Yep that’s the one,
Let’s try more debugging…
sudo systemd-analyze verify /usr/lib/systemd/system/openhab2.service
sudo systemctl daemon-reload
Yep that’s the one,
Does not seem to recognise ‘verify’
pi@raspberrypi:/etc/openhab2 $ sudo systemd-analyze verify
Unknown operation 'verify'.
blame critical-chain dot dump plot set-log-level time
I had the same issue - based on your post I looked at the openhab2.service file in the
/lib/systemd/system
I noticed that the openhab2.service file was the old version.
I removed it - together with a systemctl daemon-reload / enable - and now it works …
Thanks for your input !!
Hi @Brambot, I think you’re on the answer there!
@cgeo can you delete the /lib/systemd/systemd/openhab2.service file (not the one in /usr/) and do another reload?
Guys,
With the suggestion of @Brambot I got past the error. But it was not over. Logs indicated several permission issues
Dec 19 00:16:59 raspberrypi karaf[27231]: Unable to update instance pid: /var/lib/openhab2/tmp/instances/instance.properties (Permission denied)
Dec 19 00:19:12 raspberrypi karaf[27642]: 2017-12-19 00:19:12,547 CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging]) ERROR Cannot access RandomAccessFile java.io.FileNotFoundException: /var/log/openhab2/audit.log (Permission denied) java.io.FileNotFoundException: /var/log/openhab2/audit.log (Permission denied)
Dec 19 00:15:23 raspberrypi karaf[26526]: java.io.FileNotFoundException: /var/lib/openhab2/cache/org.eclipse.osgi/.manager/.fileTableLock (Permission denied)
I really do not know how this has happened honestly. I restored the permissions to openhab for
and now everything starts up fine!
Many thanks @Benjy and @Brambot
The support was better than what I get for paid enterprise software
Glad you got it sorted! And that we have an answer to give to other people that may encounter this error!
I getting continual repeated messages in the logs that I never got before the upgrade
2017-12-19 12:50:13.040 [me.event.ThingUpdatedEvent] - Thing ‘zway:zwayDevice:192_168_1_210:5’ has been updated.
2017-12-19 12:50:20.391 [me.event.ThingUpdatedEvent] - Thing ‘zway:zwayDevice:192_168_1_210:5’ has been updated.
2017-12-19 12:50:41.410 [me.event.ThingUpdatedEvent] - Thing ‘zway:zwayDevice:192_168_1_210:4’ has been updated.
2017-12-19 12:52:33.468 [me.event.ThingUpdatedEvent] - Thing ‘zway:zwayDevice:192_168_1_210:5’ has been updated.
2017-12-19 13:00:12.216 [me.event.ThingUpdatedEvent] - Thing ‘zway:zwayDevice:192_168_1_210:5’ has been updated.
2017-12-19 13:01:25.941 [me.event.ThingUpdatedEvent] - Thing ‘zway:zwayDevice:192_168_1_210:4’ has been updated.
2017-12-19 13:02:33.788 [me.event.ThingUpdatedEvent] - Thing ‘zway:zwayDevice:192_168_1_210:5’ has been updated.
2017-12-19 13:05:32.673 [me.event.ThingUpdatedEvent] - Thing ‘zway:zwayDevice:192_168_1_210:4’ has been updated.
2017-12-19 13:07:33.868 [me.event.ThingUpdatedEvent] - Thing ‘zway:zwayDevice:192_168_1_210:5’ has been updated.
2017-12-19 13:10:38.100 [me.event.ThingUpdatedEvent] - Thing ‘zway:zwayDevice:192_168_1_210:5’ has been updated.
Any ideas, they fill the logs
Hi Lars,
same issue same settings here.
Did you find a solution?
I also get continously repeated messages in the logs.
2017-12-21 22:36:15.085 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:iBoxLED’ has been updated.
2017-12-21 22:36:20.089 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:iBoxLED’ has been updated.
2017-12-21 22:36:25.092 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:iBoxLED’ has been updated.
