OpenHAB 2.4 + Tasmota (MQTT + JSON) on RF Bridge and PIR Motion Sensor
Thank you, now I understand better.
This is my rule that I created, based on the JSONPATH approach. Which shows DETECT in the Basic UI and removes the value after 5 seconds. This JASONPATH syntax example. I got from here.
rule "esp8285 Sensor Processing"
    Item esp_8285_PIR_1 received update // Need received update if Data has not change but button still pressed
    if (esp_8285_PIR_1.state == "EC4B2E")
        my_Display.postUpdate("DETECT")
        Thread::sleep(5000)
        my_Display.postUpdate("")
Which required me to have an additional item to display in the BasicUI
String my_Display                     "[%s]"                  <motion>      (Test_Group)
With your approach, I take it that I don’t need this place holder item, which I called my_Display. I can do everything directly to esp_8285_PIR_1. Thank you for showing me another way of doing it. I have not considered and understood the full context until you spoon fed me. :slightly_smiling_face:
Now it makes sense. Much appreciated.
