Hallo, I am new here. I am working with Openhab 2 on a raspberry 3, openhasbian and the Razberry board. This is a new installation and at first I installed the Z-Wave Binding. After the setting of the Port Configuration to /dev/ttyAMA0 the Controller runs. Now I want to add Door Sensors from D-Link DCH-Z110. One by one i started two Sensors. When I am searching for things the system found 6 entries Node 3 to Node 8. I think, this is a 3-1 Sensor and every sensor has a entry.
What can I do so the Binding found the correct sensor?
