48:25 localhost start.sh[23567]: at java.lang.Integer.parseInt(Integer.java:542)
Dec 18 19:48:25 localhost start.sh[23567]: at java.lang.Integer.parseInt(Integer.java:615)
Dec 18 19:48:25 localhost start.sh[23567]: at org.apache.karaf.main.ConfigProperties.(ConfigProperties.java:214)
Dec 18 19:48:25 localhost start.sh[23567]: at org.apache.karaf.main.Main.updateInstancePidAfterShutdown(Main.java:228)
Dec 18 19:48:25 localhost start.sh[23567]: at org.apache.karaf.main.Main.main(Main.java:193)
Dec 18 19:48:25 localhost systemd[1]: openhab2.service: main process exited, code=exited, status=254/n/a
Dec 18 19:48:25 localhost systemd[1]: Unit openhab2.service entered failed state.
Dec 18 19:48:25 localhost wpa_supplicant[887]: wlan0: Failed to initiate sched scan
Dec 18 19:48:25 localhost systemd[1]: openhab2.service holdoff time over, scheduling restart.
Dec 18 19:48:25 localhost systemd[1]: Stopping Starts and stops the openHAB Home Automation Bus…
Dec 18 19:48:25 localhost systemd[1]: Starting Starts and stops the openHAB Home Automation Bus…
Dec 18 19:48:25 localhost systemd[1]: Started Starts and stops the openHAB Home Automation Bus.
If I run /usr/share/openhab2/start.sh openhab starts…
btw
After upgrade i have to manually create directory userdata in /usr/share/openhab
java -version
java version "1.8.0_151"
Java™ SE Runtime Environment (build 1.8.0_151-b12)
Java HotSpot™ Client VM (build 25.151-b12, mixed mode)
uname -a
Linux cubietruck 4.13.16-sunxi #20 SMP Fri Nov 24 19:50:07 CET 2017 armv7l GNU/Linux
If you’re using the apt packages you can use the command:
sudo openhab-cli start --debug
To see if openhab starts properly as a non service. The userdata folder should be /var/lib/openhab2 and you can check this with:
openhab-cli info
Hi
If I run sudo openhab-cli start --debug
I get
root@cubietruck:/lib/systemd/system# openhab-cli start --debug
A systemd service configuration exists…
Use ‘sudo /bin/systemctl start openhab2.service’ to start an openHAB service
Launching an instance in this terminal…
Listening for transport dt_socket at address: 5005
                      __  _____    ____
____ ____ ___ ____ / / / / | / __ )
/ __ / __ / _ / __ / // / /| | / __ |
/ / // / __/ / / / __ / ___ |/ // /
_/ ./_// /// /// |/_____/
/_/ 2.2.0
Release Build
Hit ‘’ for a list of available commands
and ‘[cmd] --help’ for help on a specific command.
Hit ‘’ or type ‘system:shutdown’ or ‘logout’ to shutdown openHAB.
openhab> 22:58:16.750 [CM Configuration Updater (ManagedService Update: pid=[org.openhab.mail])] ERROR org.apache.felix.configadmin - [org.openhab.core.scriptengine.action.ActionService, org.osgi.service.cm.ManagedService, id=134, bundle=235/mvn:org.openhab.action/org.openhab.action.mail/1.11.0]: Updating property mail of configuration org.openhab.mail caused a problem: Parameters mail:hostname and mail:from are mandatory and must be configured. Please check your openhab.cfg!
org.osgi.service.cm.ConfigurationException: mail : Parameters mail:hostname and mail:from are mandatory and must be configured. Please check your openhab.cfg!
at org.openhab.action.mail.internal.MailActionService.updated(MailActionService.java:86) [235:org.openhab.action.mail:1.11.0]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1479) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1435) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [7:org.apache.felix.configadmin:1.8.16]
openhab starts
but if i run systemctl start openhab2.service openhab is trying to start but it can’t.
my openhab2.service looks like that
Unit]
Description=Starts and stops the openHAB Home Automation Bus
Documentation=http://www.openhab.org
Wants=network-online.target
After=network-online.target
[Service]
Type=simple
GuessMainPID=yes
User=root
ExecStart=/usr/share/openhab2/start.sh
ExecStop=kill -SIGINT $MAINPID
Restart=on-failure
WorkingDirectory=/usr/share/openhab2
[Install]
WantedBy=multi-user.target
and /usr/share/openhab2/start.sh
cho Launching the openHAB runtime…
DIRNAME=dirname "$0"
exec “${DIRNAME}/runtime/bin/karaf” “${@}”
before upgrade to 2.2 all works OK
Can’t get openHAB up and running either getting this error in the logs when trying to start’
Dec 18 23:06:58 raspberrypi systemd[1]: Starting The openHAB 2 Home Automation Bus Solution...
Dec 18 23:06:58 raspberrypi systemd[1]: Started The openHAB 2 Home Automation Bus Solution.
Dec 18 23:06:58 raspberrypi start.sh[2312]: Launching the openHAB runtime...
