The channel editing seems to still be impossible on #4027, at least when restoring a config from openhab 4.2M1.
I had the same issue while modifying the code tab of an MQTT thing on openhab 4.2M1 (openhabian on a raspberry pi v3). I saved the configuration with openhab-cli backup.
I started fresh with openhabian (in order to start with bookworm) which installed 4.1.2, then I updated to openhab snapshot #4027. I restored the configuration, and I was able to edit the mqtt thing a first time.
After that, editing was still impossible. I tried cleaning-cache, removing and re-adding the thing, removing and re-adding the MQTT binding itself.
A test I have not performed yet is to completely reset openhab configuration, removing everything to see if it is related to the restore of a wrong configuration.
EDIT: I performed the last test, i.e. I created a thing in a completely fresh install of openhab on #4028, but I cannot edit the text in the code tab, once the thing is created (both for the AVM binding and the MQTT binding)
EDIT2: in Milestone 2 this issue seems to be solved. I only had to clean cache after restoring the backup from milestone 1
I have updated from 4.2.0.M1 to 4.2.0.M2 and every time I open a location card in MainUI I see these warnings. Can someone confirm before I open an issue?
|5|07:55:39.121|WARN|e.internal.SseItemStatesEventBuilder|Attempting to send a state update of an item which doesn't exist: __v_isRef|
|4|07:55:34.359|WARN|e.internal.SseItemStatesEventBuilder|Attempting to send a state update of an item which doesn't exist: __v_isRef|
|3|07:55:34.359|WARN|e.internal.SseItemStatesEventBuilder|Attempting to send a state update of an item which doesn't exist: __ob__|
|2|07:55:31.567|WARN|e.internal.SseItemStatesEventBuilder|Attempting to send a state update of an item which doesn't exist: __v_isRef|
|1|07:55:31.566|WARN|e.internal.SseItemStatesEventBuilder|Attempting to send a state update of an item which doesn't exist: __ob__|
> 2024-04-08 08:16:58.279 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: __ob__
> 2024-04-08 08:16:58.280 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: __v_isRef
I noticed, since the milestones build, when I change a thing item in the text file it wonât realoaded succesfully all the times. Only if I clear the cache the files are loaded probably.
I donât have any log file line for this but itâs just an observation by myselfâŠ
For example I cchanged the refresh time on my icalendar thing file but not all things get realoded probably
this is my thing file ( I shortened it because configuration is not the issue)
The button for the Inbox of new things is only visible when new things are detected.
The consequence is that you cannot access things that were (maybe accidentally) hidden.
Iâm not sure wether this behavior was introduced in M2 or before.
As a workaround you can manually add âInboxâ to the URL.
[ERROR] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngine for language 'application/javascript' could not be found for identifier: 0cc119c8-d91d-4be0-85eb-62c76bc0aba2
Get this on startup but everything seems to work, when javascript addon is init.
Otherwise as Information: TimeOfDay Script doesnât work like before with M1. I put hours into variable. Before it was a number. Now itâs a time variable. I must change my code to get it work again:
[ERROR] [on.script.javascript.SystemTimeOfDay] - Failed to execute script: TypeError: A conversion from Temporal to a number is not allowed. To compare use the methods .equals(), .compareTo(), .isBefore() or one that is more suitable to your use case.
at <js>.:anonymous(@openhab-globals.js:2)
at <js>.:program(<eval>:54)
at org.graalvm.polyglot.Context.eval(Context.java:399)
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:458)
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:426)
... 76 more
Another thing i found out, that third party add-ons from SmartHomeJ will be removed after update from M1 to M2. I must reinstall them manually by hand.
They should be automatically installed. Unfortunately there seems to be an issue with the continous installation/de-installation of bundles due to the add-on finder.
@J-N-K I wasnât aware of a problem on this related to the add-on finder. Is there an issue for it? Can you be more precise about what the problem is?
