Hi, i get an error at openHAB start after i upgrade to openHAB 3.1.0 on a windows 10 64bit PC.
I even tried to install it on a new folder and to uninstall and install Zulu JDK updated version, without success.
Old openHAB 3.0.0 version works well.
Here the error i get:
Error executing command: java.nio.charset.MalformedInputException: Input length = 1
java.lang.IllegalStateException: BundleContext is no longer valid org.apache.karaf.features.core_4.3.2 [18]
at org.eclipse.osgi.internal.framework.BundleContextImpl.checkValid(BundleContextImpl.java:1027)*
at org.eclipse.osgi.internal.framework.BundleContextImpl.installBundle(BundleContextImpl.java:180)*
at org.eclipse.equinox.internal.region.BundleIdBasedRegion.installBundle0(BundleIdBasedRegion.java:117)*
at org.eclipse.equinox.internal.region.BundleIdBasedRegion.installBundleAtLocation(BundleIdBasedRegion.java:97)*
at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.installBundle(BundleInstallSupportImpl.java:135)*
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.installBundle(FeaturesServiceImpl.java:1145)*
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:906)*
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069)*
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004)*
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)*
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)*
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)*
at java.base/java.lang.Thread.run(Thread.java:829)*
Thank you in advance for any help
