12 posts were split to a new topic: OpenJDK and Zulu in openHABian
I use Zulu 11 OpenJDK. It was installed via openhabian.
In the meantime I’ve set up a fresh openhabian install. Unfortunately, the problem (see Error message during start-up after updating from 3.1.1 to 3.2: [core.karaf.internal.FeatureInstaller] - Failed installing add-ons) persits when I restore my configuration.
Not quite, it is to eventually discuss identified and confirmed issues with the software that were introduced in 3.2. This thread is to quickly get maintainers an overview of what’s eventually bad in most recent changes, strictly speaking that would be changes between the last milestone i.e. 3.2M5, and the final 3.2 release.
Getting that overview will not work if we discuss any 3.2 related issue here so my request regarding discussion on the milestone applies here likewise and I will keep splitting if necessary.
Since update from 3.1.1 to 3.2 rrd4j items with COUNTER in services/rrd4j.cfg
seems not to work anymore. The values included in database are all zero. Has there something been changed? I only could find that rrd4j was updated to a newer version.
ctr24h.def=COUNTER,900,0,U,60
ctr24h.archives=AVERAGE,0.5,1,480:AVERAGE,0.5,10,144
ctr24h.items=Item1,Item2
No issues upgrading to 3.2 from 3.1 via apt on Ubuntu 20.04.
I only use a small number of bindings. Current details below:
runtimeInfo:
version: 3.2.0
buildString: Release Build
locale: en-GB
systemInfo:
configFolder: /etc/openhab
userdataFolder: /var/lib/openhab
logFolder: /var/log/openhab
javaVersion: 11.0.13
javaVendor: Azul Systems, Inc.
javaVendorVersion: Zulu11.52+13-CA
osName: Linux
osVersion: 5.11.22-5-pve
osArchitecture: amd64
availableProcessors: 2
freeMemory: 111027184
totalMemory: 299892736
bindings:
- astro
- gpstracker
- http
- mqtt
- network
Well done to everyone involved, and Merry Christmas!
I have just made my second attempt to update from 3.1.1-1 to 3.2, after a first attempt on 23/12.
For the second time it just blew up my OH system, flooding the log with errors (generating some 40MB or errors in the log in less than a minute), forcing me to restore the previous version.
Prior to posting here I did read this thread and a couple of issues mentioned here applied to me.
- I did encounter the karaf error about failing to install add-ones (see below), but had been under the impression that the underlying issue for that had been fixed in the meantime; or, at least, from this discussion, that this was not a fundamental issue preventing the proper functioning of the system.
2021-12-28 13:34:23.538 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-tr064, openhab-persistence-mapdb, openhab-binding-senechome, openhab-misc-openhabcloud, openhab-binding-avmfritz, openhab-binding-network, openhab-persistence-influxdb, openhab-ui-habpanel, openhab-automation-jsscripting, openhab-binding-shelly, openhab-binding-nuki, openhab-binding-mqtt, openhab-transformation-map, openhab-binding-ipcamera, openhab-binding-homematic, openhab-binding-systeminfo, openhab-binding-mail, openhab-persistence-jdbc-mariadb, openhab-transformation-javascript, openhab-binding-sonos, openhab-transformation-regex, openhab-transformation-jsonpath, openhab-ui-basic, openhab-binding-http, openhab-binding-astro': null
- I also saw a mention of the System Info binding causing issues, so I uninstalled that prior to upgrading the second time.
- Also noticed a mentioned issue with Influxdb, but that sounded like it only applied to fresh installs where existing data gets copied in.
Hence asking whether anyone can make sense of the issues I am facing:
Here’s what I do / observe in my case (without really noticing any difference between first and second upgrade attempts):
- upgrade to 3.2 via apt full-upgrade
- in the logs I see the system restarting, loading all models and items
- I also start seeing some output from rules running at system start which post a number of default values to related number items (which are not connected to any bindings)
- then I start getting quite few error messages saying that transformation services MAP and JS are not available (plus all the states to be transformed are NULL) → suggesting that the bindings are not working at this stage?
2021-12-28 13:33:25.780 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'FboxKurtpresent' with pattern 'MAP(presence.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2021-12-28 13:33:25.879 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'SonosWohnzimmerStecker19216817828DeviceUptime' with pattern 'JS(secstotimeshort.js):%s': Couldn't transform value because transformation service of type 'JS' is not available.
