i am using Openhabian on an RPI 3b with the newest Openhab 2.4 Snapshot (#1302) and i am getting some error-messages while using some openocean-items (newest binding-version) which i can´t decipher. The items themself are working just fine and it is not just a specific group of items which are affected.
The thing and item-codes are correct and i have the feeling that it is not the bindings fault. Maybe something else broke while upgrading to each snapshot. Sadly i have no idea, when the error-messages started because everything worked and still works fine.
Here is the error-code:
17:43:06.266 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'EG_Licht_Flur_2' received command ON
17:43:06.271 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'EventSubscriber.receive()' on 'org.eclipse.smarthome.core.thing.internal.CommunicationManager@1aa6f3f': null
at java.util.concurrent.ConcurrentHashMap.get(ConcurrentHashMap.java:936) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.lambda$2(CommunicationManager.java:253) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.toAcceptedType(CommunicationManager.java:329) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.lambda$8(CommunicationManager.java:305) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:184) [?:?]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:175) [?:?]
at java.util.Spliterators$ArraySpliterator.forEachRemaining(Spliterators.java:948) [?:?]
at java.util.stream.ReferencePipeline$Head.forEach(ReferencePipeline.java:580) [?:?]
at java.util.stream.ReferencePipeline$7$1.accept(ReferencePipeline.java:270) [?:?]
at java.util.concurrent.ConcurrentHashMap$ValueSpliterator.forEachRemaining(ConcurrentHashMap.java:3566) [?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481) [?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471) [?:?]
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:151) [?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:174) [?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) [?:?]
at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:418) [?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.handleEvent(CommunicationManager.java:298) [101:org.eclipse.smarthome.core.thing:0.10.0.201806141343]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.receiveCommand(CommunicationManager.java:253) [101:org.eclipse.smarthome.core.thing:0.10.0.201806141343]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.receive(CommunicationManager.java:135) [101:org.eclipse.smarthome.core.thing:0.10.0.201806141343]
at sun.reflect.GeneratedMethodAccessor16.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [94:org.eclipse.smarthome.core:0.10.0.201806141343]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [94:org.eclipse.smarthome.core:0.10.0.201806141343]
17:43:06.285 [INFO ] [smarthome.event.ItemStateChangedEvent] - EG_Licht_Flur_2 changed from OFF to ON
17:43:06.390 [ERROR] [ome.core.internal.events.EventHandler] - Dispatching/filtering event for subscriber 'org.eclipse.smarthome.core.events.EventSubscriber' failed: null
17:43:06.444 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'EventSubscriber.receive()' on 'org.eclipse.smarthome.core.thing.internal.CommunicationManager@1aa6f3f': null
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.lambda$4(CommunicationManager.java:268) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.receiveUpdate(CommunicationManager.java:268) [101:org.eclipse.smarthome.core.thing:0.10.0.201806141343]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.receive(CommunicationManager.java:133) [101:org.eclipse.smarthome.core.thing:0.10.0.201806141343]
17:43:06.493 [ERROR] [ome.core.internal.events.EventHandler] - Dispatching/filtering event for subscriber 'org.eclipse.smarthome.core.events.EventSubscriber' failed: null
Best regards,
Alex