2017-12-21 22:36:30.094 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:iBoxLED’ has been updated.
2017-12-21 22:36:35.095 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:iBoxLED’ has been updated.
2017-12-21 22:36:40.099 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:iBoxLED’ has been updated.
2017-12-21 22:36:45.101 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:iBoxLED’ has been updated.
2017-12-21 22:36:50.104 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:iBoxLED’ has been updated.
2017-12-21 22:36:55.107 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:iBoxLED’ has been updated.
2017-12-21 22:37:00.109 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:iBoxLED’ has been updated.
Does anybody know how to fix that?
Nope…not yet. Its still a open issue for me. But “good” to hear, that i am not alone. This means, there is a reproducable issue connected to German language-settings…so there is at least hope for a solution.
I see the same thing in my log, and I don’t have German language, so probably not connected to that.
Have you been able to also solve the neato binding? I get the same error with trying to start the binding.
openhab> bundle:start 207
Error executing command: Error executing command on bundles:
Error starting bundle 207: Could not resolve module: org.openhab.binding.neato [207]
Unresolved requirement: Import-Package: org.apache.commons.codec.binary; version="1.6.0"
Thanks!
Same here! Is there a way to fix this?
I posted this in another topic earlier. Hope it helps.
I ran this in karaf. This was right after I updated to 2.2. I’m no computer wiz so I’m not sure what negative effects this would have but it stopped the flood of milight updates in the log.
log:set ERROR smarthome.event.ThingUpdatedEvent
A bigger issue with this that I recently noticed is that every ThingUpdatedEvent
corresponds to a write to /var/lib/openhab2/jsondb/org.eclipse.smarthome.core.thing.Thing.json
and every time that file is written to, OpenHAB creates a backup of the file. This means that the backups are useless, since the oldest one is from just a few minutes ago…
Have anyone figured out what causes this?
I dont know if this recoment to this issue but what my external ssd is doing 24/7 is read/write all the time. The ssd is busy all the time.
By the looks of the subject of this thread I have the same problem, so followed all suggestions but still can not get it to work. One thing which looks different from what was described above is the output from “openhab-cli start --debug”, after some time I get the following message (of which I do not know if it is related)
openhab> 21:30:22.433 [Start Level: Equinox Container: e8809b83-5429-4dc5-9644-7e56583d83df] ERROR org.openhab.ui.dashboard - [org.openhab.dashboard(20)] The activate method has thrown an exception
java.lang.IllegalArgumentException: Network prefix length is not within bounds
at org.eclipse.smarthome.core.net.NetUtil.networkPrefixLengthToNetmask(NetUtil.java:251) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.core.net.NetUtil.getIpv4NetAddress(NetUtil.java:289) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.core.net.NetUtil.getIPv4inSubnet(NetUtil.java:326) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.core.net.NetUtil.getPrimaryIpv4HostAddress(NetUtil.java:79) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.openhab.ui.dashboard.internal.DashboardService.activate(DashboardService.java:83) [189:org.openhab.ui.dashboard:2.2.0]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
[Start Level: Equinox Container: 5f334267-7d3b-4ceb-b5b4-f01e09fde248] ERROR org.openhab.ui.dashboard.internal.DashboardService - Error during dashboard startup: alias: '/start/index' is already in use in this or another context
When accessing OpenHab2 via the browser I get a internal server error
java.lang.NullPointerException
at org.openhab.ui.dashboard.internal.DashboardService.getLocalizedText(DashboardService.java:240)
But I am able to access the PaperUI.
Last thing I did was try to install OwnTracks and because the binding did not show up in the list with binding after I hit the install button, I restarted openHab2 and ended up in this situation (log files are empty by the way… )
Any clue as to what may be causing this?
did you ever solve this
Well no really, in the end I backed up my configuration and reinstalled OpenHAB. The I put back my configuration but this caused OpenHAB to not work (looked it didn’t recognise some of the config files) and I redid my configuration … and now it is working again
i’m experiencing the same problem but mine has developed on its own not from an upgrade im thinking about starting again myself
