thank you.
i did manage to edit the config for log level maximum but i cannot find the file boot/first-boot.log …
i do find the boot folder but there is no such file.
maybe i am looking at the wrong folder?
i will remember to not clear the cache in the future.
This is what openhabian-cli returned after turning on log-maximum:
openhabian@openhabian:~$ sudo openhabian-config
2021-09-23_22:30:56_CEST [openHABian] Checking for root privileges... OK
+ export UNATTENDED SILENT DEBUGMAX INTERACTIVE
+ for shfile in "${BASEDIR:-/opt/openhabian}"/functions/*.bash
+ source /opt/openhabian/functions/auth.bash
+ source /opt/openhabian/functions/backup.bash
+ source /opt/openhabian/functions/config.bash
+ source /opt/openhabian/functions/ext-storage.bash
+ source /opt/openhabian/functions/find.bash
+ source /opt/openhabian/functions/habapp.bash
+ source /opt/openhabian/functions/helpers.bash
++ ESC='\033['
++ COL_DEF='\033[39;49;00m'
++ COL_RED='\033[31;01m'
++ COL_GREEN='\033[32;01m'
++ COL_YELLOW='\033[33;01m'
++ COL_BLUE='\033[34;01m'
++ COL_MAGENTA='\033[35;01m'
++ COL_CYAN='\033[36;01m'
++ COL_LGRAY='\033[37;01m'
++ COL_DGRAY='\033[90;01m'
++ export COL_DEF COL_RED COL_GREEN COL_YELLOW COL_BLUE COL_MAGENTA COL_CYAN COL_LGRAY COL_DGRAY
+ source /opt/openhabian/functions/influxdb+grafana.bash
+ source /opt/openhabian/functions/java-jre.bash
+ source /opt/openhabian/functions/menu.bash
+ source /opt/openhabian/functions/nodejs-apps.bash
+ source /opt/openhabian/functions/openhab.bash
+ source /opt/openhabian/functions/openhabian.bash
+ source /opt/openhabian/functions/packages.bash
+ source /opt/openhabian/functions/system.bash
+ source /opt/openhabian/functions/vpn.bash
+ source /opt/openhabian/functions/wifi.bash
+ source /opt/openhabian/functions/zram.bash
++ pwd
+ OLDWD=/home/openhabian
+ cd /opt
+ update_openhabian_conf
+ local configFile=/etc/openhabian.conf
+ local referenceConfig=/opt/openhabian/openhabian.conf.dist
+ cp /etc/openhabian.conf /etc/openhabian.conf.BAK
+ read -r line
+ [[ # Modify your openHABian settings =~ ^(#)?[a-zA-Z] ]]
+ echo '# Modify your openHABian settings'
+ read -r line
+ [[ # Handle with care, only touch if you need to!! =~ ^(#)?[a-zA-Z] ]]
+ echo '# Handle with care, only touch if you need to!!'
+ read -r line
+ [[ # This file will only be used on unattended initial install. =~ ^(#)?[a-zA-Z] ]]
+ echo '# This file will only be used on unattended initial install.'
+ read -r line
+ [[ # If you want to change anything after unattended install completed, use menu in openhabian-config. =~ ^(#)?[a-zA-Z] ]]
+ echo '# If you want to change anything after unattended install completed, use menu in openhabian-config.'
+ read -r line
+ [[ '' =~ ^(#)?[a-zA-Z] ]]
+ echo ''
+ read -r line
+ [[ # Hostname to set this one to =~ ^(#)?[a-zA-Z] ]]
+ echo '# Hostname to set this one to'
+ read -r line
+ [[ hostname=openhabian =~ ^(#)?[a-zA-Z] ]]
+ parsed=hostname=openhabian
+ [[ hostname=openhabian =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo hostname=openhabian
+ param=hostname
+ [[ -v hostname ]]
+ [[ openhabian == *\ * ]]
+ read -r line
+ [[ # if it exists, the default user (with its working environment) will be renamed to this username given here ... =~ ^(#)?[a-zA-Z] ]]
+ echo '# if it exists, the default user (with its working environment) will be renamed to this username given here ...'
+ read -r line
+ [[ username=openhabian =~ ^(#)?[a-zA-Z] ]]
+ parsed=username=openhabian
+ [[ username=openhabian =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo username=openhabian
+ param=username
+ [[ -v username ]]
+ read -r line
+ [[ # ... and given this password. The password will be removed from this file after completion for security reasons. =~ ^(#)?[a-zA-Z] ]]
+ echo '# ... and given this password. The password will be removed from this file after completion for security reasons.'
