openHAB 3.1.1: Massive network latency caused by mDNS Service (Bundle 188)?
Hi all,
I’m running openHAB 3.1.1 on a Raspberry Pi (openHABian, Raspbian Buster) and recently experienced a very strange issue.
Symptoms
  • Network became extremely slow after openHAB startup.
  • Ping from LAN clients to my UniFi gateway increased from <1 ms to 800–1300 ms.
  • Internet access became noticeably slow.
  • Stopping openHAB immediately restored normal network performance.
Troubleshooting
I initially suspected:
  • Raspberry Pi hardware
  • SD card corruption
  • Ethernet cable / switch port
  • Homematic binding
  • Hue binding
  • Amazon Echo Control binding
  • Rules
However:
  • Same behaviour occurred on two different Raspberry Pis.
  • Different cable and switch port made no difference.
  • Disabling Rules did not help.
  • Stopping Homematic did not help.
  • Stopping Hue did not help.
  • Stopping Amazon Echo Control did not help.
  • Stopping UPnP Discovery did not help.
Interesting findings
top -H showed the most active threads as:
  • SocketListener(…)
  • JmDNS(…)
The openHAB Java process consumed significant CPU time, and the activity seemed related to mDNS/JmDNS.
I then stopped the following bundles:
bundle:stop 166
bundle:stop 182
bundle:stop 188
where:
  • 166 = Configuration mDNS Discovery
  • 182 = REST mDNS Announcer
  • 188 = mDNS Service
After testing the bundles individually, the issue appears to be related specifically to:
188 = openHAB Core :: Bundles :: mDNS Service
When bundle 188 is stopped, network latency immediately returns to normal and remains stable.
Environment
  • openHAB 3.1.1
  • openHABian
  • Raspberry Pi
  • UniFi Cloud Gateway
  • Homematic
  • Hue
  • InfluxDB
  • Grafana
Questions
  1. Has anyone seen similar behaviour from the mDNS Service bundle?
  2. Are there known issues with JmDNS and UniFi networks?
  3. Could IPv6 or a recently updated network device trigger such behaviour even though the openHAB installation itself has not changed?
  4. Is this a known issue that has been fixed in newer openHAB releases?
Thanks!
openHAB 3.1 is 5 years old and a lot of development has happened since then. I don’t think you’ll find many users on the community still running it and being able to help you.
Have you tried spinning up a fresh openHAB 5.1 installation besides your 3.1 installation to test whether 5.1 causes the same issue?
