running openHAB 2.2 on a Pi 2 with openHABian 1.4: just updated and done that already:
- stopped OH2
- deleted cache, tmp and config
- rebooted Pi
2017-12-19 17:40:11.181 [WARN ] [.smarthome.config.core.Configuration] - Could not set field value for field 'port': Can not set java.math.BigDecimal field org.openhab.binding.network.internal.NetworkHandlerConfiguration.port to java.lang.String
java.lang.IllegalArgumentException: Can not set java.math.BigDecimal field org.openhab.binding.network.internal.NetworkHandlerConfiguration.port to java.lang.String
at sun.reflect.UnsafeFieldAccessorImpl.throwSetIllegalArgumentException(UnsafeFieldAccessorImpl.java:167) [?:?]
at sun.reflect.UnsafeFieldAccessorImpl.throwSetIllegalArgumentException(UnsafeFieldAccessorImpl.java:171) [?:?]
at sun.reflect.UnsafeObjectFieldAccessorImpl.set(UnsafeObjectFieldAccessorImpl.java:81) [?:?]
at java.lang.reflect.Field.set(Field.java:764) [?:?]
at org.apache.commons.lang.reflect.FieldUtils.writeField(FieldUtils.java:523) [41:org.apache.commons.lang:2.6.0]
at org.apache.commons.lang.reflect.FieldUtils.writeField(FieldUtils.java:500) [41:org.apache.commons.lang:2.6.0]
at org.apache.commons.lang.reflect.FieldUtils.writeField(FieldUtils.java:560) [41:org.apache.commons.lang:2.6.0]
at org.eclipse.smarthome.config.core.Configuration.as(Configuration.java:106) [103:org.eclipse.smarthome.config.core:0.10.0.b1]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.getConfigAs(BaseThingHandler.java:284) [116:org.eclipse.smarthome.core.thing:0.10.0.b1]
at org.openhab.binding.network.handler.NetworkHandler.initialize(NetworkHandler.java:152) [218:org.openhab.binding.network:2.2.0]
at org.openhab.binding.network.handler.NetworkHandler.initialize(NetworkHandler.java:202) [218:org.openhab.binding.network:2.2.0]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [109:org.eclipse.smarthome.core:0.10.0.b1]
2017-12-19 17:40:11.213 [WARN ] [.smarthome.config.core.Configuration] - Could not set field value for field 'retry': Can not set java.math.BigDecimal field org.openhab.binding.network.internal.NetworkHandlerConfiguration.retry to java.lang.String
java.lang.IllegalArgumentException: Can not set java.math.BigDecimal field org.openhab.binding.network.internal.NetworkHandlerConfiguration.retry to java.lang.String
2017-12-19 17:40:11.219 [WARN ] [.smarthome.config.core.Configuration] - Could not set field value for field 'timeout': Can not set java.math.BigDecimal field org.openhab.binding.network.internal.NetworkHandlerConfiguration.timeout to java.lang.String
java.lang.IllegalArgumentException: Can not set java.math.BigDecimal field org.openhab.binding.network.internal.NetworkHandlerConfiguration.timeout to java.lang.String
2017-12-19 17:40:11.423 [WARN ] [lipse.smarthome.io.net.exec.ExecUtil] - Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program "arping" (in directory "."): error=2, Datei oder Verzeichnis nicht gefunden)
looks like this is related to Amazon dash buttons running libpcap
? (binding is running, though)