+ read -r line
+ [[ userpw=openhabian =~ ^(#)?[a-zA-Z] ]]
+ parsed=userpw=openhabian
+ [[ userpw=openhabian =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo userpw=openhabian
+ param=userpw
+ [[ -v userpw ]]
+ read -r line
+ [[ # set this to download a SSH key and authorize the owner to login as the admin user =~ ^(#)?[a-zA-Z] ]]
+ echo '# set this to download a SSH key and authorize the owner to login as the admin user'
+ read -r line
+ [[ adminkeyurl="" =~ ^(#)?[a-zA-Z] ]]
+ parsed='adminkeyurl=""'
+ [[ adminkeyurl="" =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo 'adminkeyurl=""'
+ param=adminkeyurl
+ [[ -v adminkeyurl ]]
+ echo adminkeyurl=
+ read -r line
+ echo ''
+ read -r line
+ [[ # Language and timezone. See Debian documentation for valid values. =~ ^(#)?[a-zA-Z] ]]
+ echo '# Language and timezone. See Debian documentation for valid values.'
+ read -r line
+ [[ timezone=Europe/Berlin =~ ^(#)?[a-zA-Z] ]]
+ parsed=timezone=Europe/Berlin
+ [[ timezone=Europe/Berlin =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo timezone=Europe/Berlin
+ param=timezone
+ [[ -v timezone ]]
+ [[ Europe/Berlin == *\ * ]]
+ read -r line
+ [[ locales="en_US.UTF-8 de_DE.UTF-8" =~ ^(#)?[a-zA-Z] ]]
+ parsed='locales="en_US.UTF-8 de_DE.UTF-8"'
+ [[ locales="en_US.UTF-8 de_DE.UTF-8" =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo 'locales="en_US.UTF-8 de_DE.UTF-8"'
+ param=locales
+ [[ -v locales ]]
+ [[ en_US.UTF-8 de_DE.UTF-8 == *\ * ]]
+ read -r line
+ [[ system_default_locale="en_US.UTF-8" =~ ^(#)?[a-zA-Z] ]]
+ parsed='system_default_locale="en_US.UTF-8"'
+ [[ system_default_locale="en_US.UTF-8" =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo 'system_default_locale="en_US.UTF-8"'
+ param=system_default_locale
+ [[ -v system_default_locale ]]
+ [[ en_US.UTF-8 == *\ * ]]
+ echo system_default_locale=en_US.UTF-8
+ read -r line
+ echo ''
+ read -r line
+ [[ # WiFi settings. An ethernet connection is recommended. =~ ^(#)?[a-zA-Z] ]]
+ echo '# WiFi settings. An ethernet connection is recommended.'
+ read -r line
+ [[ # If you have a RPi4, RPi3, RPi0W or a supported external WiFi dongle, the WiFi =~ ^(#)?[a-zA-Z] ]]
+ echo '# If you have a RPi4, RPi3, RPi0W or a supported external WiFi dongle, the WiFi'
+ read -r line
+ [[ # interface can be setup and used for the initial installation. =~ ^(#)?[a-zA-Z] ]]
+ echo '# interface can be setup and used for the initial installation.'
+ read -r line
+ [[ # Fill in your SSID and password below, leave empty or put comment in front to =~ ^(#)?[a-zA-Z] ]]
+ echo '# Fill in your SSID and password below, leave empty or put comment in front to'
+ read -r line
+ [[ # have your WiFi remain unchanged/uninitialized. Make sure your Ethernet works. =~ ^(#)?[a-zA-Z] ]]
+ echo '# have your WiFi remain unchanged/uninitialized. Make sure your Ethernet works.'
+ read -r line
+ [[ # ATTENTION: you need to escape these special characters: $, `, ", \, (newline) =~ ^(#)?[a-zA-Z] ]]
+ echo '# ATTENTION: you need to escape these special characters: $, `, ", \, (newline)'
+ read -r line
+ [[ # 'Escaping' means to put an additional \ in front of that character =~ ^(#)?[a-zA-Z] ]]
+ echo '# '\''Escaping'\'' means to put an additional \ in front of that character'
+ read -r line
+ [[ wifi_ssid="" =~ ^(#)?[a-zA-Z] ]]
+ parsed='wifi_ssid=""'
+ [[ wifi_ssid="" =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo 'wifi_ssid=""'
+ param=wifi_ssid
+ [[ -v wifi_ssid ]]
+ echo wifi_ssid=
+ read -r line
+ [[ wifi_password="" =~ ^(#)?[a-zA-Z] ]]
+ parsed='wifi_password=""'
+ [[ wifi_password="" =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo 'wifi_password=""'
+ param=wifi_password
+ [[ -v wifi_password ]]
+ echo wifi_password=
+ read -r line
+ echo ''
+ read -r line
+ [[ # Wi-Fi setting. Select a two-letter country code suitable for your location =~ ^(#)?[a-zA-Z] ]]
+ echo '# Wi-Fi setting. Select a two-letter country code suitable for your location'
+ read -r line
+ [[ # E.g. US (default), DE, AU, NZ... =~ ^(#)?[a-zA-Z] ]]
+ echo '# E.g. US (default), DE, AU, NZ...'
