OK people, I have searched until I am frustrated. I upgraded my openHAB instance that is essentially a text to speech and backup alarm clock to openHAB 3 today.
I can’t figure out how to get my old “var clockhour = now.getHourOfDay” converted to javatime.
Help please and thanks. This compares to a Number of DecimalType.
You will have to be more precise. Is it all inbox entries or only the ones from a particular binding. Are your things defined in config files or with UI?
Just to mention that it still works as before in my case.
People, please stay on topic and only post here if your issue of general interest and specific to 3.0RC.
If you continue the way you did, this will invalidate usefulness of this thread to identify bugs in the RC to get them fixed in time.
Thank you for your cooperation.
In RC1 I have multiple entries “enabled CORS for REST API” in the openhab.log during startup/stop of openhab. I know, these are only INFO messages, but are they related to any binding/thing or do they appear also multiple times in a clean install ?
log (I shortened the *.items, *.things & *.sitemap entries)
2020-12-19 09:22:39.092 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Zurich'.
2020-12-19 09:22:39.099 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '47.6133925548962,8.731502294540407'.
2020-12-19 09:22:39.101 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'de_CH'.
2020-12-19 09:22:42.075 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.079 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.102 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.195 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.216 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.306 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.330 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.348 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.382 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.411 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.465 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.489 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.514 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.549 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.586 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.625 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.678 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.719 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.804 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:42.885 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:44.247 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'xxxxxxx¨.items'
2020-12-19 09:22:48.332 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'xxxxxx.sitemap'
2020-12-19 09:22:48.604 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'xxxxxx.things'
2020-12-19 09:22:48.710 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:49.020 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:49.189 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:50.315 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-12-19 09:22:50.492 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'startup.rules'
2020-12-19 09:22:52.757 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:52.942 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:53.006 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:53.137 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:53.256 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:53.334 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:53.570 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:53.846 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:54.004 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:54.120 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
2020-12-19 09:22:54.289 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8082
2020-12-19 09:22:54.425 [INFO ] [.internal.servlet.HomeConnectServlet] - Initialize log viewer servlet (/homeconnect)
2020-12-19 09:22:56.225 [INFO ] [o.internal.handler.AstroThingHandler] - Scheduled Positional job astro:sun:local every 300 seconds
2020-12-19 09:22:56.697 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
When i filter in the items tab and click on one item the new view is opened. When i go back the filter is still set but the filter result isn’t correct anymore.
Updated from RC1 to RC2 with the command sudo runtime/bin/update 3.0.0.RC2, removed all log files and then started openHAB. The events.log file remained empty until I stopped and restarted openHAB again.
Not sure of this in RC issue or was always there. But during my testing (OH3.0.0.RC1 on Docker) I found that it is not possible to create a player channel with the http binding.
According to the docs of the binding there is a player channel type available
But the player option is not available in MainUI when creating channel:
Manual configuration in the code tab as YAML also doesn’t work… the lines for the player channel are just deleted.
