openHAB 4.0 wishlist
  • One of my biggest wishes from only using while openHAB do the work is information inside the “Schedule” section of the UI. I had only rules written in text files and many of them make use of astro binding events and cron time jobs. But no rule is listed in the UI. On the other side, all this rules are listed (not editable) in the “Rules” section. This is fine. But I think it should be possible to calculate the “next” schedule in the same way, as if a had created this rules over the UI directly.
  • Smaller, but useful thinks could be in persistence to have control over the latest data, which is stores. I am actual thinking about creating a fresh linux machine and searched for information, how much space I need on the “hard drive”. More information about used resources, how to get free space, would be nice.
  • And the last, for me big point, is the support for creating a individuell modern UI with Textfiles. It is such a big deal with openHAB to create only a fresh Maschine, install openHAB, copy all text files to the new target and start the system and everything runs. And no defect databases or something could be a problem. Perhaps it could be solved, that the UI is only a assistent and saved the result in files, which could be edited.