+ read -r line
+ [[ # You may infringe on local legislature otherwise =~ ^(#)?[a-zA-Z] ]]
+ echo '# You may infringe on local legislature otherwise'
+ read -r line
+ [[ # See https://en.wikipedia.org/wiki/ISO_3166-1_alpha-2 or /usr/share/zoneinfo/zone.tab =~ ^(#)?[a-zA-Z] ]]
+ echo '# See https://en.wikipedia.org/wiki/ISO_3166-1_alpha-2 or /usr/share/zoneinfo/zone.tab'
+ read -r line
+ [[ wifi_country="" =~ ^(#)?[a-zA-Z] ]]
+ parsed='wifi_country=""'
+ [[ wifi_country="" =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo 'wifi_country=""'
+ param=wifi_country
+ [[ -v wifi_country ]]
+ echo wifi_country=
+ read -r line
+ echo ''
+ read -r line
+ [[ # Eventually disable all IPv6 e.g. on installation problems =~ ^(#)?[a-zA-Z] ]]
+ echo '# Eventually disable all IPv6 e.g. on installation problems'
+ read -r line
+ [[ # values: "enable", "disable" =~ ^(#)?[a-zA-Z] ]]
+ echo '# values: "enable", "disable"'
+ read -r line
+ [[ ipv6=enable =~ ^(#)?[a-zA-Z] ]]
+ parsed=ipv6=enable
+ [[ ipv6=enable =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo ipv6=enable
+ param=ipv6
+ [[ -v ipv6 ]]
+ [[ enable == *\ * ]]
+ echo ipv6=enable
+ read -r line
+ echo ''
+ read -r line
+ [[ # repo and branch to clone from =~ ^(#)?[a-zA-Z] ]]
+ echo '# repo and branch to clone from'
+ read -r line
+ [[ repositoryurl=https://github.com/openhab/openhabian.git =~ ^(#)?[a-zA-Z] ]]
+ parsed=repositoryurl=https://github.com/openhab/openhabian.git
+ [[ repositoryurl=https://github.com/openhab/openhabian.git =~ ^#[a-zA-Z] ]]
++ echo repositoryurl=https://github.com/openhab/openhabian.git
++ cut -d= -f1
+ param=repositoryurl
+ [[ -v repositoryurl ]]
+ [[ https://github.com/openhab/openhabian.git == *\ * ]]
+ read -r line
+ [[ clonebranch=openHAB3 =~ ^(#)?[a-zA-Z] ]]
+ parsed=clonebranch=openHAB3
+ [[ clonebranch=openHAB3 =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo clonebranch=openHAB3
+ param=clonebranch
+ [[ -v clonebranch ]]
+ [[ openHAB3 == *\ * ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # debug verbosity mode =~ ^(#)?[a-zA-Z] ]]
+ echo '# debug verbosity mode'
+ read -r line
+ [[ # off, on (verbose output in log) or maximum (show every command) =~ ^(#)?[a-zA-Z] ]]
+ echo '# off, on (verbose output in log) or maximum (show every command)'
+ read -r line
+ [[ debugmode=off =~ ^(#)?[a-zA-Z] ]]
+ parsed=debugmode=off
+ [[ debugmode=off =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo debugmode=off
+ param=debugmode
+ [[ -v debugmode ]]
+ [[ maximum == *\ * ]]
+ echo debugmode=maximum
+ read -r line
+ echo ''
+ read -r line
+ [[ # fake hardware =~ ^(#)?[a-zA-Z] ]]
+ echo '# fake hardware'
+ read -r line
+ [[ # force treating your box as if it was a ... =~ ^(#)?[a-zA-Z] ]]
+ echo '# force treating your box as if it was a ...'
+ read -r line
+ [[ # pi4, pi4_8gb, cm4, pi400, pi3, cm3, pi3+, cm3+, pi2, pi1, cm1, pi0, pi0w =~ ^(#)?[a-zA-Z] ]]
+ echo '# pi4, pi4_8gb, cm4, pi400, pi3, cm3, pi3+, cm3+, pi2, pi1, cm1, pi0, pi0w'
+ read -r line
+ [[ #hw=pi4 =~ ^(#)?[a-zA-Z] ]]
+ parsed='#hw=pi4'
+ [[ #hw=pi4 =~ ^#[a-zA-Z] ]]
+ parsed=hw=pi4
++ cut -d= -f1
++ echo hw=pi4
+ param=hw
+ [[ -v hw ]]
+ echo '#hw=pi4'
+ eval hw=pi4
++ hw=pi4
+ read -r line
+ echo ''
+ read -r line
+ [[ # Hardware architecture =~ ^(#)?[a-zA-Z] ]]
+ echo '# Hardware architecture'
+ read -r line
+ [[ # x86_64, amd64, armv6l, armv7l, aarch64, arm64 =~ ^(#)?[a-zA-Z] ]]
+ echo '# x86_64, amd64, armv6l, armv7l, aarch64, arm64'
+ read -r line
+ [[ #hwarch=armv7l =~ ^(#)?[a-zA-Z] ]]
+ parsed='#hwarch=armv7l'
