All,
We have just released openHAB 2.5.3. It again contains quite some fixes for existing add-ons - please check out the release notes for details!
Regards,
Kai
All,
Regards,
Kai
Hi Kai,
For Zwave, the release notes seem to be incorrect. At least Zwave issue 1311 was already confirmed fixed in 2.5.2.
I guess it was incorrectly tagged - this is not a general problem as each issue is tagged separately.
OH 2.5.3 isnāt offered on openhabian,
I did :
sudo apt-get update
sudo apt-get upgrade
Maybe the repos arenāt up to date?
Any idea how I can get the update?
You could switch to snapshot in openHABian, it has 2.5.3. Or wait until it got propagated to the release repo.
OK, thanks for the info. Iāll wait until the repos are up to dateā¦
Will provide feedback
Hi Kai,
https://github.com/openhab/openhab-addons/pull/7180 seems to be missing for nanoleaf (even though you tagged it for 2.5.3)
cheers
Stefan
Unfortunately the selection of platforms and packages on the download page (https://www.openhab.org/download/) is not functional at the moment. It is only possible to download the stable 2.5.3 APT package for Linux, all other options are not selectable:
OH 2.5.3 was offered in openhabian, update done.
Had to restart twice, as a lot of items (which are created in .items files) wasnāt recognized after first restart.
After second restart everything looks fine
This appears to be the direct Windows link.
For the benefit of others, it took about 12 hours for the 2.5.3 release to propagate through the repos and become available in Raspbian / openHABian.
The upgrade in openHABian is simple, and available directly under menu option 03 | openHAB Stable
, but I used the following commands to check the version available from the repos before running the tool:
# update and list available software from the repos
sudo apt-get update
sudo apt list --upgradable
# when you see the release you want is available...
sudo openhabian-config
# select 03 | openHAB Stable
openHAB 2.5.3-1 (Release Build)
is working well for me on a RPi 4.
Some previous intermediate releases were only available in openHABian option 41 | openHAB testing
, which was a little more complex to confirm.
Hope this helps,
James
And not always expected to work properly. Do not use for your production system. If you use it, report issues on GitHub.
when I do the sudo apt list --upgradable
I see
[17:19:51] openhabian@openhab:~$ apt list --upgradable
Listingā¦ Done
binutils-arm-linux-gnueabihf/stable 2.31.1-16+rpi2 armhf [upgradable from: 2.31.1-16+rpi1]
binutils-common/stable 2.31.1-16+rpi2 armhf [upgradable from: 2.31.1-16+rpi1]
binutils/stable 2.31.1-16+rpi2 armhf [upgradable from: 2.31.1-16+rpi1]
libbinutils/stable 2.31.1-16+rpi2 armhf [upgradable from: 2.31.1-16+rpi1]
rpi-eeprom-images/testing 5.2-1 all [upgradable from: 5.1-1]
rpi-eeprom/testing 5.2-1 armhf [upgradable from: 4.0-1]
Then start sudo openhabian-config and select option 03
nothing is done
when I do the sudo apt list --upgradable again,
i get the same list
Iām not a linux guy,so, donāt shoot me
Do you have the Stable repo selected in openhabian-config
Thatās pretty much what I saw after upgrading using openhabian-config
option 03. This sets your repo (the source of updated packages) to Stable, then updates the openHAB packages all automagically for you without needing the command line.
For the inquisitive, the update tool is reporting the base OS packages which have later versions available, but are being held back by the base OS (not under the control of openHAB nor openHABian).
No, I donāt know why, and doubt it matters much for openHAB, but if you really want to you can manually upgrade the individual packages one-by-one (e.g. sudo apt-get upgrade rpi-eeprom; sudo apt list --upgradable
, repeat). This greybeard sysadmin did risk the updates - but then, I do have hardware and software BACKUPS !
As weāre specifically upgrading openHAB, the question is what is the version installed, and the version available. Hereās the command, and my output (from an upgraded RPi4):
$ apt search openhab2
Sorting... Done
Full Text Search... Done
openhab2/stable,now 2.5.3-1 all [installed]
openhab2
openhab2-addons/stable 2.5.3-1 all
openhab2-addons
openhab2-addons-legacy/stable 2.5.3-1 all
Notice the version number, and stable release.
If youāve ever ventured beyond options 02 and 03 into Testing or Unstable releases (option 41), then running openhabian-config
option 03 changes your repo back to Stable. (Hint - read the bash script source in /opt/openhabian/functions
You shouldnāt need to double which repo is active (just select 03 and 02), but for completeness, hereās my output on Stable:
$ cat /etc/apt/sources.list.d/openhab2.list
deb https://dl.bintray.com/openhab/apt-repo2 stable main
openHABian makes use of the Debian apt mechanism. It does not really do anything specific other than to call that.
Option 03 runs apt-get upgrade
while to upgrade āeverything including the rest you sawā you would need to issue apt-get dist-upgrade
. That you can always manually do in the CLI.
Hereās an explanation on the difference.
Wondering whether we should change that in openHABian ā¦ @Benjy wdyt?
Ack - dist-upgrade
rather than upgrade
- good shout!
I always forget about the distinction. I blame too many years of SunOS/ Solaris, Red Hat and Fedora.
The rpi-eeprom
upgrade was the one that made me manually upgrade as thereās been lots of optimisation for the RPi4 power/ performance, and work on HDD / SSD boot without a uSD.
Over time, perhaps as well as sudo apt dist-upgrade
perhaps sudo apt autoremove
may be an advantage.
Iāve been using:
sudo apt-get --with-new-pkgs upgrade
Though I used to use the dist-upgrade and never had a problem with itā¦
In general, I wouldnāt recommend doing a dist-upgrade
through a script as a default update action, especially if the function is hidden from users new to Linux. It could be offered as a different option with the relevant warnings though. Or use one of the more cautious commands as @jswim788 describes.
yes.
