Seeing the same behavior here. openhab-3.4.0~S3124 updated this morning and can’t login now. Running it on a Rocky Linux 8.6 system. I reset the password using the console and still can’t login.
The log is showing:
2022-10-12 08:48:24.605 [WARN ] [uth.internal.AbstractAuthPageServlet] - Authentication failed from [ipv6 address]: Wrong password for user username
Upgraded to 3.4.0.M3 and started getting the errors:
2022-10-17 20:15:00.176 [ERROR] [hab.automation.script.file.garage.js] - Failed to execute rule Garage-Doors---Check-Every-5-Minutes-234f36c9-33db-430f-abdb-25c78dd8c074: TypeError: (intermediate value).get is not a function: TypeError: (intermediate value).get is not a function
at execute (garage.js:56)
at doExecute (webpack://openhab/./node_modules/openhab/rules/rules.js?:243)
2022-10-17 20:15:00.195 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'Garage-Doors---Check-Every-5-Minutes-234f36c9-33db-430f-abdb-25c78dd8c074': Fail to execute action: 1
the offending line is:
if (actions.get('astro', 'astro:sun:home').getElevation(null) > 0) {
I downgraded to 3.4.0.M2 and the errors stopped occurring,
I have to inform that Shelly support for Shelly 1 devices (not Plus/Pro) is broken in 3.4M3 due to the updated Californium libs (2.0.0 → 2.7.3) included in the dist. The code compiles, bit the binding doesn‘t receives Coap traffic.
I noticed the merged issue by mistake, but hadn‘t the chance to test before M3 was closed.
@openhab-core-maintainers: Please inform binding authors on changes like that. Every update of included libraries could break binding compatibility and should be verified by the binding author/
@markus7017 Sorry, Markus, you’re obviously right, we should have done so.
Do you see any chance to fix those issues in Shelly or would we need to downgrade Californium again?
I need to investigate. I did some testing and found out that it works in general, but the events are delayed by 5-10sec compared to 100…500ms before. This is not acceptable for the user. I have no clue if this is related to an architectural change, missing initialization setting, comm problem etc. Maybe I need to contact the Californium project.
I would prefer to revert the change before M5 is coming and I was not able to fix it. I‘ll spend some time at the weekend on this.
By the way: The Tradfi binding might also be affected, it also uses Californium
Ok, I was able to fix the problem. The multicast initialization needed another parameter with Californium 2.7.3. @fwolter I submitted a PR and requested your review. Maybe we could push this a little bit as a hot fix for M3 users.
@wborn I noticed that there is Californium 2.7.4. If you consider to bump to the latest version let me know. If so we should do it now and test, so M3 is broken for Shelly and M4 works with changes in sync.
Seems like the uploads are missing or went wrong.
I have no access to upload, but @Kai can take care of it later. The download urls should be working then right away.
Yersterday I did an update. First to the M3, later to the M4 version.
After updating to M3 I had a problem with the sonos binding. Maybe its caused to the Upnp.
In the Karaf Console some states are “Waiting”
There haven’t been any changes wrt JUPnP nor Sonos, so I doubt that this issue is newly introduced.
Could you try to manually stop/start the bundles and check, what service they are waiting for?
Yesterday I did start/stop the bundles. Nothing happend, they were still in Waiting status. Today I restored the backup zip file from yesterday (3.4M2) and after that all the bundles went to Active, also Sonos is working again.
