rlkoshak
(Rich Koshak)
January 19, 2018, 5:28pm
21
https://docs.openhab.org/administration/logging.html#create-log-entries-in-rules
Log out everything. What is the name of the Item that gets set to motionLatest? What is the name of the Item that gets set to doorwindowLatest? What is their lastUpdate? What is the lastUpdate for ALL the Items in both groups?
hello
i added loggin but still i see the same thing in the logs
2018-01-19 19:35:03.840 [INFO ] [home.model.script.MotionUpdate.rules] - Checking Last Motion Detection !
2018-01-19 19:35:03.846 [INFO ] [home.model.script.MotionUpdate.rules] - Lastmotiondetector intrusion state ON
2018-01-19 19:35:03.853 [INFO ] [home.model.script.MotionUpdate.rules] - Lastdoorwindow intrusion state CLOSED
2018-01-19 19:35:03.858 [INFO ] [home.model.script.MotionUpdate.rules] - Lastest intrusion state CLOSED
2018-01-19 19:35:03.864 [INFO ] [home.model.script.MotionUpdate.rules] - DoorWindowsSensor Garage Intrusion!, CLOSED
current rule:
rule "Process Intrusion Updates"
Item gMotionAlarms changed from OFF to ON or
Item DoorsWindows changed from OFF to ON
Thread::sleep(300)
logInfo("MotionUpdate.rules", "Checking Last Motion Detection !")
//val motionLatest = gMotionAlarms.members.sortBy[lastUpdate].last
val motionLatest = gMotionAlarms.members.filter[a | a.lastUpdate !== null].sortBy[lastUpdate].last
logInfo("MotionUpdate.rules", "Lastmotiondetector intrusion state" + " " + motionLatest.state.toString)
val doorwindowLatest = DoorsWindows.members.sortBy[lastUpdate].last
logInfo("MotionUpdate.rules", "Lastdoorwindow intrusion state" + " " + doorwindowLatest.state.toString)
val latest = if(motionLatest.lastUpdate.isAfter(doorwindowLatest.lastUpdate)) motionLatest else doorwindowLatest
logInfo("MotionUpdate.rules", "Lastest intrusion state" + " " + latest.state.toString)
val name = latest.name.split("_")
LastMotionDetection.postUpdate("" + name.get(1) + " " + name.get(2) + " Intrusion!, " + latest.state.toString)
logInfo("MotionUpdate.rules", LastMotionDetection.state.toString)
rlkoshak
(Rich Koshak)
January 19, 2018, 6:45pm
23
I don’t care what the state is. We need to know what Item it is.
motionLatest.name
job
(Joachim Boeddeker)
January 19, 2018, 7:18pm
24
I have a different approach. Instead of browsing through persistence, use the triggeringItem.
String lastMotion "Last motion [%s]"
rule "contact check"
Item DOOR_STATE changed from OPEN to CLOSED or
Item DOOR_STATE changed from CLOSED to OPEN or
Item MOTION_STATE changed from ON to OFF or
Item MOTION_STATE changed from OFF to ON
/// put all your watched items and state changes in the conditions block
val String msg = triggeringItem.name
lastMotion.postUpdate(msg)
logInfo("motion", msg)
I use that msg, device name and state:
val String msg = String::format("%s %s", triggeringItem.name.split("_").get(0), triggeringItem.state.toString)
Excuse me, if i did miss the point.
problem is solved by setting the group for the door/windows correctly
it was set to a switch while it should be a contact.
changed the group to:
Group:Contact:OR(OPEN,CLOSED) DoorsWindows
adjusted the rule:
Item DoorsWindows changed from CLOSED to OPEN
Thread::sleep(300)
logInfo("MotionUpdate.rules", "Lastmotiondetector intrusion state" + " " + motionLatest.name.toString)
val doorwindowLatest = DoorsWindows.members.filter[b | b.lastUpdate !== NULL].sortBy[lastUpdate].last
