I think this is related to the change in 3.4 for quantity types. I can see this in the log for the ZWave node I deleted and recreated a few minutes ago:
2022-12-23 14:39:50.873 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 87: Updating channel state zwave:device:c247fe7742:node87:sensor_luminance to 179 lx [QuantityType]
2022-12-23 14:42:51.129 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 87: Sensor Type = Luminance(3), Scale = 1
2022-12-23 14:42:51.129 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 87: Updating channel state zwave:device:c247fe7742:node87:sensor_luminance to 167 lx [QuantityType]
2022-12-23 14:45:51.922 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 87: Sensor Type = Luminance(3), Scale = 1
2022-12-23 14:45:51.923 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 87: Updating channel state zwave:device:c247fe7742:node87:sensor_luminance to 141 lx [QuantityType]
2022-12-23 14:48:52.525 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 87: Sensor Type = Luminance(3), Scale = 1
2022-12-23 14:48:52.525 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 87: Updating channel state zwave:device:c247fe7742:node87:sensor_luminance to 176 lx [QuantityType]
2022-12-23 14:51:53.541 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 87: Sensor Type = Luminance(3), Scale = 1
2022-12-23 14:51:53.542 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 87: Updating channel state zwave:device:c247fe7742:node87:sensor_luminance to 144 lx [QuantityType]
2022-12-23 14:54:54.067 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 87: Sensor Type = Luminance(3), Scale = 1
2022-12-23 14:54:54.067 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 87: Updating channel state zwave:device:c247fe7742:node87:sensor_luminance to 109 lx [QuantityType]
2022-12-23 14:57:55.103 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 87: Sensor Type = Luminance(3), Scale = 1
2022-12-23 14:57:55.103 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 87: Updating channel state zwave:device:c247fe7742:node87:sensor_luminance to 70 lx [QuantityType]
2022-12-23 15:00:56.103 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 87: Sensor Type = Luminance(3), Scale = 1
2022-12-23 15:00:56.103 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 87: Updating channel state zwave:device:c247fe7742:node87:sensor_luminance to 48 lx [QuantityType]
2022-12-23 15:06:58.081 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 87: Sensor Type = Luminance(3), Scale = 1
2022-12-23 15:06:58.081 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 87: Updating channel state zwave:device:c247fe7742:node87:sensor_luminance to 39 lx [QuantityType]
2022-12-23 15:09:59.062 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 87: Sensor Type = Luminance(3), Scale = 1
2022-12-23 15:09:59.062 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 87: Updating channel state zwave:device:c247fe7742:node87:sensor_luminance to 30 lx [QuantityType]
2022-12-23 15:22:02.392 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 87: Sensor Type = Luminance(3), Scale = 1
2022-12-23 15:22:02.392 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 87: Updating channel state zwave:device:c247fe7742:node87:sensor_luminance to 42 lx [QuantityType]
2022-12-23 15:31:05.767 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 87: Sensor Type = Luminance(3), Scale = 1
2022-12-23 15:31:05.767 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 87: Updating channel state zwave:device:c247fe7742:node87:sensor_luminance to 27 lx [QuantityType]
2022-12-23 15:37:07.664 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 87: Sensor Type = Luminance(3), Scale = 1
2022-12-23 15:37:07.664 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 87: Updating channel state zwave:device:c247fe7742:node87:sensor_luminance to 16 lx [QuantityType]
2022-12-23 15:52:28.108 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 87: Sensor Type = Luminance(3), Scale = 1
2022-12-23 15:52:28.108 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 87: Updating channel state zwave:device:c247fe7742:node87:sensor_luminance to 5 lx [QuantityType]
The luminance values were being reported by the device, they just didnât seem to make it through to the linked item.
The linked item that has just been recreated when I created the thing is a number item with no UoM:
However, another PIR (same make and model) that I havenât deleted and recreated (so this is the item that was created in OH3.3) is a number with the UoM luminous intensity:
I need to do some more investigation into this and shine a torch at a couple of these PIRs but I thought Iâd post this in case anyone has any suggestions on what diagnostics I can perform.
