I try the Kodi Binding and everything works perfect.
Except the Kodi state for "Stop"
My rule knows the state “Play” & “Pause” but the state “Stop” doesnt work (it takes my rule for “Pause”).
My rule:
rule "Adjust living room lighting when XBMC starts/stops"
Item KodiKeller_Kontrolle changed
var String stateKino = KodiKeller_Kontrolle.state.toString()
if (Xbmc_Kino_EA.state == ON){
switch (stateKino.lowerCase) {
case "play" : {
Kino_ColorGroup1_Brightness.sendCommand(0)
Kino_ColorGroup2_Brightness.sendCommand(0)
Kino_ColorGroup3_Brightness.sendCommand(0)
Kino_ColorGroup4_Brightness.sendCommand(0)
case "pause" : {
Kino_ColorGroup1_Brightness.sendCommand(50)
Kino_ColorGroup2_Brightness.sendCommand(50)
Kino_ColorGroup3_Brightness.sendCommand(50)
Kino_ColorGroup4_Brightness.sendCommand(50)
case "stop" : {
callScript("langzeitdimmer_kino")
As a workaround: I solved this with the Script plugin on Kodi side. My Kodi issues MQTT commands on states. This is probably a little more complicated, but on the other hand, you have much more access to Kodi.
1 to find this out as well - as a test I have the state showing in my sitemap and it never shows stop, only play and pause (in caps as well - yuck)
Also noticed that the showtitle channel does not clear - always shows the last one played.
I guess the above comment about the smarthome comment also explaings why the player control doesnt have a stop button - wonder why this is the case I cant see why a basic media function like stop isnt included?
Have the same issue, play, pause works fine, but the stop channel doesn’t update if I stops from my Kodi remote. I have no idea why the stop has its own channel btw, why not put it in control like the rest?
rule "Kodi stopped or playing"
Item myKodiMediaType changed
if (myKodiMediaType.state == "") {
logInfo('Kodi','Kodi has stopped')
} else if (myKodiMediaType.state != null) {
logInfo('Kodi','kodi is playing something')
Edit: But I do agree that it makes little sense not to have a “STOP” state for the Player item
E1Lachter1_Dimmer.sendCommand(100) // Kodi has stopped playing
E1Lachter1_Dimmer.sendCommand(0) // Kodi is playing
The media player control was not changed but the Kodi bindings contains now a separate stop channel. Don’t remember when it was introduced but the current snapshot builds contains this channel
The stop channel doesn’t work properly for me. I can stop playback by sending ON to the stop channel. But when I stop playback in kodi directly, the channel doesn’t update in OH2.
Also nothing in the event log, I see that player, title and type for example change, but stop does not.
How can I check, which version of the addon I’m using? I tried via the karaf console, feature:list | grep kodi: openhab-binding-kodi | 2.0.0 | x | Started | addons-2.0.0 | Kodi Binding
But in Paper UI under Control, I see that Kodi has a Stop switch so I assume it is supported?
