I have a problem after a upgrade from openhab 2.4 to openhab 2.5.1 rc1.
The installation/update to 25.1 will be done without errors.
But after a reboot the ip:8080 will bring a 500 server error /start/index
Cache ist clear and that the output…
Has anybody any idea?
Thx, markus
HTTP ERROR 500
Problem accessing /start/index. Reason:
Server Error
Caused by:
java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Long
at org.apache.felix.cm.impl.ConfigurationImpl.configure(ConfigurationImpl.java:659)
at org.apache.felix.cm.impl.ConfigurationImpl.configureFromPersistence(ConfigurationImpl.java:619)
at org.apache.felix.cm.impl.ConfigurationImpl.(ConfigurationImpl.java:194)
at org.apache.felix.cm.impl.ConfigurationManager.getConfiguration(ConfigurationManager.java:466)
at org.apache.felix.cm.impl.ConfigurationAdminImpl.getConfiguration(ConfigurationAdminImpl.java:164)
at org.openhab.ui.dashboard.internal.DashboardServlet.getPackage(DashboardServlet.java:196)
at org.openhab.ui.dashboard.internal.DashboardServlet.isSetup(DashboardServlet.java:191)
at org.openhab.ui.dashboard.internal.DashboardServlet.doGet(DashboardServlet.java:83)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)
at org.eclipse.jetty.server.Server.handle(Server.java:494)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918)
at java.lang.Thread.run(Thread.java:748)
