- Platform information:
- Hardware: Intel NUC I7
- OS: windows 10
- Java Runtime Environment: JAVA_VERSION=“11.0.7” JDK11
- openHAB version: 2.5.6
Openhab does not start as a service.
log in userdata/bin/wrapper:
WARN | wrapper | 2020/07/05 06:25:24 | Unable to expand environment variable, PATH as it would be longer than the 16384 byte buffer size.
log in userdata/logs/wrapper:
STATUS | wrapper | 2020/07/05 06:25:24 | --> Wrapper Started as Service
STATUS | wrapper | 2020/07/05 06:25:25 | Launching a JVM...
INFO | jvm 1 | 2020/07/05 06:25:25 | -Djava.endorsed.dirs=C:\Program Files\Java\jdk11\jre\lib\endorsed;C:\Program Files\Java\jdk11\lib\endorsed;C:\openHAB2\runtime\lib\endorsed is not supported. Endorsed standards and standalone APIs
INFO | jvm 1 | 2020/07/05 06:25:25 | in modular form will be supported via the concept of upgradeable modules.
INFO | jvm 1 | 2020/07/05 06:25:25 | Error: Could not create the Java Virtual Machine.
INFO | jvm 1 | 2020/07/05 06:25:25 | Error: A fatal exception has occurred. Program will exit.
ERROR | wrapper | 2020/07/05 06:25:25 | JVM exited while loading the application.
STATUS | wrapper | 2020/07/05 06:25:29 | Launching a JVM...
INFO | jvm 2 | 2020/07/05 06:25:30 | -Djava.endorsed.dirs=C:\Program Files\Java\jdk11\jre\lib\endorsed;C:\Program Files\Java\jdk11\lib\endorsed;C:\openHAB2\runtime\lib\endorsed is not supported. Endorsed standards and standalone APIs
INFO | jvm 2 | 2020/07/05 06:25:30 | in modular form will be supported via the concept of upgradeable modules.
INFO | jvm 2 | 2020/07/05 06:25:30 | Error: Could not create the Java Virtual Machine.
INFO | jvm 2 | 2020/07/05 06:25:30 | Error: A fatal exception has occurred. Program will exit.
ERROR | wrapper | 2020/07/05 06:25:30 | JVM exited while loading the application.
STATUS | wrapper | 2020/07/05 06:25:34 | Launching a JVM...
INFO | jvm 3 | 2020/07/05 06:25:34 | -Djava.endorsed.dirs=C:\Program Files\Java\jdk11\jre\lib\endorsed;C:\Program Files\Java\jdk11\lib\endorsed;C:\openHAB2\runtime\lib\endorsed is not supported. Endorsed standards and standalone APIs
INFO | jvm 3 | 2020/07/05 06:25:34 | in modular form will be supported via the concept of upgradeable modules.
INFO | jvm 3 | 2020/07/05 06:25:34 | Error: Could not create the Java Virtual Machine.
INFO | jvm 3 | 2020/07/05 06:25:34 | Error: A fatal exception has occurred. Program will exit.
ERROR | wrapper | 2020/07/05 06:25:34 | JVM exited while loading the application.
STATUS | wrapper | 2020/07/05 06:25:39 | Launching a JVM...
INFO | jvm 4 | 2020/07/05 06:25:39 | -Djava.endorsed.dirs=C:\Program Files\Java\jdk11\jre\lib\endorsed;C:\Program Files\Java\jdk11\lib\endorsed;C:\openHAB2\runtime\lib\endorsed is not supported. Endorsed standards and standalone APIs
INFO | jvm 4 | 2020/07/05 06:25:39 | in modular form will be supported via the concept of upgradeable modules.
INFO | jvm 4 | 2020/07/05 06:25:39 | Error: Could not create the Java Virtual Machine.
INFO | jvm 4 | 2020/07/05 06:25:39 | Error: A fatal exception has occurred. Program will exit.
ERROR | wrapper | 2020/07/05 06:25:39 | JVM exited while loading the application.
STATUS | wrapper | 2020/07/05 06:25:44 | Launching a JVM...
INFO | jvm 5 | 2020/07/05 06:25:44 | -Djava.endorsed.dirs=C:\Program Files\Java\jdk11\jre\lib\endorsed;C:\Program Files\Java\jdk11\lib\endorsed;C:\openHAB2\runtime\lib\endorsed is not supported. Endorsed standards and standalone APIs
INFO | jvm 5 | 2020/07/05 06:25:44 | in modular form will be supported via the concept of upgradeable modules.
INFO | jvm 5 | 2020/07/05 06:25:44 | Error: Could not create the Java Virtual Machine.
INFO | jvm 5 | 2020/07/05 06:25:44 | Error: A fatal exception has occurred. Program will exit.
ERROR | wrapper | 2020/07/05 06:25:44 | JVM exited while loading the application.
FATAL | wrapper | 2020/07/05 06:25:44 | There were 5 failed launches in a row, each lasting less than 300 seconds. Giving up.
FATAL | wrapper | 2020/07/05 06:25:44 | There may be a configuration problem: please check the logs.
STATUS | wrapper | 2020/07/05 06:25:44 | <-- Wrapper Stopped
I have same error when I try to start Openhab3 as a service in same Java enviroment.
If I comment out:
wrapper.java.additional.8=-Djava.endorsed.dirs="%JAVA_HOME%\jre\lib\endorsed;%JAVA_HOME%\lib\endorsed;%KARAF_HOME%\lib\endorsed"
in openHAB2-wrapper.conf then service starts but Openhab will not work.
I think problem is wrapper config in Java 11 enviroment.