+ [[ #hwarch=armv7l =~ ^#[a-zA-Z] ]]
+ parsed=hwarch=armv7l
++ cut -d= -f1
++ echo hwarch=armv7l
+ param=hwarch
+ [[ -v hwarch ]]
+ echo '#hwarch=armv7l'
+ eval hwarch=armv7l
++ hwarch=armv7l
+ read -r line
+ echo ''
+ read -r line
+ [[ # OS distribution/release =~ ^(#)?[a-zA-Z] ]]
+ echo '# OS distribution/release'
+ read -r line
+ [[ # Valid arguments: raspios, raspbian, debian, ubuntu, stretch, buster, bionic, focal =~ ^(#)?[a-zA-Z] ]]
+ echo '# Valid arguments: raspios, raspbian, debian, ubuntu, stretch, buster, bionic, focal'
+ read -r line
+ [[ #osrelease=buster =~ ^(#)?[a-zA-Z] ]]
+ parsed='#osrelease=buster'
+ [[ #osrelease=buster =~ ^#[a-zA-Z] ]]
+ parsed=osrelease=buster
++ cut -d= -f1
++ echo osrelease=buster
+ param=osrelease
+ [[ -v osrelease ]]
+ echo '#osrelease=buster'
+ eval osrelease=buster
++ osrelease=buster
+ read -r line
+ echo ''
+ read -r line
+ [[ # Java architecture mode =~ ^(#)?[a-zA-Z] ]]
+ echo '# Java architecture mode'
+ read -r line
+ [[ # Valid arguments: "Adopt11", "Zulu11-32", or "Zulu11-64" =~ ^(#)?[a-zA-Z] ]]
+ echo '# Valid arguments: "Adopt11", "Zulu11-32", or "Zulu11-64"'
+ read -r line
+ [[ java_opt=Zulu11-32 =~ ^(#)?[a-zA-Z] ]]
+ parsed=java_opt=Zulu11-32
+ [[ java_opt=Zulu11-32 =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo java_opt=Zulu11-32
+ param=java_opt
+ [[ -v java_opt ]]
+ [[ Zulu11-32 == *\ * ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # openHAB Log Viewer (frontail) theme =~ ^(#)?[a-zA-Z] ]]
+ echo '# openHAB Log Viewer (frontail) theme'
+ read -r line
+ [[ # Valid arguments: "light", "dark" =~ ^(#)?[a-zA-Z] ]]
+ echo '# Valid arguments: "light", "dark"'
+ read -r line
+ [[ frontailtheme=light =~ ^(#)?[a-zA-Z] ]]
+ parsed=frontailtheme=light
+ [[ frontailtheme=light =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo frontailtheme=light
+ param=frontailtheme
+ [[ -v frontailtheme ]]
+ [[ light == *\ * ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # install zram per default, set to "disable" to skip installation =~ ^(#)?[a-zA-Z] ]]
+ echo '# install zram per default, set to "disable" to skip installation'
+ read -r line
+ [[ zraminstall=enable =~ ^(#)?[a-zA-Z] ]]
+ parsed=zraminstall=enable
+ [[ zraminstall=enable =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo zraminstall=enable
+ param=zraminstall
+ [[ -v zraminstall ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # start comitup hotspot if internet is not reachable =~ ^(#)?[a-zA-Z] ]]
+ echo '# start comitup hotspot if internet is not reachable'
+ read -r line
+ [[ hotspot=enable =~ ^(#)?[a-zA-Z] ]]
+ parsed=hotspot=enable
+ [[ hotspot=enable =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo hotspot=enable
+ param=hotspot
+ [[ -v hotspot ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # external SD card device to backup and mirror the internal SD card to =~ ^(#)?[a-zA-Z] ]]
+ echo '# external SD card device to backup and mirror the internal SD card to'
+ read -r line
+ [[ #backupdrive=/dev/sda =~ ^(#)?[a-zA-Z] ]]
+ parsed='#backupdrive=/dev/sda'
+ [[ #backupdrive=/dev/sda =~ ^#[a-zA-Z] ]]
+ parsed=backupdrive=/dev/sda
++ cut -d= -f1
++ echo backupdrive=/dev/sda
+ param=backupdrive
+ [[ -v backupdrive ]]
+ echo '#backupdrive=/dev/sda'
+ eval backupdrive=/dev/sda
++ backupdrive=/dev/sda
+ read -r line
+ [[ storageconfig=openhab-dir =~ ^(#)?[a-zA-Z] ]]
+ parsed=storageconfig=openhab-dir
+ [[ storageconfig=openhab-dir =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo storageconfig=openhab-dir
+ param=storageconfig
+ [[ -v storageconfig ]]
