Primary Goal:
To only type one field for a prop, which then auto populates all expressions throughout widget code.
Example Group I would use in a widget for TRV control, including open window sensing:
- SittingRoomTRV_LowBattery
- SittingRoomTRV_Temperature
- SittingRoomTRV_TargetTemperature
- SittingRoomTRV_Humidity
- SittingRoomTRV_HVACMode
- SittingRoomTRV_TimerMode
- SittingRoomWindowSensor_OpenClosed
Secondary Goal:
To populate a oh-list-card based on a group and apply above goal.
Examples include groups of:
- 23 + batteries
- 8 switches
- 11 lights
- 6 TRVs
- 5 apple devices
- etc etc
Example problem:
I have lots of Zigbee sensors with batteries.
I am making a list widget that uses the
- Battery Level (sometimes Low Battery switch) to control the icon,
- the badge (showing battery percentage or low battery switch state),
- badge colour (green for > 90% or low battery switch OFF), yellow for <30%, and red for < 10% or low battery switch ON),
- link to online manual (action External URL),
- and Replacement Battery Type (Just text, “CR2030” for example).
It should be possible for this to be as simple as typing the name of a group into a text prop,
then auto populate a list of oh-list-items, all of which then use the naming scheme to fill in all the props in the custom widget in each list place.
Below is my best guess as to how this should work for Goal 1 (but obviously doesn’t):
uid: widget_ListItem_LowBattery
tags: []
props:
parameters:
- label: Location # Get from Group if implementing Goal 2
description: Spell correctly # This is what drives everything.
type: TEXT
- label: Sensor Type # Can be inferred from item name if implementing Goal 2. Or create Command Options list, or text prop.
description: Motion Sensor, TRV, Door Sensor etc # Or get from location prop if implementing Goal 2
type: TEXT
- context: item # I can add an item to Model if implementing Goal 2. Or create Command Options list, or text prop.
label: Battery type
description: Type of Battery that fits the device. eg CR2030
type: TEXT
- context: item # I can add an item to Model if implementing Goal 2, otherwise just a text prop. Or create IF list of known battery types in this widget.
label: Instruction manual URL
description: link to manufactures User Manual
type: TEXT
parameterGroups: []
component: oh-list-item
item: ="items." + props.location.REMOVEWHITESPACES + "_BatteryLevel.state" # example result =items.FrontDoorMotionSensor_BatteryLevel.state - If _BatteryLevel is not available, use _LowBattery.
badge: ="items." + props.location.REMOVEWHITESPACES + "_BatteryLevel.state" # example result =items.FrontDoorMotionSensor_BatteryLevel.state - If _BatteryLevel is not available, use _LowBattery.
badge-color: '=
("items." + props.location.REMOVEWHITESPACES + "_BatteryLevel.state" == "ON") ? "red":
"green"' #- If _BatteryLevel is not available, use _LowBattery.
icon: oh:batterylevel # or oh:lowbattery if _BatteryLevel is not available
iconUseState: true
title: props.location
action: popup
actionModal: widget:widget_DeviceBatteryInfo # A secodary widget/page that holds more info. Not described here.
actionModalConfig:
device: =props.location + " " + props.type # example result Front Door Motion Sensor
battype: =props.battType # example result CR2030
lowbat: =props.location REMOVEWHITESPACES+ props.typeREMOVEWHITESPACES + "_BatteryLevel.state" # example result =items.FrontDoorMotionSensor_BatteryLevel.state
url: =props.url # example result http://gddgmkln.com
slots: null
As for Goal 2, I have no idea.
Any ideas on how to make this AutoMagic work?
