Openhab 2.5.11 zwave stopped sending commands
I use several zwave devices (TRVs and two smart plugs) for about a year without much issues.
However since one of the reboots I was not able to control devices (reports still come in).
When I send the commands I see:
avk@hab:/var/log/openhab2$ grep -a NODE\ 2 openhab.log
2021-05-25 19:13:44.167 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Command received zwave:device:0ffb7110:node2:switch_binary --> OFF [OnOffType]
2021-05-25 19:13:44.170 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 2: Command class class COMMAND_CLASS_SWITCH_BINARY for endpoint 0 not found
2021-05-25 19:13:44.172 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: No messages returned from converter
2021-05-25 19:13:49.037 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Command received zwave:device:0ffb7110:node2:switch_binary --> ON [OnOffType]
2021-05-25 19:13:49.040 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 2: Command class class COMMAND_CLASS_SWITCH_BINARY for endpoint 0 not found
2021-05-25 19:13:49.044 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: No messages returned from converter
Also there is an exception:
2021-05-23 20:16:41.873 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 11: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@a71c0c
        at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.processTransaction(ZWaveNodeInitStageAdvancer.java:291) [bundleFile:?]
        at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.processTransaction(ZWaveNodeInitStageAdvancer.java:264) [bundleFile:?]
        at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.doInitialStages(ZWaveNodeInitStageAdvancer.java:442) [bundleFile:?]
        at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.access$6(ZWaveNodeInitStageAdvancer.java:373) [bundleFile:?]
        at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer$1.run(ZWaveNodeInitStageAdvancer.java:188) [bundleFile:?]
        at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.processTransaction(ZWaveNodeInitStageAdvancer.java:289) [bundleFile:?]
        at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.doInitialStages(ZWaveNodeInitStageAdvancer.java:434) [bundleFile:?]
2021-05-25 18:52:20.176 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling initialised at 86400 seconds - start in 1500 milliseconds.
2021-05-25 18:52:21.678 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling deferred until initialisation complete
Any ideas what can cause it?
I’ve tried clearing caches and rebooting the RPi.
your code goes here
Only your system knows. Filtered logs are not useful for troubleshooting. While waiting for the developer, perhaps the log viewer can shed some light.
I would consider if the binding maybe auto-updated. Check bundle versions.
Binding updates may break existing Things e.g.if a channel type changes.
That’s almost certainly forced updates now.
But take care now - the remote repository for OH2 has moved, stuff that used to download by itself will not any longer.
Possibly there is some corruption in the data stored in the system. I would suggest to reinitialise the devices - there is an option for this in the parameters section of each thing - set this to true and save the configuration. This should cause the binding to download all the data about the device again as this seems to now be broken.
When I had weird zwave problems and I could not point them to a specific node, I removed the Zwave dongle waited a few minutes and then reinserted it. All with no reboot. It re-initialized all devices again and errors were gone. Try it.
Fixed by power cycling openhab with the zwave stick. It’s quite a lot since I’ve fixed anything by powercycling.