+ [[ openhab-dir == *\ * ]]
+ read -r line
+ [[ storagedir=/storage =~ ^(#)?[a-zA-Z] ]]
+ parsed=storagedir=/storage
+ [[ storagedir=/storage =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo storagedir=/storage
+ param=storagedir
+ [[ -v storagedir ]]
+ [[ /storage == *\ * ]]
+ read -r line
+ [[ storagetapes=15 =~ ^(#)?[a-zA-Z] ]]
+ parsed=storagetapes=15
+ [[ storagetapes=15 =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo storagetapes=15
+ param=storagetapes
+ [[ -v storagetapes ]]
+ [[ 15 == *\ * ]]
+ read -r line
+ [[ storagecapacity=1024 =~ ^(#)?[a-zA-Z] ]]
+ parsed=storagecapacity=1024
+ [[ storagecapacity=1024 =~ ^#[a-zA-Z] ]]
++ cut -d= -f1
++ echo storagecapacity=1024
+ param=storagecapacity
+ [[ -v storagecapacity ]]
+ [[ 1024 == *\ * ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # mail relay settings =~ ^(#)?[a-zA-Z] ]]
+ echo '# mail relay settings'
+ read -r line
+ [[ #adminmail=john.doe@foo.bar =~ ^(#)?[a-zA-Z] ]]
+ parsed='#adminmail=john.doe@foo.bar'
+ [[ #adminmail=john.doe@foo.bar =~ ^#[a-zA-Z] ]]
+ parsed=adminmail=john.doe@foo.bar
++ cut -d= -f1
++ echo adminmail=john.doe@foo.bar
+ param=adminmail
+ [[ -v adminmail ]]
+ echo '#adminmail=john.doe@foo.bar'
+ eval adminmail=john.doe@foo.bar
++ adminmail=john.doe@foo.bar
+ read -r line
+ [[ #relayuser=john.doe@foo.bar =~ ^(#)?[a-zA-Z] ]]
+ parsed='#relayuser=john.doe@foo.bar'
+ [[ #relayuser=john.doe@foo.bar =~ ^#[a-zA-Z] ]]
+ parsed=relayuser=john.doe@foo.bar
++ cut -d= -f1
++ echo relayuser=john.doe@foo.bar
+ param=relayuser
+ [[ -v relayuser ]]
+ echo '#relayuser=john.doe@foo.bar'
+ eval relayuser=john.doe@foo.bar
++ relayuser=john.doe@foo.bar
+ read -r line
+ [[ #relaypass=secret =~ ^(#)?[a-zA-Z] ]]
+ parsed='#relaypass=secret'
+ [[ #relaypass=secret =~ ^#[a-zA-Z] ]]
+ parsed=relaypass=secret
++ cut -d= -f1
++ echo relaypass=secret
+ param=relaypass
+ [[ -v relaypass ]]
+ echo '#relaypass=secret'
+ eval relaypass=secret
++ relaypass=secret
+ read -r line
+ [[ #smarthost=smtp.gmail.com =~ ^(#)?[a-zA-Z] ]]
+ parsed='#smarthost=smtp.gmail.com'
+ [[ #smarthost=smtp.gmail.com =~ ^#[a-zA-Z] ]]
+ parsed=smarthost=smtp.gmail.com
++ cut -d= -f1
++ echo smarthost=smtp.gmail.com
+ param=smarthost
+ [[ -v smarthost ]]
+ echo '#smarthost=smtp.gmail.com'
+ eval smarthost=smtp.gmail.com
++ smarthost=smtp.gmail.com
+ read -r line
+ [[ #smartport=587 =~ ^(#)?[a-zA-Z] ]]
+ parsed='#smartport=587'
+ [[ #smartport=587 =~ ^#[a-zA-Z] ]]
+ parsed=smartport=587
++ cut -d= -f1
++ echo smartport=587
+ param=smartport
+ [[ -v smartport ]]
+ echo '#smartport=587'
+ eval smartport=587
++ smartport=587
+ read -r line
+ echo ''
+ read -r line
+ [[ # Tailscale VPN =~ ^(#)?[a-zA-Z] ]]
+ echo '# Tailscale VPN'
+ read -r line
+ [[ #preauthkey=tskey-xxxxxxxxxxxxxxxxx =~ ^(#)?[a-zA-Z] ]]
+ parsed='#preauthkey=tskey-xxxxxxxxxxxxxxxxx'
+ [[ #preauthkey=tskey-xxxxxxxxxxxxxxxxx =~ ^#[a-zA-Z] ]]
+ parsed=preauthkey=tskey-xxxxxxxxxxxxxxxxx
++ cut -d= -f1
++ echo preauthkey=tskey-xxxxxxxxxxxxxxxxx
+ param=preauthkey
+ [[ -v preauthkey ]]
+ echo '#preauthkey=tskey-xxxxxxxxxxxxxxxxx'
+ eval preauthkey=tskey-xxxxxxxxxxxxxxxxx
++ preauthkey=tskey-xxxxxxxxxxxxxxxxx
+ read -r line
+ echo ''
+ read -r line
+ [[ # Custom log files =~ ^(#)?[a-zA-Z] ]]
+ echo '# Custom log files'
+ read -r line
+ [[ #custom_log_files=("/var/log/foo.log" "/var/log/bar.log") =~ ^(#)?[a-zA-Z] ]]
+ parsed='#custom_log_files=("/var/log/foo.log" "/var/log/bar.log")'
+ [[ #custom_log_files=("/var/log/foo.log" "/var/log/bar.log") =~ ^#[a-zA-Z] ]]
