I have installed openhabian on an Raspberry 2:
openHAB 2.5.7-1 (Release Build)
There is an USB 300 EnOcean Dongle online - working.
I try to add two different physical devices:
Window contact: Eltako FTK
Rocker Eltako FT55
My former OpenHAB 1.8 installation was working, here my item configuration (examples):
Contact Bedroom_Contact “Fenster Schlafzimmer” (groupGF_Bedroom,Windows) {enocean="{id=01:9A:A9:92, eep=D5:00:01, parameter=CONTACT_STATE}"}
Added enocean.cfg in …/openhab2/services with serialPort=/dev/ttyUSB0
in PaperUI: Added thing Enocean USB300 Dongle (online)
Tried a lot adding things/channels/items in PaperUI. All things “online”
I do not get any events from the devices (items)
Logfile (Level=DEBUG):
2020-08-19 10:22:43.371 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG RPS for FEFA2E06 payload F670FEFA2E063101FFFFFFFF2D00 received
2020-08-19 10:22:43.695 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG RPS for FEFA2E06 payload F600FEFA2E062101FFFFFFFF2D00 received
2020-08-19 10:22:52.423 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG _1BS for 019F6FB6 payload D509019F6FB60001FFFFFFFF5B00 received
The first two entries come from pushing the Rocker.
The last entry comes from a Window contact.
What is the best way to add/configure EnOcean things (PaperUI or files)?
What made I wrong? How can I add devices?
Do you have examples for my devices or hints for documentation?
Contact Window_Bureau_Andreas "Fenster Büro Andreas [MAP(de.map):%s]" <contact> (gWindows,gBureauAndreas) {channel="enocean:contact:FFE83500:TH_Window_Bureau_Andreas:contact"}
No entry for rockerSwitch!
In a rule we can use the Channel of a rockerSwitch directly:
rule "Test Schalter Down"
Channel 'enocean:rockerSwitch:FFE83500:TH_Button_Alarm:rockerswitchA' triggered DIR2_PRESSED
sendCommand(Kitchen_Switch_Light, ON)
Give some time for window contacts (solar powered) because they need up to 30 minutes to initialize!
You could bind the rocker channel to an item, depending on if you eg. want to visualize the state or trigger rules then on an update on that item.
But triggering on a channel directly from a rule is of course perfectly fine.