- then I have many rules and also scheduled jobs failing, again because of the NULLs
- also warning that no queryable persistance service influxdb (which is my default service)
2021-12-28 13:33:28.099 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id 'influxdb'
- then the above-mentioned karaf error of failed installing bindings
- after that OH restarts, starts loading items and rules again
- and then all hell breaks lose, with lots of “Error executing EValidator” or “resolution of uriFragment failed” errors on all the rules; and each of those errors fills 1-2k lines in the logs, hence quickly blowing up the logs. (See start of the first EValidator error message and start of first “resolution of uriFragment” errors below).
2021-12-28 13:35:04.274 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'allother.rules'
2021-12-28 13:35:06.076 [ERROR] [xtext.validation.CompositeEValidator] - Error executing EValidator
java.lang.UnsupportedOperationException: Missing type computation for expression type: QuantityLiteral / ExpressionTypeComputationState: ExpressionAwareStackedResolvedTypes: [
parent: [
parent: [
parent: [
types:
JvmOperation: Tmp_allotherRules._Elternbad Temperatur() (visibility: PUBLIC, simpleName: _Elternbad Temperatur, identifier: Tmp_allotherRules._Elternbad Temperatur(), deprecated: <unset>) (varArgs: false) (static: true, final: false, abstract: false, synchronized: false, default: false, native: false, strictFloatingPoint: false) -> void
declaredTypeParameters:
parent: [
types:
JvmField: Tmp_allotherRules.counter (visibility: PRIVATE, simpleName: counter, identifier: Tmp_allotherRules.counter, deprecated: <unset>) (static: true, final: false, volatile: false, transient: false, constant: <unset>, constantValue: null) -> Number
JvmField: Tmp_allotherRules.draussenkaelter (visibility: PRIVATE, simpleName: draussenkaelter, identifier: Tmp_allotherRules.draussenkaelter, deprecated: <unset>) (static: true, final: false, volatile: false, transient: false, constant: <unset>, constantValue: null) -> boolean
JvmField: Tmp_allotherRules.ElternbadKalt (visibility: PRIVATE, simpleName: ElternbadKalt, identifier: Tmp_allotherRules.ElternbadKalt, deprecated: <unset>) (static: true, final: false, volatile: false, transient: false, constant: <unset>, constantValue: null) -> boolean
JvmField: Tmp_allotherRules.KinderbadKalt (visibility: PRIVATE, simpleName: KinderbadKalt, identifier: Tmp_allotherRules.KinderbadKalt, deprecated: <unset>) (static: true, final: false, volatile: false, transient: false, constant: <unset>, constantValue: null) -> boolean
JvmField: Tmp_allotherRules.STOP (visibility: PRIVATE, simpleName: STOP, identifier: Tmp_allotherRules.STOP, deprecated: <unset>) (static: true, final: false, volatile: false, transient: false, constant: <unset>, constantValue: null) -> StopMoveType
JvmField: Tmp_allotherRules.PLAY (visibility: PRIVATE, simpleName: PLAY, identifier: Tmp_allotherRules.PLAY, deprecated: <unset>) (static: true, final: false, volatile: false, transient: false, constant: <unset>, constantValue: null) -> PlayPauseType
2021-12-28 13:35:20.794 [ERROR] [xbase.resource.BatchLinkableResource] - resolution of uriFragment '|::0.2.0.2.0.0.7.0::0::/1' failed.
parent: [
parent: [
parent: [
types:
parent: [
types:
If anyone had any ideas what might be causing this, it would be greatly appreciated!
I recommend to update through openhabian-config menu as the scripts perform some pre-update tasks.
But I do not know of that is the root of your problem.
After updating from 3.1.1 to 3.2.0, my Honeywell TH6320ZW thermostat is not detected properly any more. Seems like Chris removed it from the ZWave binding and has it added back in 3.3.0-SNAPSHOT according to posts in this thread, though I haven’t tested this myself:
In openhab.log I get a new error
2021-12-28 13:00:29.562 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery could not resolve to a thingType! 0039:0011:0008::1.3
The thermostat does still work with any existing Items. But if you try to create a new Item, you can’t - the Thing is empty.
Installation of the latest Z-Wave binding snapshot (openHAB-ZWave [Jenkins]) should solve this problem:
Note, this is what happens if you have the wrong credentials for the /etc/openhab/automation folder.
Just updated to 3.2.0 Release Build. (Ubuntu)
All is well.
After reading the Release notes in Kai’s 3.2.0 is here post, I decided to try out JSScript’ing.
Prior to this, I have used DSL only.