+ parsed='custom_log_files=("/var/log/foo.log" "/var/log/bar.log")'
++ cut -d= -f1
++ echo 'custom_log_files=("/var/log/foo.log" "/var/log/bar.log")'
+ param=custom_log_files
+ [[ -v custom_log_files ]]
+ echo '#custom_log_files=("/var/log/foo.log" "/var/log/bar.log")'
+ eval 'custom_log_files=("/var/log/foo.log" "/var/log/bar.log")'
++ custom_log_files=("/var/log/foo.log" "/var/log/bar.log")
+ read -r line
+ echo ''
+ read -r line
+ [[ # vim: filetype=sh =~ ^(#)?[a-zA-Z] ]]
+ echo '# vim: filetype=sh'
+ read -r line
+ set_cpu_speed
+ is_raspios
+ [[ buster == \r\a\s\p\i\o\s ]]
+ is_raspbian
+ [[ buster == \r\a\s\p\b\i\a\n ]]
++ cat /etc/os-release
+ [[ PRETTY_NAME="Debian GNU/Linux 10 (buster)"
NAME="Debian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/" =~ Raspbian ]]
+ return 1
VERSION_ID="10"
ID=debian
BUG_REPORT_URL="https://bugs.debian.org/" =~ Raspberry Pi OS ]]
+ [[ -f /boot/issue.txt ]]
+ return 1
+ return 0
+ config_ipv6
+ local aptConf=/etc/apt/apt.conf.d/S90force-ipv4
+ local sysctlConf=/etc/sysctl.d/99-sysctl.conf
+ [[ enable == \d\i\s\a\b\l\e ]]
+ [[ enable == \e\n\a\b\l\e ]]
+ grep -qs '^[[:space:]]*# Disable all IPv6 functionality' /etc/sysctl.d/99-sysctl.conf
+ [[ -n '' ]]
+ apt_update
+ PID_APT=1424
+ whiptail_check
+ apt-get update
++ command -v whiptail
+ [[ -x /usr/bin/whiptail ]]
+ load_create_config
+ local 'questionText=\nWelcome to openHABian!\n\nPlease provide the name of your Linux user i.e. the account you normally log in with.\n\nTypical user names are '\''pi'\'' or '\''ubuntu'\''.'
+ local input
+ [[ -f /etc/openhabian.conf ]]
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-09-23_22:30:57_CEST [openHABian] Loading configuration file '\''/etc/openhabian.conf'\''... '
2021-09-23_22:30:57_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... ++ getent group openhabian
+ [[ ! -n openhabian:x:1001:openhabian,frontail ]]
+ id -u openhabian
+ source /etc/openhabian.conf
++ hostname=openhabian
++ username=openhabian
++ userpw=openhabian
++ adminkeyurl=
++ timezone=Europe/Berlin
++ locales='en_US.UTF-8 de_DE.UTF-8'
++ system_default_locale=en_US.UTF-8
++ wifi_ssid=
++ wifi_password=
++ wifi_country=
++ ipv6=enable
++ repositoryurl=https://github.com/openhab/openhabian.git
++ clonebranch=openHAB3
++ debugmode=maximum
++ java_opt=Zulu11-32
++ frontailtheme=light
++ zraminstall=enable
++ hotspot=enable
++ storageconfig=openhab-dir
++ storagedir=/storage
++ storagetapes=15
++ storagecapacity=1024
+ echo OK
OK
+ openhabian_console_check
+ [[ -z 1 ]]
++ tput cols
+ [[ 148 -ge 120 ]]
+ return 0
+ openhabian_update_check
+ [[ -z 1 ]]
+ local branch
+ local introText
+ local unsupportedHWText
+ local unsupportedOSText
+ branch=openHAB3
+ introText='Additions, improvements or fixes were added to the openHABian configuration tool. Would you like to update now and benefit from them? The update will not automatically apply changes to your system.\n\nUpdating is recommended.'
+ unsupportedHWText='You are running on old hardware that is no longer officially supported.\nopenHABian may still work with this or not.\nWe recommend that you replace your hardware with a current SBC such as a RPi4/2GB.\nDo you really want to continue using openHABian on this system?'
+ unsupportedOSText='You are running an old Linux release that is no longer officially supported.\nWe recommend upgrading to the most current stable release of your distribution (or current Long Term Support version for distributions that offer LTS).\nDo you really want to continue using openHABian on this system?'
