OpenHab 2.4 and MySensors Binding 2.4.0.201812040738
Hi, I’m having a problem with a couple of my MySensors (Light actuators) that send “On” and “Off” messages (i.e. 5;0;1;0;2;Off) while the Light thing for the MySensors binding seems not to accpet those strings as valid OnOff states. Is there anything I can do to pre-transform the incoming strings to something valid or I will have to update my sketches on the MySensors devices for it to work?
This is what I can see in the log:
2019-06-10 09:56:09.430 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 5/4 to 2019-06-10T09:56:09.000+0200
2019-06-10 09:56:09.430 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 5;0;1;0;2;Off
2019-06-10 09:56:09.430 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 5 found in gateway
2019-06-10 09:56:09.432 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 5
2019-06-10 09:56:09.432 [ERROR] [nternal.event.MySensorsEventRegister] - Event broadcasting throw an exception
java.lang.IllegalArgumentException: String: Off, could not be used as OnOff state
at org.openhab.binding.mysensors.converter.MySensorsOnOffTypeConverter.fromString(MySensorsOnOffTypeConverter.java:31) ~[?:?]
at org.openhab.binding.mysensors.converter.MySensorsTypeConverter.stateFromChannel(MySensorsTypeConverter.java:32) ~[?:?]
at org.openhab.binding.mysensors.handler.MySensorsThingHandler.handleChildUpdateEvent(MySensorsThingHandler.java:303) ~[?:?]
at org.openhab.binding.mysensors.handler.MySensorsThingHandler.sensorUpdateEvent(MySensorsThingHandler.java:227) ~[?:?]
at org.openhab.binding.mysensors.internal.event.MySensorsEventRegister.lambda$4(MySensorsEventRegister.java:126) ~[?:?]
at java.lang.Iterable.forEach(Iterable.java:75) ~[?:?]
at org.openhab.binding.mysensors.internal.event.MySensorsEventRegister.notifyNodeUpdateEvent(MySensorsEventRegister.java:122) ~[?:?]
at org.openhab.binding.mysensors.internal.gateway.MySensorsGateway.handleSetReqMessage(MySensorsGateway.java:560) ~[?:?]
at org.openhab.binding.mysensors.internal.gateway.MySensorsGateway.handleIncomingMessage(MySensorsGateway.java:458) ~[?:?]
at org.openhab.binding.mysensors.internal.gateway.MySensorsGateway.messageReceived(MySensorsGateway.java:371) ~[?:?]
at org.openhab.binding.mysensors.internal.event.MySensorsEventRegister.lambda$1(MySensorsEventRegister.java:83) ~[?:?]
at java.lang.Iterable.forEach(Iterable.java:75) [?:?]
at org.openhab.binding.mysensors.internal.event.MySensorsEventRegister.notifyMessageReceived(MySensorsEventRegister.java:79) [233:org.openhab.binding.mysensors:2.4.0.201812040738]
at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection$MySensorsReader.run(MySensorsAbstractConnection.java:358) [233:org.openhab.binding.mysensors:2.4.0.201812040738]
Any idea of what can I try?
Thank you!
