Per the wrapper log it seems like openHAB can’t create the log files when booting from the service. My home directory is named properly and pointed to the right location. As I mentioned yesterday, it works fine when booting from start.bat.
These two lines may indicate the problem:
INFO | jvm 1 | 2020/12/22 07:51:10 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to create file ${sys:openhab.logdir}/openhab.log Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
INFO | jvm 1 | 2020/12/22 07:51:10 | java.io.IOException: The filename, directory name, or volume label syntax is incorrect
Full Log:
STATUS | wrapper | 2020/12/22 07:51:08 | --> Wrapper Started as Service
STATUS | wrapper | 2020/12/22 07:51:08 | Launching a JVM...
INFO | jvm 1 | 2020/12/22 07:51:09 | Wrapper (Version 3.2.3) http://wrapper.tanukisoftware.org
INFO | jvm 1 | 2020/12/22 07:51:09 | Copyright 1999-2006 Tanuki Software, Inc. All Rights Reserved.
INFO | jvm 1 | 2020/12/22 07:51:09 | WARNING: An illegal reflective access operation has occurred
INFO | jvm 1 | 2020/12/22 07:51:09 | WARNING: Illegal reflective access by org.eclipse.osgi.storage.FrameworkExtensionInstaller (file:/C:/openhab/runtime/system/org/eclipse/platform/org.eclipse.osgi/3.12.100/org.eclipse.osgi-3.12.100.jar) to method java.net.URLClassLoader.addURL(java.net.URL)
INFO | jvm 1 | 2020/12/22 07:51:09 | WARNING: Please consider reporting this to the maintainers of org.eclipse.osgi.storage.FrameworkExtensionInstaller
INFO | jvm 1 | 2020/12/22 07:51:09 | WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
INFO | jvm 1 | 2020/12/22 07:51:09 | WARNING: All illegal access operations will be denied in a future release
INFO | jvm 1 | 2020/12/22 07:51:09 | Dec 22, 2020 7:51:09 AM org.apache.karaf.main.lock.SimpleFileLock lock
INFO | jvm 1 | 2020/12/22 07:51:09 | INFO: Trying to lock C:\openhab\userdata\tmp\lock
INFO | jvm 1 | 2020/12/22 07:51:09 | INFO: Lock acquired
INFO | jvm 1 | 2020/12/22 07:51:09 | Dec 22, 2020 7:51:09 AM org.apache.karaf.main.Main$KarafLockCallback lockAcquired
INFO | jvm 1 | 2020/12/22 07:51:09 | INFO: Lock acquired. Setting startlevel to 100
INFO | jvm 1 | 2020/12/22 07:51:09 | Dec 22, 2020 7:51:09 AM org.apache.karaf.main.ShutdownSocketThread run
INFO | jvm 1 | 2020/12/22 07:51:09 | INFO: Shutdown socket thread is listening on 127.0.0.1:53451
INFO | jvm 1 | 2020/12/22 07:51:10 | at java.base/java.io.WinNTFileSystem.canonicalize0(Native Method)
INFO | jvm 1 | 2020/12/22 07:51:10 | at java.base/java.io.WinNTFileSystem.canonicalize(WinNTFileSystem.java:438)
INFO | jvm 1 | 2020/12/22 07:51:10 | at java.base/java.io.File.getCanonicalPath(File.java:620)
INFO | jvm 1 | 2020/12/22 07:51:10 | at java.base/java.io.File.getCanonicalFile(File.java:645)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.util.FileUtils.makeParentDirs(FileUtils.java:142)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory.createManager(RollingFileManager.java:650)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory.createManager(RollingFileManager.java:631)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.appender.AbstractManager.getManager(AbstractManager.java:113)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.appender.OutputStreamManager.getManager(OutputStreamManager.java:114)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.appender.rolling.RollingFileManager.getFileManager(RollingFileManager.java:205)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.appender.RollingFileAppender$Builder.build(RollingFileAppender.java:146)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.appender.RollingFileAppender$Builder.build(RollingFileAppender.java:62)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.config.plugins.util.PluginBuilder.build(PluginBuilder.java:122)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.config.AbstractConfiguration.createPluginObject(AbstractConfiguration.java:1002)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.config.AbstractConfiguration.createConfiguration(AbstractConfiguration.java:942)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.config.AbstractConfiguration.createConfiguration(AbstractConfiguration.java:934)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.config.AbstractConfiguration.doConfigure(AbstractConfiguration.java:552)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.config.AbstractConfiguration.initialize(AbstractConfiguration.java:241)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.config.AbstractConfiguration.start(AbstractConfiguration.java:288)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.LoggerContext.setConfiguration(LoggerContext.java:579)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.LoggerContext.start(LoggerContext.java:285)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl.configureLog4J2(PaxLoggingServiceImpl.java:427)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl.updated(PaxLoggingServiceImpl.java:269)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl$1ManagedPaxLoggingService.updated(PaxLoggingServiceImpl.java:569)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1118)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1074)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:138)
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105)
INFO | jvm 1 | 2020/12/22 07:51:10 | at java.base/java.lang.Thread.run(Thread.java:834)
INFO | jvm 1 | 2020/12/22 07:51:10 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Could not create plugin of type class org.apache.logging.log4j.core.appender.RollingFileAppender for element RollingFile: java.lang.IllegalStateException: ManagerFactory [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory@71aabda5] unable to create manager for [${sys:openhab.logdir}/openhab.log] with data [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$FactoryData@95dd3e0[pattern=${sys:openhab.logdir}/openhab.log.%i, append=true, bufferedIO=true, bufferSize=8192, policy=CompositeTriggeringPolicy(policies=[OnStartupTriggeringPolicy, SizeBasedTriggeringPolicy(size=16777216)]), strategy=DefaultRolloverStrategy(min=1, max=7, useMax=true), advertiseURI=null, layout=%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n, filePermissions=null, fileOwner=null]] Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
INFO | jvm 1 | 2020/12/22 07:51:10 | java.lang.IllegalStateException: ManagerFactory [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory@71aabda5] unable to create manager for [${sys:openhab.logdir}/openhab.log] with data [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$FactoryData@95dd3e0[pattern=${sys:openhab.logdir}/openhab.log.%i, append=true, bufferedIO=true, bufferSize=8192, policy=CompositeTriggeringPolicy(policies=[OnStartupTriggeringPolicy, SizeBasedTriggeringPolicy(size=16777216)]), strategy=DefaultRolloverStrategy(min=1, max=7, useMax=true), advertiseURI=null, layout=%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n, filePermissions=null, fileOwner=null]]
INFO | jvm 1 | 2020/12/22 07:51:10 | at org.apache.logging.log4j.core.appender.AbstractManager.getManager(AbstractManager.java:115)