++ timestamp
++ date +%F_%T_%Z
++ get_git_revision
++ local branch
++ local latestTag
++ local revCount
++ local shorthash
+++ git -C /opt/openhabian rev-parse --abbrev-ref HEAD
++ branch=openHAB3
+++ git -C /opt/openhabian describe --tags --abbrev=0
++ latestTag=patchday-20210118
+++ wc -l
+++ git -C /opt/openhabian log --oneline
++ revCount=1208
+++ git -C /opt/openhabian log --pretty=format:%h -n 1
++ shorthash=75187cd
++ echo '[openHAB3]patchday-20210118-1208(75187cd)'
+ echo '2021-09-23_22:30:57_CEST [openHABian] openHABian configuration tool version: [openHAB3]patchday-20210118-1208(75187cd)'
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-09-23_22:30:57_CEST [openHABian] Checking for changes in origin branch openHAB3... '
2021-09-23_22:30:57_CEST [openHABian] Checking for changes in origin branch openHAB3... + is_pine64
++ uname -r
+ [[ 4.19.0-16-amd64 =~ pine64-longsleep ]]
+ return 1
+ is_jessie
+ [[ buster == \j\e\s\s\i\e ]]
VERSION_ID="10"
ID=debian
BUG_REPORT_URL="https://bugs.debian.org/" =~ jessie ]]
+ return 1
+ is_xenial
+ [[ buster == \x\e\n\i\a\l ]]
VERSION_ID="10"
ID=debian
BUG_REPORT_URL="https://bugs.debian.org/" =~ xenial ]]
+ return 1
+ git -C /opt/openhabian config user.email openhabian@openHABian
+ git -C /opt/openhabian config user.name openhabian
+ git -C /opt/openhabian fetch --quiet origin
++ git -C /opt/openhabian rev-parse openHAB3
++ git -C /opt/openhabian rev-parse '@{u}'
+ [[ 75187cda8953c4fa54c01576a1b948be8c81f4e9 == 75187cda8953c4fa54c01576a1b948be8c81f4e9 ]]
+ echo OK
OK
+ openhabian_announcements
+ [[ -z 1 ]]
+ local newsFile
+ local readNews
+ newsFile=/opt/openhabian/NEWS.md
+ readNews=/opt/openhabian/docs/LASTNEWS.md
+ cmp --silent /opt/openhabian/NEWS.md /opt/openhabian/docs/LASTNEWS.md
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-09-23_22:31:02_CEST [openHABian] Switching to branch openHAB3... '
2021-09-23_22:31:02_CEST [openHABian] Switching to branch openHAB3... + git -C /opt/openhabian checkout --quiet openHAB3
+ echo OK
OK
+ show_main_menu
+ local choice
+ local version
+++ get_git_revision
+++ local branch
+++ local latestTag
+++ local revCount
+++ local shorthash
++++ git -C /opt/openhabian rev-parse --abbrev-ref HEAD
+++ branch=openHAB3
++++ git -C /opt/openhabian describe --tags --abbrev=0
+++ latestTag=patchday-20210118
++++ wc -l
++++ git -C /opt/openhabian log --oneline
+++ revCount=1208
++++ git -C /opt/openhabian log --pretty=format:%h -n 1
+++ shorthash=75187cd
+++ echo '[openHAB3]patchday-20210118-1208(75187cd)'
++ whiptail --title 'Welcome to the openHABian Configuration Tool [openHAB3]patchday-20210118-1208(75187cd)' --menu 'Setup Options' 18 116 11 --cancel-button Exit --ok-button Execute '00 | About openHABian' 'Information about the openHABian project and this tool' '' '' '01 | Select Branch' 'Select the openHABian config tool version ("branch") to run' '02 | Upgrade System' 'Upgrade all installed software packages (incl. openHAB) to their latest version' '03 | Install openHAB' 'Install or upgrade to openHAB release 3' '' '' '10 | Apply Improvements' 'Apply the latest improvements to the basic openHABian setup ►' '20 | Optional Components' 'Choose from a set of optional software components ►' '30 | System Settings' 'A range of system and hardware related configuration steps ►' '40 | openHAB Related' 'Switch the installed openHAB version or apply tweaks ►' '50 | Backup/Restore' 'Manage backups and restore your system ►'
+ choice=
+ RET=1
+ '[' 1 -eq 1 ']'
+ return 255
+ system_check_default_password
+ is_pi
+ is_pifour
+ [[ pi4 == \p\i\4 ]]
+ return 0
+ return 0
+ local algo
+ local defaultPassword
+ local defaultUser
+ local generatedPassword
+ local introText
+ local originalPassword
+ local salt
+ is_pi
+ is_pifour
+ return 0
+ return 0
+ id -u pi
+ is_pi
+ is_pifour
+ return 0
+ return 0
+ defaultUser=openhabian
+ defaultPassword=openhabian
++ cut -d: -f2
++ grep -w openhabian /etc/shadow
+ originalPassword='$6$ppgPamwYCGI3BQRA$D0dZsOyCBW8CuIKn/NKXnhYJHRLNGRYXcJfjmlu0U8nZgsaf26UVQygQB6.VwR29/lYDtxAOgFsK3f7ndfK7a.'
++ cut '-d$' -f2
++ echo '$6$ppgPamwYCGI3BQRA$D0dZsOyCBW8CuIKn/NKXnhYJHRLNGRYXcJfjmlu0U8nZgsaf26UVQygQB6.VwR29/lYDtxAOgFsK3f7ndfK7a.'
+ algo=6
+ introText='The default password was detected on your system! That is a serious security concern. Bad guys or malicious programs in your subnet are able to gain root access!\n\nPlease set a strong password by typing the command '\''passwd openhabian'\''!'
