The configured device ‘800693CA8296784C8309794477EF333F1DC5A1C9’ doesn’t match with the id the device reports: ‘8006176036D56D252898E7BD1326BE411DAC2018’.
Is there anyway to fix this?
Thanks!
Thanks!
I think you should provide a more detailed description of you system and the problem
Hi brianlay, thanks for your suggestion. I think you are right - fortunately I have found the root cause of my problem - the configuration got broken due that I have added another network interface and that broke the whole system - I need to configure that network interface to use routing correctly.
I think we can close this issue.
