- Platform information:
- Hardware: raspberry pi 4 :: 4GB :: arm v7
- OS: Debian :: Docker openhab:3.2.0-snapshot
- Java Runtime Environment: no data
- openHAB version: openHAB 3.2.0 Build #2505
- Issue of the topic:
When using Homekit integration, devices connected via openhab become unavailable after a while. If the Homekit meta is updated the devices become available for some time. The same happens if the bundle Homekit is refreshed in the Karaf console
try to change “Use OpenHAB mDNS” in homekit binding settings via UI
I tried. Doesn’t affect. (I already turned it ON for binding via Homekit)
the OFF is more reliable. please keep it OFF for testing.
if it does not help we need to troubleshoot it
- do you see anything in the log files, any errors when homekit is not available
- can you check with discovery app whether you can see openhab ? (as described here HomeKit Add-on - System Integrations | openHAB)