++ cut '-d$' -f3
+ salt=ppgPamwYCGI3BQRA
+ export algo defaultPassword salt
++ perl -le 'print crypt("$ENV{defaultPassword}","\$$ENV{algo}\$$ENV{salt}\$")'
+ generatedPassword='$6$ppgPamwYCGI3BQRA$D0dZsOyCBW8CuIKn/NKXnhYJHRLNGRYXcJfjmlu0U8nZgsaf26UVQygQB6.VwR29/lYDtxAOgFsK3f7ndfK7a.'
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-09-23_22:31:22_CEST [openHABian] Checking for default openHABian username:password combination... '
2021-09-23_22:31:22_CEST [openHABian] Checking for default openHABian username:password combination... ++ id -u openhabian
+ [[ -n 1001 ]]
+ [[ $6$ppgPamwYCGI3BQRA$D0dZsOyCBW8CuIKn/NKXnhYJHRLNGRYXcJfjmlu0U8nZgsaf26UVQygQB6.VwR29/lYDtxAOgFsK3f7ndfK7a. == \$\6\$\p\p\g\P\a\m\w\Y\C\G\I\3\B\Q\R\A\$\D\0\d\Z\s\O\y\C\B\W\8\C\u\I\K\n\/\N\K\X\n\h\Y\J\H\R\L\N\G\R\Y\X\c\J\f\j\m\l\u\0\U\8\n\Z\g\s\a\f\2\6\U\V\Q\y\g\Q\B\6\.\V\w\R\2\9\/\l\Y\D\t\x\A\O\g\F\s\K\3\f\7\n\d\f\K\7\a\. ]]
+ [[ -n 1 ]]
+ whiptail --title 'Default password detected' --msgbox 'The default password was detected on your system! That is a serious security concern. Bad guys or malicious programs in your subnet are able to gain root access!\n\nPlease set a strong password by typing the command '\''passwd openhabian'\''!' 11 80
+ echo FAILED
FAILED
++ timestamp
++ date +%F_%T_%Z
+ echo -e '2021-09-23_22:31:23_CEST [openHABian] We hope you got what you came for! See you again soon ;)'
+ cd /home/openhabian
i did in fact read it but i cannot make any sense of it. i was looking for an “error” or something like that …
EDIT:
Ok i just recognized, that it keeps logging after i executed a command.
Here’s what i found after trying to update/reinstall:
[[ 02 | Upgrade System == '' ]]
+ [[ 02 | Upgrade System == \0\0* ]]
+ [[ 02 | Upgrade System == \0\1* ]]
+ [[ 02 | Upgrade System == \0\2* ]]
+ wait_for_apt_to_finish_update
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-09-23_22:37:17_CEST [openHABian] Updating Linux package information... '
2021-09-23_22:37:17_CEST [openHABian] Updating Linux package information... + [[ -z 2078 ]]
+ tail --pid=2078 -f /dev/null
+ echo OK
OK
+ system_upgrade
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-09-23_22:37:17_CEST [openHABian] Updating repositories and upgrading installed packages... '
2021-09-23_22:37:17_CEST [openHABian] Updating repositories and upgrading installed packages... + export DEBIAN_FRONTEND=noninteractive
+ DEBIAN_FRONTEND=noninteractive
+ apt-get upgrade --yes -o Dpkg::Options::=--force-confdef -o Dpkg::Options::=--force-confold
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
Paketaktualisierung (Upgrade) wird berechnet... Fertig
Die folgenden Pakete sind zurückgehalten worden:
linux-image-amd64
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
+ cond_redirect java_install_or_update Zulu11-32
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ java_install_or_update Zulu11-32 \033[39;49;00m'
+ java_install_or_update Zulu11-32
+ local branch
+ branch=openHAB3
++ command -v java
+ [[ -x /usr/bin/java ]]
++ java -version
+ [[ /opt/openhabian/functions/java-jre.bash: Zeile 15: /usr/bin/java: Kann die Binärdatei nicht ausführen: Fehler im Format der Programmdatei == *\Z\u\l\u* ]]
++ java -version
+ [[ /opt/openhabian/functions/java-jre.bash: Zeile 15: /usr/bin/java: Kann die Binärdatei nicht ausführen: Fehler im Format der Programmdatei == *\A\d\o\p\t\O\p\e\n\J\D\K* ]]
++ command -v java
+ cond_redirect java -version
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ java -version \033[39;49;00m'
$ java -version
+ java -version
/opt/openhabian/functions/helpers.bash: Zeile 31: /usr/bin/java: Kann die Binärdatei nicht ausführen: Fehler im Format der Programmdatei
+ return 126
+ return 126
+ echo FAILED
FAILED
+ return 1
+ '[' 1 -ne 0 ']'
+ whiptail --msgbox 'There was an error or interruption during the execution of:\n "02 | Upgrade System"\n\nPlease try again. If the error persists, please read /opt/openhabian/docs/openhabian-DEBUG.md or https://github.com/openhab/openhabian/blob/main/docs/openhabian-DEBUG.md how to proceed.' 14 80
+ return 0
sounds like a java problem?! right?
