The strange thing though is that I was on M6 already and did not encounter that problem
Agreed, and it is - this is as I posted in my message above -:
The limits are 1 to 254 (ie min/max) but 0 and 255 are options and weāre not limiting to options. So as above, I believe all values from 0 to 255 should be valid.
You might not want to use 254 - this will set a dim rate of 254 minutes - 4 1/4 hours
Additional checks were added in the core, but if I remember correctly this was in the previous milestone a few months back, so Iām not sure why this has just started now. I assume this is a bug in the core, but again, Iām not sure what changed, but this config definition hasnāt changed for 6 years according to GitHub.
- Can you exactly explain when this ādim rateā is applied?
- What has a dim rate to do with a rollershutter for example?
- Can I somewhere look up what the default value for that is? (1 >second< for example?)
Should we discuss this further in this thread or rather open a separate one for that?
Itās a speed - the duration of change.
The roller shutter control uses the same command class as a dimmer - the commands are the same.
Not that I know of - itās up to the device manufacturer as far as I can tell.
With regards to
can we not set the min=ā0ā and the max=ā255ā as the 255, which was the value of that configuration before I had to change it, uses obviously the ādeviceās defaultā value (whatever it is)?
Hi since upgrading to M7, none of my bindings that are connected to the internet seem to work. I have the following bindings that connect to the internet:
- evohome
- openweathermap
- buienradar
Bindings that are connected to my own network such as mqtt and wifiled work perfectly.
Does anyone have any idea? I am on a raspberry pi with openhab running in a docker container. Before upgrading from M6 everthing worked fine.
EDIT:
- Just logged into the container and pinged some hosts. Ping works fine, so it doesnāt appear to be a network problem inside the container
- Moved back to M6 and the bindings work again.
J-N-K must have expanded the checking to the channels with M7 (just my speculation based on the traffic)
I set my blinds roller-shutter channel step duration to 128 and my blinds immediately went online and now respond to commands
from OH
After migrating to M7, I experienced the item name beginning with a number problem others have referenced.
2022-06-20 18:24:41.052 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "GroupItem" with key "80Burgundy": The specified name of the item '80Burgundy' is not valid!
I appreciate that a solution is proffered here openHAB 3.3 Milestone discussion - #167 by J-N-K, but Iām afraid I need a little more detail on how to implement it. I have 18 items that are (were) part of the illegally named group. I did an API Get Items (all of them), downloaded the file and can see them. But it is not clear to me how to remove the illegal GroupItem from the JSON definition of the Item using the API. I would appreciate any suggestions of how to do this. Thanks.
What I did was
- a manual edit of the openhab-userdata/jsondb/org.openhab.core.items.Item.json file in a gui editor
- did a search and replace of all occurrences of the offending string, in my case 9999_MyStreetAddress_Ave to g_9999_MyStreetAddress_Ave
That fixed it for me. In my case the offending item name was just a group item, so changing that item and the reference to the group in all the group member items worked fine for me.
Thanks for the quick reply. Two quick questions. Did you first create the new GroupItem? And did you stop openHAB while you editted the json?
Yes, we could do that in this case as the values are contiguous. However this should not be necessary - it should allow all values between min and max, and also the values in the options. This is needed as often we have a min of 0, a max of 100 and then a requirement to have another value (eg 255) for something specific like default.
I stopped OH just because, I donāt know if it was required
I did not create a new group item because it was the root of a very large group
Thanks. That did the trick for me.
After migrating to M7, I also had this in the log:
2022-06-20 19:19:20.540 [ERROR] [ity.CommunityMarketplaceAddonService] - Unable to retrieve marketplace add-ons
javax.net.ssl.SSLException: readHandshakeRecord
at sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) ~[?:?]
at sun.net.www.protocol.https.HttpsClient.afterConnect(Unknown Source) ~[?:?]
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source) ~[?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(Unknown Source) ~[?:?]
at org.openhab.core.addon.marketplace.internal.community.CommunityMarketplaceAddonService.getRemoteAddons(CommunityMarketplaceAddonService.java:172) ~[?:?]
at org.openhab.core.cache.ExpiringCache.refreshValue(ExpiringCache.java:101) [bundleFile:?]
at org.openhab.core.cache.ExpiringCache.getValue(ExpiringCache.java:72) [bundleFile:?]
at org.openhab.core.addon.marketplace.AbstractRemoteAddonService.refreshSource(AbstractRemoteAddonService.java:110) [bundleFile:?]
at org.openhab.core.addon.marketplace.internal.community.CommunityMarketplaceAddonService.modified(CommunityMarketplaceAddonService.java:128) [bundleFile:?]
at org.openhab.core.addon.marketplace.internal.community.CommunityMarketplaceAddonService.<init>(CommunityMarketplaceAddonService.java:117) [bundleFile:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source) [?:?]
at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source) [?:?]
at java.lang.reflect.Constructor.newInstance(Unknown Source) [?:?]
at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:316) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:286) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1000) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:973) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:918) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:220) [org.eclipse.osgi-3.17.200.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:217) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:118) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:48) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:547) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:533) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:655) [org.eclipse.osgi-3.17.200.jar:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:88) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:675) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2556) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:2075) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:2058) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:443) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:301) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1200) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1121) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:928) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:864) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1152) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:114) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:120) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:956) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:936) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:873) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:261) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:495) [org.eclipse.osgi-3.17.200.jar:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1271) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1222) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:667) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:305) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:554) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:70) [bundleFile:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:421) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) [osgi.core-7.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:944) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:486) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.17.200.jar:?]
