I might have missed it, but will we in version 3 still have the possibility to use the code editor? Or do we define everything in the new GUI only? If both still co exists, will these work together better than in OH2?
It is up to you to use the code editor or the ui. OH2 and OH3 are not comparable in terms og ui.
Main UI far better than the paper ui. Just give it a try. you can easily import you textual item definition
