event.itemState and so on seem to always be strings.
So I get something like “21.5 °C” or “220 kcal”.
When accessing items with items.getitem, I am using .rawState instead of state for that reason.
Do I overlook something, or what is the correct way to get a number out of an event?
In DSL you could just say event.newState as Number.
Not if you are dealing with units of measurement. Even in Rules DSL you have to deal with that differently, ultimately calling .floatValue() or converting the value you are doing math with to a QuantityType with proper units too.
And you can do the same in JS Scripting too.
If it’s just a plain old number, JS itself is smart enough to recognize when you have the String representation of a number and do the conversion to number for you.
The vast majority of the time, the string version of the state will work exactly as you need it to work. The only two exceptions are quantity types and datetime types.
Is it because I have state descriptions?
My temperatures should only have one decimal, so I have %.1f °C in place, allthough being tagged as number: temperature. I will try this out later. Thank you.
Just to not leave this hanging out, it’s because you have the Item defined as a Number:Temperature. If you need help beyond this, I recommend opening a new thread to keep this thread on topic.
I have a beginners Issue which I suppose is not related to 3.3, thus I posted a dedicated discussion thread here.
However I am using the latest image from docker hub (3.3.0-snapshot-alpine from Today (April 27th)) which for the sake of completeness I post this here as well, just in case it could be a version-related Issue after all.
Using the latest snapshot-alpine in docker works but for the go-e charger binding. The already created things work and all linked items also but I can’t create new things (“No thing types can be added with this binding.”):
After migrating to 3.3.0M4, there was an error in the log that a rule failed and after a little investigation, it appears that the marketplace Blockly Date and Time extension that I had added was removed in the migration, and I can’t add it in the marketplace.
After updating from M3 to 3.3.0M4, all my (different) HabPabel-configs seems not not be available anymore. Does somebody else facing issues with HabPanel Configs?
I ran three different configs for three different tablets - and the configs are not choosable anymore.
When importing a config into HabPanel and executing it I see in the log:
[ERROR] [internal.JSONResponseExceptionMapper] - Unexpected exception occurred while processing REST request.
java.lang.IllegalStateException: ManagedProvider is not available
Any ideas?
I went back to M3 - everything fine (again).
I’ve seen it in other context. When you use a registry infrastructure there is an implicit dependency on a “managed provider” which is capable of removing elements. In other words, if you see this error it means that you try to remove an element but there is no known managed provider which is capable of dropping a given element.
There is a logic in PR which does that:
If you see such error it means that condition was not satisfied and you ended up with miss-interpreted provider which is managed, but not detected as one.
Second look at openhab-webui/oh3storage.service.js at main · openhab/openhab-webui · GitHub discloses reason.
The HABpanel did assume that all ui related components are writable which was true until above commit/PR. Once this PR was introduced there is no default UI component provider for HABpanel which could manage its state.
All what is need is below. It is a basic component provider which will simply match HABpanel json file (uicomponents_habpanel_panelconfig.json):
@Component(service = {Provider.class, ManagedProvider.class, UIProvider.class})
public class ManagedHabpanelProvider extends UIComponentProvider {
@Activate
public ManagedHabpanelProvider(@Reference StorageService storageService) {
super("habpanel:panelconfig", storageService);
Thanks for the analysis. I tried to implement that, but unfortunately UIComponentProvider is in an internal package. I guess we should move it, so the specific provider can live in the habpanel project instead of the core project.
How does one revert back to M3? (I generally use openhabian to manage versions, but I don’t see where there is an option to pick a Milestone release other than the most current one.
Update
(openhabian uses apt, I reverted with sudo apt-get install openhab=3.3.0~M3-1), but there were errors related to a transform that was still M4, so I went back to M4)
For Sitemap there is a Provider, I’m currently working on the blocks provider and some refactoring. I wonder if we could generalize it, so it works for all namespaces.
On the separate thread@wborn indicated that the updated libraries haven’t been added to the online repo.
If the updated libraries have been added to the repo, that wasn’t the original problem. If they have not been added, they still need to be added to the repo.
Downloading the kar file and putting it into the addons folder fixes the problem for now.