Suppressed: java.net.SocketException: Broken pipe (Write failed)
at java.net.SocketOutputStream.socketWrite0(Native Method) ~[?:?]
at java.net.SocketOutputStream.socketWrite(Unknown Source) ~[?:?]
at java.net.SocketOutputStream.write(Unknown Source) ~[?:?]
at sun.security.ssl.SSLSocketOutputRecord.encodeAlert(Unknown Source) ~[?:?]
at sun.security.ssl.TransportContext.fatal(Unknown Source) ~[?:?]
Caused by: java.net.SocketException: Broken pipe (Write failed)
at sun.security.ssl.SSLSocketOutputRecord.flush(Unknown Source) ~[?:?]
at sun.security.ssl.HandshakeOutStream.flush(Unknown Source) ~[?:?]
at sun.security.ssl.Finished$T13FinishedProducer.onProduceFinished(Unknown Source) ~[?:?]
at sun.security.ssl.Finished$T13FinishedProducer.produce(Unknown Source) ~[?:?]
at sun.security.ssl.SSLHandshake.produce(Unknown Source) ~[?:?]
at sun.security.ssl.Finished$T13FinishedConsumer.onConsumeFinished(Unknown Source) ~[?:?]
at sun.security.ssl.Finished$T13FinishedConsumer.consume(Unknown Source) ~[?:?]
at sun.security.ssl.SSLHandshake.consume(Unknown Source) ~[?:?]
at sun.security.ssl.HandshakeContext.dispatch(Unknown Source) ~[?:?]
at sun.security.ssl.TransportContext.dispatch(Unknown Source) ~[?:?]
at sun.security.ssl.SSLTransport.decode(Unknown Source) ~[?:?]
at sun.security.ssl.SSLSocketImpl.decode(Unknown Source) ~[?:?]
... 114 more
Thanks, Iāll check that.
Glancing forward at the 3.3 release, we should be prepared that a lot of people might hit issues because of this and donāt understand why. Thereās many more that donāt follow milestones than there are that do.
@kai This should be very prominently mentioned in the Release Notes.
I have no problems with openweathermap after moving to 3.3.0.M7
After moving to 3.3.0.M7 I had these entries in openhab.log
2022-06-21 10:01:23.946 [WARN ] [l.structures.TapoDeviceConfiguration] - tapocontrol:P100:6731f67b2d:C0C9E3FFD4BA error reading device-configuration: 'For input string: "30.0"'
2022-06-21 10:01:23.961 [WARN ] [l.structures.TapoDeviceConfiguration] - tapocontrol:P100:6731f67b2d:C0C9E3FFD1A1 error reading device-configuration: 'For input string: "30.0"'
2022-06-21 10:01:23.976 [WARN ] [l.structures.TapoDeviceConfiguration] - tapocontrol:P100:6731f67b2d:C0C9E3963230 error reading device-configuration: 'For input string: "30.0"'
2022-06-21 10:01:23.965 [WARN ] [l.structures.TapoDeviceConfiguration] - tapocontrol:P100:6731f67b2d:C0C9E37658C6 error reading device-configuration: 'For input string: "30.0"'
2022-06-21 10:01:24.014 [WARN ] [l.structures.TapoDeviceConfiguration] - tapocontrol:P100:6731f67b2d:C0C9E3FFD1A1 error reading device-configuration: 'For input string: "30.0"'
2022-06-21 10:01:24.016 [WARN ] [l.structures.TapoDeviceConfiguration] - tapocontrol:P100:6731f67b2d:C0C9E3FFD4BA error reading device-configuration: 'For input string: "30.0"'
2022-06-21 10:01:24.025 [WARN ] [l.structures.TapoDeviceConfiguration] - tapocontrol:P100:6731f67b2d:C0C9E37658C6 error reading device-configuration: 'For input string: "30.0"'
2022-06-21 10:01:24.039 [WARN ] [l.structures.TapoDeviceConfiguration] - tapocontrol:P100:6731f67b2d:C0C9E3963230 error reading device-configuration: 'For input string: "30.0"'
2022-06-21 10:01:24.040 [WARN ] [l.structures.TapoDeviceConfiguration] - tapocontrol:P110:2a2ef37a29:8d49c446e9 error reading device-configuration: 'For input string: "30.0"'
2022-06-21 10:01:24.055 [WARN ] [l.structures.TapoDeviceConfiguration] - tapocontrol:P110:2a2ef37a29:8d49c446e9 error reading device-configuration: 'For input string: "30.0"'
Had no such warnings in M6. The affected things seem to be working ok. According to changelog Tapo binding was not changed from M6 to M7.
