I’ve done a clean setup of openhab 2.3, but despite of knx bridge result online write commands are not sended to the knx bus. KNX bus is connected and read values but doesn’t write commands even the event log reports the state change record. It’s really weird. I’ve already tried TUNNEL and ROUTER mode with and without parameters in different combinations.
Maybe it’s a problem similar to
https://community.openhab.org/t/send-value-to-knx/46676
https://community.openhab.org/t/no-sending-from-knx2-binding/45930/4
https://community.openhab.org/t/problems-with-knx/33373
None of the solutions previously proposed seems work to me.
Currently my setup it’s like that
knx.things
Bridge knx:ip:bridge [
type="ROUTER",
localSourceAddr="1.0.255"
Thing device switch {
Type switch : scale_interrato "Switch" [ ga="0/0/32+<0/1/32" ]
knx.items
Switch scale_interrato "Scale interrato" {channel="knx:device:bridge:switch:scale_interrato" }
I have separated the logs in different files. They report something like that
openhab.log
14-set-2018 12:13:10.382 [TRACE] [nhab.binding.knx.internal.client.AbstractKNXClient] - Received a Group Write telegram from '1.1.37' to '0/0/32'
events.log
initializing and status reading
2018-09-14 12:06:35.209 [hingStatusInfoChangedEvent] - 'knx:ip:bridge' changed from UNINITIALIZED to INITIALIZING
2018-09-14 12:06:35.227 [hingStatusInfoChangedEvent] - 'knx:ip:bridge' changed from INITIALIZING to UNKNOWN
2018-09-14 12:06:35.379 [hingStatusInfoChangedEvent] - 'knx:device:bridge:dimmer' changed from UNINITIALIZED to INITIALIZING
2018-09-14 12:06:35.410 [hingStatusInfoChangedEvent] - 'knx:device:bridge:dimmer' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE)
2018-09-14 12:06:35.469 [hingStatusInfoChangedEvent] - 'knx:device:bridge:switch' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONF$
2018-09-14 12:06:35.548 [hingStatusInfoChangedEvent] - 'knx:device:bridge:termostati' changed from UNINITIALIZED to INITIALIZING
2018-09-14 12:06:35.553 [hingStatusInfoChangedEvent] - 'knx:device:bridge:termostati' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE)
2018-09-14 12:06:35.561 [hingStatusInfoChangedEvent] - 'knx:device:bridge:contact' changed from UNINITIALIZED to INITIALIZING
2018-09-14 12:06:35.572 [hingStatusInfoChangedEvent] - 'knx:device:bridge:contact' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE)
2018-09-14 12:06:35.682 [hingStatusInfoChangedEvent] - 'knx:ip:bridge' changed from UNKNOWN to ONLINE
2018-09-14 12:06:35.697 [hingStatusInfoChangedEvent] - 'knx:device:bridge:dimmer' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-09-14 12:06:35.699 [hingStatusInfoChangedEvent] - 'knx:device:bridge:termostati' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-09-14 12:06:35.704 [hingStatusInfoChangedEvent] - 'knx:device:bridge:contact' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
commands
2018-09-14 12:06:52.506 [ome.event.ItemCommandEvent] - Item 'scale_interrato' received command ON
2018-09-14 12:06:52.518 [vent.ItemStateChangedEvent] - scale_interrato changed from NULL to ON
2018-09-14 12:06:53.360 [ome.event.ItemCommandEvent] - Item 'scale_interrato' received command OFF
2018-09-14 12:06:53.382 [vent.ItemStateChangedEvent] - scale_interrato changed from ON to OFF
example of successful read of another item
2018-09-14 12:13:02.536 [vent.ItemStateChangedEvent] - temperatura_soggiorno changed from 24.66 to 24.72
calimero.log
4-set-2018 12:13:10.382 [DEBUG] [calimero.link.224.0.23.12:3671 ] - indication 1.1.37->0/0/32 L_Data.ind, low priority hop count 5, tpdu 00 81
I can’t find any log record that reports a write or send or whatever command to the KNX bus, or at least i can’t recognize it.
That’s very strange because once the KNX bus connection is up and running i’ll expect that both read and write works.
