I have seen significant improvement (>20%) on the startup times of the OH2 service on my system lately and I wanted to check if anyone else is seeing the same.
Maybe the latest Snapshot builds have included some (better) way to optimize service startup?
Using:
HW Platform: Mid-ranged laptop (Intel CPU i5-6200U, 8GB RAM, 1TB HDD)
SW Platform: Linux Debian Jessie (8), Oracle Java build 1.8.0_171-b11, OH 2.3.0-Snapshot Build #1272
Addons:
Bindings: knx1,mqtt1,weather1,samsungtv,astro,ntp,wol1,networkupstools1, unifi, zwave (refactored)
UIs = basic,paper,habpanel,habmin
Persistence = mapdb,influxdb
Actions = mail,pushover
Transformations = map,regex,jsonpath
Misc = restdocs,homekit
400k bytes worth of *.items
, *.things
, *.rules
etc files in /etc/openhab2/
directory
openHAB 2.3.0 Snapshot Build #1272 Service startup time: 24 secs, 51 msecs
openhab.log:
2018-05-07 08:21:24.447 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to 'xx.xxx,yy.yyy'.
2018-05-07 08:21:24.557 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://172.16.13.100:8081
2018-05-07 08:21:24.559 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://172.16.13.100:8444
2018-05-07 08:21:29.420 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'KNX.items'
2018-05-07 08:21:29.497 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Simulation.items'
2018-05-07 08:21:29.510 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Unifi.items'
2018-05-07 08:21:29.543 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Paradox.items'
2018-05-07 08:21:29.562 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Astro.items'
2018-05-07 08:21:29.576 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'UPS.items'
2018-05-07 08:21:29.587 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ESP.items'
2018-05-07 08:21:29.609 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ZWave.items'
2018-05-07 08:21:29.646 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'WoL.items'
2018-05-07 08:21:29.659 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Weather.items'
2018-05-07 08:21:29.705 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Groups.items'
2018-05-07 08:21:30.247 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mPower.items'
2018-05-07 08:21:30.289 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ntp.items'
2018-05-07 08:21:30.296 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'SamsungTV.items'
2018-05-07 08:21:30.464 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2018-05-07 08:21:30.475 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2018-05-07 08:21:32.131 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Sun.rules'
2018-05-07 08:21:32.235 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Master_Lights.rules'
2018-05-07 08:21:32.282 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'UPS.rules'
2018-05-07 08:21:33.020 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Fib_Eyes.rules'
2018-05-07 08:21:33.128 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Email.rules'
2018-05-07 08:21:33.287 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Fib_Buttons.rules'
2018-05-07 08:21:33.341 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Paradox.rules'
2018-05-07 08:21:33.370 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Home.rules'
2018-05-07 08:21:39.497 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Unifi.rules'
2018-05-07 08:21:39.718 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-05-07 08:21:39.871 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Ana.sitemap'
2018-05-07 08:21:39.891 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'HomeR.sitemap'
2018-05-07 08:21:40.011 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Astro.things'
2018-05-07 08:21:40.109 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ntp.things'
2018-05-07 08:21:40.114 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'SamsungTV.things'
2018-05-07 08:21:40.121 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Unifi.things'
2018-05-07 08:21:40.186 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key astro:sun:local in ManagedThingProvider
, because it does not exists.
2018-05-07 08:21:40.188 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key astro:moon:local in ManagedThingProvide
r, because it does not exists.
2018-05-07 08:21:40.344 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2018-05-07 08:21:40.449 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2018-05-07 08:21:40.488 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2018-05-07 08:21:40.489 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2018-05-07 08:21:40.704 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:local
2018-05-07 08:21:40.733 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:sun:local every 60 seconds
2018-05-07 08:21:40.774 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:local
2018-05-07 08:21:40.786 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:moon:local every 60 seconds
2018-05-07 08:21:42.232 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2018-05-07 08:21:42.233 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'homer'
2018-05-07 08:21:42.429 [INFO ] [nx.internal.connection.KNXConnection] - Established connection to KNX bus on 224.0.23.12:3671 in mode ROUTER.
2018-05-07 08:21:42.585 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-05-07 08:21:42.612 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-05-07 08:21:43.645 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2018-05-07 08:21:43.645 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2018-05-07 08:21:43.645 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 3: Node found
2018-05-07 08:21:43.646 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 4: Node found
2018-05-07 08:21:43.646 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 6: Node found
2018-05-07 08:21:43.646 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 8: Node found
2018-05-07 08:21:43.647 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 9: Node found
2018-05-07 08:21:43.647 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 10: Node found
2018-05-07 08:21:43.647 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2018-05-07 08:21:43.648 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2018-05-07 08:21:43.648 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller---------
2018-05-07 08:21:43.651 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 8
2018-05-07 08:21:43.652 [INFO ] [age.SerialApiGetInitDataMessageClass] - -------------------------------------------------------------------------
2018-05-07 08:21:45.238 [INFO ] [b.core.service.AbstractActiveService] - NetworkUpsTools Refresh Service has been started
2018-05-07 08:21:45.414 [INFO ] [eather.internal.common.WeatherConfig] - ProviderConfig[providerName=WUNDERGROUND,apiKey=xxxx]
2018-05-07 08:21:45.415 [INFO ] [eather.internal.common.WeatherConfig] - LocationConfig[providerName=WUNDERGROUND,language=en,updateInterval=10,la
titude=xx.xxx,longitude=yy.yyy,woeid=<null>,locationId=HomeR,name=HomeR]
2018-05-07 08:21:46.114 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-05-07 08:21:46.133 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-05-07 08:21:48.498 [INFO ] [ternal.scheduler.WeatherJobScheduler] - Starting and scheduling weatherJob-HomeR with interval of 10 minutes
