from the openhab-binding-xmppclient section in file /var/lib/openhab/tmp/kar/openhab-addons-3.2.0/org/openhab/distro/openhab-addons/3.2.0/openhab-addons-3.2.0-features.xml magicly improves the situation…
Yes this is openhab-addons#11560. Now that these changes are also in the release it might be a good idea to upload the artifacts to the online repo @Kai.
Interesting ist, that a lot of unrelated bindings were affected and that might be worth a look for the future to make the loading of bindings more independent…
Thank you to all those that made version 3.2 possible.
Just to double check. Do the upgrade issues affect docker installation only?
Are there any issues reported with non-docker installations?
Anyone else having a problem with their Mail binding after the upgrade? I’m getting:
14:49:46.473 [WARN ] [hab.binding.mail.internal.SMTPHandler] - Sending the email to the following server failed : redacted.redacted.net:25
14:49:46.476 [WARN ] [hab.binding.mail.internal.SMTPHandler] - javax.mail.MessagingException: IOException while sending message;
nested exception is:
javax.activation.UnsupportedDataTypeException: text/plain; charset=UTF-8
Actual addresses / IDs redacted. This was working in 3.1 on a manual install at /opt/openhab. It broke after running the upgrade script. I tried a fresh install to see if that made a difference but same problem on a fresh install too.
Thanks for the ping, @wborn and sorry for not having it uploaded yet. @ramack, it’s done now and the xmppclient binding should now smoothly install (and not have any negative impact on other add-ons either).
thanks for your efforts. I just started built up OH3.2 from scratch using docker on my synology. But I am not sure whether the fixed version is already available in the docker repository (openhab:latest). Anyway, binding upload doesn’t work. How can I check whether your fixes are already available? Or is it what you mean “to upload the artifacts to the online repo”. Thnaks for any advice.
A huge thanks and a merry christmas to all involved in development, forums/help,documentation and organisation! Been using OH for years and I really appreciate all the work and effort!
Same here, updated from 3.1.1 to 3.2.0 stable on openhabian. Worked perfect. I only had to replace Amazon Echo Binding with 3.2.8 version due to “socket errors” in openhab.log
After upgrading to 3.2 my powerview hub stays offline. I should mention that I am on docker. My network mode is host. The error message I see on the UI is:
Hi there,
it seems, that in the nuki-binding of 3.2 are some breaking changes because they have changed all the lockstate-codes to lock and unlock the nuki.
i think, it would be good, if you could add this in the ‘breaking-changes’ enumeration of the release-announcement. it tooks me a couple of “magic minutes” in the cold to explore this…
I updated from the RC1 to the 3.2 Release and now I found a bug. I am not 100% sure that it wasn’t already in the RC1 version, but it wasn’t in the 3.2 M5 Release.
This occures when I open a specific group in my sitemap.
2021-12-22 08:43:11.018 [ERROR] [internal.JSONResponseExceptionMapper] - Unexpected exception occurred while processing REST request.
at org.openhab.core.ui.internal.items.ItemUIRegistryImpl.getLabel(ItemUIRegistryImpl.java:450) ~[?:?]
at org.openhab.core.io.rest.sitemap.internal.SitemapResource.createWidgetBean(SitemapResource.java:517) ~[?:?]
at org.openhab.core.io.rest.sitemap.internal.SitemapResource.createPageBean(SitemapResource.java:475) ~[?:?]
at org.openhab.core.io.rest.sitemap.internal.SitemapResource.getPageBean(SitemapResource.java:371) ~[?:?]
at org.openhab.core.io.rest.sitemap.internal.SitemapResource.getPageData(SitemapResource.java:284) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor346.invoke(Unknown Source) ~[?:?]
at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179) ~[bundleFile:3.4.5]
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96) ~[bundleFile:3.4.5]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201) ~[bundleFile:3.4.5]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96) ~[bundleFile:3.4.5]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doGet(AbstractHTTPServlet.java:222) ~[bundleFile:3.4.5]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[bundleFile:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273) ~[bundleFile:3.4.5]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82) ~[bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:386) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.43.v20210629]
Sitemap:
Group item=Wetterstation label="Wetterstation" icon="sun_clouds"