If QuantityType is posted to a plain Number item the unit is stripped and the value posted as plain number, as requested by the user that created a plain Number item.
Thanks for reminding me to use DEBUG mode. I could fix the issue on my own. So it looks like the new version is more precise.
The error was
2022-12-23 11:40:40.096 [ERROR] [jdbc.internal.JdbcPersistenceService] - bundle org.openhab.persistence.jdbc:3.4.0 (304)[org.openhab.persistence.jdbc.internal.JdbcPersistenceService(382)] : The activate method has thrown an exception
java.lang.IllegalArgumentException: 12 is not a valid item name
So I deleted the entry in the database table and it worked. However now my regular historic temperature update throws errors. Iâll double check the forum and maybe enable debug again to dig deeper. However, the strange thing is, the values are updated.
The errors are:
[WARN ] [jdbc.internal.JdbcPersistenceService] - JDBC::query: Unable to query item
org.openhab.persistence.jdbc.internal.exceptions.JdbcSQLException: Error in SQL query!!!; HOUR_OF_DAY: 2 -> 3 Query: SELECT time, value FROM Item328 WHERE TIME>='2021-12-23 19:45:12' ORDER BY time ASC Parameters: []; Pool Name= yank-default; SQL= SELECT time, value FROM Item328 WHERE TIME>='2021-12-23 19:45:12' ORDER BY time ASC
Itâs important to configure the same time-zone in the JDBC connection string as in openHAB. But I donât think anything changed in 3.4 in this regard. See also:
I was still on RC1 (because I wasnât brave enough so far to go the the final as I was working on the blockly jsscripting migration and didnât want to change too many things at the same time) and now I updated to final 3.4.0 Release build.
I can now say that it at least happens much much less. Currently it is only affecting one out of four and it only âhappensâ around every two minutes (still annoying though(. The difference that I see is that the three stable ones are a google minis whereas the one that is flickering a bit, is a nest hub.
Even there is no obvious change (I checked the code and libs) it seems there is a transient dependency somewhere.
(note that this is not due to a restart because I had done that several times before)
I just upgraded to 3.4.0 but found several warning messages in the openhab.log file, such as:
2022-12-24 16:52:33.971 [WARN ] [d4j.internal.RRD4jPersistenceService] - Failed to open rrd4j database âSunology_Voltageâ (java.lang.IllegalStateException)
âŠ
2022-12-24 16:48:19.152 [WARN ] [core.thing.internal.ThingManagerImpl] - No config description for âchannel-type:http:channel-config-numberâ found when normalizing configuration for âhttp:url:69657263c9:46â. This is probably a bug.
2022-12-24 16:48:19.154 [WARN ] [core.thing.internal.ThingManagerImpl] - No config description for âchannel-type:http:channel-config-numberâ found when normalizing configuration for âhttp:url:69657263c9:T1_HCHPâ. This is probably a bug.
2022-12-24 16:48:19.155 [WARN ] [core.thing.internal.ThingManagerImpl] - No config description for âchannel-type:http:channel-config-numberâ found when normalizing configuration for âhttp:url:69657263c9:T1_PAPPâ. This is probably a bug.
âŠ
2022-12-24 16:48:42.329 [WARN ] [core.audio.internal.AudioManagerImpl] - Failed playing audio stream âorg.openhab.core.audio.FileAudioStream@7e05af3fâ as no audio sink was found.
These warning messages appeared when I started openhab (it was not the first start after the upgrade). I must said that I got several error messages when I started openhab 3.4.0 the first time. Openhab started twice without any intervention on my side. I used a docker container for openhab.
2022-12-24 16:48:19.131 [WARN ] [ty.util.ssl.SslContextFactory.config] - No Client EndPointIdentificationAlgorithm configured for Client@3b5a64ea[provider=null,keyStore=null,trustStore=null]
And this one appeared several minutes after starting openhab. I also got this message for other items:
Openhab seems to run fine but I did not check everythingâŠ