Dec 18 23:07:00 raspberrypi start.sh[2312]: null
Dec 18 23:07:00 raspberrypi start.sh[2312]: Error occurred shutting down framework: java.lang.NumberFormatException: null
Dec 18 23:07:00 raspberrypi start.sh[2312]: java.lang.NumberFormatException: null
Dec 18 23:07:00 raspberrypi start.sh[2312]: at java.lang.Integer.parseInt(Integer.java:542)
Dec 18 23:07:00 raspberrypi start.sh[2312]: at java.lang.Integer.parseInt(Integer.java:615)
Dec 18 23:07:00 raspberrypi start.sh[2312]: at org.apache.karaf.main.ConfigProperties.<init>(ConfigProperties.java:214)
Dec 18 23:07:00 raspberrypi start.sh[2312]: at org.apache.karaf.main.Main.updateInstancePidAfterShutdown(Main.java:228)
Dec 18 23:07:00 raspberrypi start.sh[2312]: at org.apache.karaf.main.Main.main(Main.java:193)
Dec 18 23:07:00 raspberrypi systemd[1]: openhab2.service: main process exited, code=exited, status=254/n/a
Dec 18 23:07:00 raspberrypi kill[2448]: kill: invalid argument S
I can get openhab to start as a non service using @Benjy comments.
Version:     2.2.0 (Build)
User:        openhab (Environment Variable Set)
User Groups: openhab
Directories: Folder Name      | Path                        | User:Group
             OPENHAB_HOME     | /usr/share/openhab2         | openhab:openhab
             OPENHAB_RUNTIME  | /usr/share/openhab2/runtime | openhab:openhab
             OPENHAB_USERDATA | /var/lib/openhab2           | openhab:openhab
             OPENHAB_CONF     | /etc/openhab2               | openhab:openhab
             OPENHAB_LOGDIR   | /var/log/openhab2           | openhab:openhab
URLs:        http://192.168.10.200:8080
             https://192.168.10.200:8443
Hi @Murpher,
The actual file should be in /usr/lib/systemd/system/openhab2.service
Can you delete the one that exists in /lib/ and see if this resolves your issue? You need to follow it with sudo systemctl daemon-reload
i.e.
sudo rm /lib/systemd/system/openhab2.service
sudo systemctl enable openhab2.service
sudo systemctl start openhab2.service
Thanks @Benjy for replying that did the trick.
I decided to remove 2.1 and install 2.2 I now have the Welcome to openHAB 2 - Initial Setup screen in my browser but when I select standard the browser try’s going to start/inbox page but just stays on the Welcome to openHAB 2 - Initial Setup screen.
Nothing happens either when I select Standard or Demo
Have you come across this before?
I havent but I have seen other who have managed to get past it by clearing the tmp and cache directories:
sudo systemctl stop openhab2.service
sudo rm -rf /var/lib/openhab2/cache/*
sudo rm -rf /var/lib/openhab2/tmp/*
Let me know how it goes!
Unfortunately that didn’t work
can’t even get round it by going to paperui/index.html#/inbox/search just get a 404 error
Are there errors or warnings in /var/log/openhab2/openhab.log there are a couple of reasons why this may happen but it depends on the error.
Nothing since your suggestion to get openHAB up and running only this from before hand.
2017-12-18 21:58:20.927 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.10.200:8080
2017-12-18 21:58:20.945 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.10.200:8443
2017-12-18 21:58:33.710 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
2017-12-18 22:44:52.488 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2017-12-18 22:44:56.338 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.10.200:8080
2017-12-18 22:44:56.342 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.10.200:8443
2017-12-18 22:46:04.305 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
So does that log change at all with restarts? Is that timestamp current? I suspect that if it’s not then you should reinstall with the default logging configuration:
sudo apt-get -o Dpkg::Options::="--force-confask" --reinstall install openhab2
And responding with Y for each of the files that it prompts in /var/lib/openhab2 (N for files in /etc/).
Just got it solved.
I saw you comments in another post https://community.openhab.org/t/openhab-2-2-stable-upgrade-errors/37437/25.
Permission of folders! for some reason my /var/lib/openhab2/etc folder was owned by root and not openhab when I chown this to openhab it worked.
Thanks for help @Benjy wouldn’t of got it sorted without it.
Glad you got it sorted! Sorry I hadn’t suggested that to you specifically though! Nice debugging on your part!
Happy automating! :slight_smile:
Couldn’t let you do all the work! :slight_smile:
Moving openhab2.service fixed it for me with manual installation. Docs probably should be updated as I ended up reloading from scratch. Although I’m having other problems and might revert to the upgraded version if they don’t go away.
Thank you @Benjy, I had also the issue that OpenHAB did not start after upgrading fom 2.1 -> 2.2. Removing the contents of /var/lib/openhab2/cache/ and /var/lib/openhab2/tmp/ solved the issue for me.
I was using apt to upgrade. Maybe the package should clear cache and tmp automatically.
The installation package does this automatically after the install completes, but for reasons I can’t explain just yet the first run of a new update sometimes (only rarely) runs better after a cache/tmp removal.
I will add a cli shortcut so that the command:
sudo openhab-cli clean-cache
is all that would be needed, instead of having to remember and type out the directories each time.
Adding in, same issues, no response via 8080 or 8443.
Karaf console on 8101 also no response.
openhab-cli info - no visible issues
Did the clear of the tmp and cache per your advice, and seems to have done the trick. Restart the service, and it’s now loading normally.
Thx.
Jp.
