I use a openHAB 3 installation via openhabian.
I get a WARNING in the openhab.log when restarting the system:
2022-01-10 22:59:26.216 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.zigbee.ember.handler.EmberHandler.setGroupRegistration(EmberHandler.java:365) ~[?:?]
at org.openhab.binding.zigbee.ember.handler.EmberHandler.initializeDongleSpecific(EmberHandler.java:120) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.initialiseZigBee(ZigBeeCoordinatorHandler.java:551) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.lambda$2(ZigBeeCoordinatorHandler.java:559) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) ~[?:?]
What is the reason?
