Openhab 4.0.1 Influxdb not (fully) installed
  • Platform information:
    • Hardware: intel
    • OS: ubuntu 22.04/docker image of openhab 4.0.1
    • Java Runtime Environment: see container
    • openHAB version: 4.0.1
  • Issue of the topic: Install of influxDB incomplete
reproduction:
setup docker container for openhab 4.0.1.
  • set up account
    -skip rest of setup
  • install binding for influxdb
    -for image 3.4.5 you get an influxDB menu item in the settings menu, for 4.0.1 this is not added
The Menu has just moved, you can find it now in the Addon ā€œInstall/Removeā€ details dialogue (right from the install/remove button, there is a blue gear (yeah, very small…)
Thanks for the quick reply. Found it, but that is very hard to find :slight_smile:
