I upgraded to Openhab 4 - Docker a fortnight ago. Everything has worked so far, with a few adjustments. My system has been working without any problems since then. The log file also looks good. Now I wanted to add a new item. The item was created correctly and is also found under Items.
Only the item is not created in the model. No matter what I set as the path. I then tried to create a new location in the model as a test. This does not work either. This group is found under Items, even with the correct parents. Only in the model it is not displayed. Of course I have already deleted the cache and the temp directory. Unfortunately without success. What is going wrong here?
regards
Christian
