After using openhab 1 for quite some time I started to give OH2 a try today. I have to say it looks quite promising
There is one thing which is not clear to me yet. How to configute the zwave interface ?
I installed the zwave binding, have a z-stick2 which shows up on com3 (Windows 10) but I did not find any configuration option for the serial port.
I also checked the OH log files and could not find any attempt for the zwave binding to load/start neither an attempt to open a serial port.
Thanks for the info. I did not see my zwave USB stick and was looking for the serial port configuration under bindings.
I also did not see the zwave stick in things, found out that I was able to add it and then configure the port. Was not so obvious for me, but it works now.
