[Openhab-3.1.0M] KNX Item feedbacks doesn`t work propertly
Making everything in web UI without textual item files
When I add FB
+<2/1/1
to control ga:
2/0/1
It starts to switch on/off repeatedly and if I set autoupdate off then no control is possible
I am using this as tutorial:
Why did you choose switch-control type for an actor? It’s intended for a control panel type.
