I mentioned in my post above “I will provide a couple of further infos on how to proceed with 2.x” - there will be a way to make add-on fixes available to existing 2.5 users, so please be patient for a few more days!
Cool, thanks!
Thank you to all contributors!
My update worked perfectly!
I’ve just updated and 24 hours in everything seems to be worked perfectly. Thanks very much, you achieved what a lot of the major software companies can’t!
Done, see here.
I’ve had OpenHABian 2.4 running on a PI3 for few weeks now. I do not yet see a 2.5 version. Is it in the works?
Did you try the update function of openhabian-config? Should be selection no 3.
Although I can’t say in what way you expect to “see” the update. Blog-post on openhab.org, announcement in this forum…
BTW You are most probably running openHAB 2.4 on an openhabian installation, the version numbers for openhabian are different!
openHABian OS & script numbers re different but OH version numbers when using openHABian are the same.
If you are using the Stable repo, 2.5 is definitely there. Does sudo apt-get update give any errors? There were some changes in repo keys several months ago.
The Paper UI is not recommended for daily control anyway. It will not be a UI on OH3 as far as I know.
Ok! Thanks! I now. I use it just in debug purpose.
Thanks.i will try in another browser.
Thanks all contributors for this update.
After remove org.openhab.binding.amazonechocontrol_2.5.0.RC_3.jar from addons directory and reboot everything works fine, including Z-Wave, Zigbee devices and MQTT
Here my system:
Raspberry Pi 3 Model B Plus Rev 1.3
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
VERSION_CODENAME=stretch
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
nano ~/.profile
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
d9f5dc16cc6a openhab/openhab:latest "/entrypoint.sh gosu…" 2 hours ago Up 2 hours docker_openhab_1
66df760487a8 jsurf/rpi-mariadb "docker-entrypoint.s…" 2 hours ago Up 2 hours 0.0.0.0:3306->3306/tcp docker_mariadb_1
4b58e71c0a4a arm32v6/eclipse-mosquitto "/docker-entrypoint.…" 2 hours ago Up 2 hours 0.0.0.0:1883->1883/tcp, 0.0.0.0:8883->8883/tcp, 0.0.0.0:9001->9001/tcp docker_mosquitto_1
9a0d7502e953 koenkk/zigbee2mqtt:latest "./run.sh" 2 hours ago Up 2 hours docker_zigbee2mqtt_1
dash-mqtt-bridge.service
Active: active (running) since Sat 2020-02-08 11:52:45 CET; 2h 3min ago
frontail_log.service
frontail_oh.service
Active: active (running) since Sat 2020-02-08 11:53:02 CET; 2h 3min ago
frontail_mos_log.service
docker-compose version 1.24.1, build 4667896
Docker version 19.03.5, build 633a0ea