When installing JSScript, I noticed these two entries in the log:
2021-12-29 22:55:48.509 [WARN ] [nternal.fs.watch.JSDependencyTracker] - Failed to create watched directory: /etc/openhab/automation/js/node_modules
2021-12-29 22:55:48.535 [WARN ] [rulesupport.loader.ScriptFileWatcher] - Failed to create watched directory: /etc/openhab/automation/js
Letting it slide, I tried creating my first ever JS rule (a 1s test-ticker), only to get this in the log:
2021-12-29 23:35:01.972 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error while creating ScriptEngine
org.graalvm.polyglot.PolyglotException: Error: Invalid CommonJS root folder: /etc/openhab/automation/js/node_modules
at org.graalvm.polyglot.Context.eval(Context.java:379) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.evalInternal(GraalJSScriptEngine.java:376) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSBindings.initGlobal(GraalJSBindings.java:94) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSBindings.initContext(GraalJSBindings.java:90) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSBindings.requireContext(GraalJSBindings.java:84) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSBindings.put(GraalJSBindings.java:127) ~[?:?]
at javax.script.SimpleScriptContext.setAttribute(SimpleScriptContext.java:246) ~[java.scripting:?]
at org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl.addAttributeToScriptContext(ScriptEngineManagerImpl.java:254) ~[bundleFile:?]
at org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl.createScriptEngine(ScriptEngineManagerImpl.java:144) [bundleFile:?]
at org.openhab.core.automation.module.script.internal.handler.AbstractScriptModuleHandler.createScriptEngine(AbstractScriptModuleHandler.java:92) [bundleFile:?]
at org.openhab.core.automation.module.script.internal.handler.AbstractScriptModuleHandler.getScriptEngine(AbstractScriptModuleHandler.java:88) [bundleFile:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1180) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:988) [bundleFile:?]
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:89) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
2021-12-29 23:35:01.984 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule '915601a534': Fail to execute action: 2
2021-12-29 23:35:01.985 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule '915601a534': Fail to execute action: 2
2021-12-29 23:35:01.986 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule '915601a534': Fail to execute action: 2
This is primarily to notify about this behaviour.
Secondly, for me to remedy this situation, is it enough to just manually create these 2 directories?
Think I found the source of my problem.
A year ago I added this:
omr@shs2:~$ ll /etc/openhab/automation/lib/javascript/community/
total 24
drwxr-xr-x 2 root root 4096 Apr 11 2021 ./
drwxr-xr-x 3 root root 4096 Dec 27 2020 ../
-rw-r--r-- 1 root root 5969 Apr 11 2021 timeUtils.js
-rw-r--r-- 1 root root 4199 Dec 27 2020 timerMgr.js
And I had created a /etc/openhab/automation folder without user openhab write access.
Have remedied this now, and after deleting the test rule and creating another one, the rule runs, but with this warning:
2021-12-30 00:02:23.252 [WARN ] [.internal.OpenhabGraalJSScriptEngine] - Failed to retrieve script script dependency listener from engine bindings. Script dependency tracking will be disabled.
2021-12-30 00:02:23.890 [INFO ] [org.openhab.automation.script ] - Ticker 1s
2021-12-30 00:02:24.235 [INFO ] [org.openhab.automation.script ] - Ticker 1s
I looked for a way to Remove the JSScript add-on, but couldn’t find it.
Wanted to re-install with openhab access to the automation directory. Unsure how serious the warning is though.
Edit: was able to remove the JSScript add-on after a karaf bundle uninstall and an openHab restart.
After a remove/re-install, I still get this warning: (but rule is working)
2021-12-30 15:13:26.998 [WARN ] [.internal.OpenhabGraalJSScriptEngine] - Failed to retrieve script script dependency listener from engine bindings. Script dependency tracking will be disabled.
I am also trying to get the JSScripting to work and got the same error above.
Would be cool to have a migration guide to the new JS dialect.
What have you do? I thought my fingerprint sensor is broken, but now i realize it’s the update’s fault. Before the update i set channel="nuki:smartlock:***:***:lockState"
to value “7”. But this does not work anymore.
they have changed the action-codes in the nuki-binding.
Please read the actual documentation at Nuki - Bindings | openHAB
You have to change the action-codes.
This is benign and can be ignored for now.
See Migrate from Nashorn to JSScripting for UI Rules and the docs for the JS Scripting add-on.
Thank you. That in itself did not help, unfortunately.
But I have now managed to get things running. The two underlying issues that appear to have caused my problems were
- The System Info binding; there appears to be an issue there, as expressed by a number of users here
- for some reason I still had a copy of openhab-addons-3.1.1.kar lying in my addons folder
After uninstalling the binding and deleting the *.kar file things appear to be running well now.
