I just installed new update 4.3.0.M2.
After that all DSL rules seems to be not working any longer without any message, error, warning.
So I recovered the snapshot wit 4.3.0.M1 again.
Is there any idea?
Thanks and have a nice evening
Sebastian
The question is where to report that issue ⦠the add-on has not changed its supported MIME types, so this is more likely a core issues. Anyway, it seems weird to me.
Agreed. Iām on a short vacation so probably wonāt get to this until next week but Iāve a couple of tests in mind to help figure out whatās going on. I guess Iāll file an issue on core, if thatās what the evidence suggests and see where it goes from there.
this parameter is shared across all invocations of significant.js, i.e. fig is always 2 when significant.js is called, even when it is not explicitly given as in my second item.
This is rather surprising behavior, and I was wondering whether itās a bug or a feature in M2 (or before?)
Couldnāt try it on any other build, so please forgive me, if this behavior is not specific to M2.
Thx, Stephen
PS: Update: It seems that one has to manually set the injected variable to undefined at the end of the transformation script in order to have reset before the next invocation - Iām quite astonished:
fig = undefined; // reset fig to undefined for the next iteration
Yes, that would do the trick. But I would like to avoid cluttering my dozens of calls to significant.js with unnecessary fig= parameters⦠(Background: significant.js is my transformation script for rounding incoming values from sensors to a more sensible, reduced number of significant figures/digits depending on the unit of the measurement. I also use fig= to override my unit specific default, e.g. 2 for temperatures.)
I followed @florian-h05 's suggestion and opened the issue 4414 on Github using something like the following script donothing.js as a simplified example:
Anyone having issues with the iCloud binding after 4.3.0M2? This is on openhabian/pi4. I updated to the new milestone and immediately found icloud no longer connects. It will trigger a 2fa prompt that Iāll see on my apple devices and I do get the automated āweāve received a password login from this address, if this was you do nothingā email note from apple. ie. Apple seems to think there was a valid login. But the icloud account thing never gets updated to āOnlineā and will end up in status āERROR: CONFIG.ā Log shows invalid 2fa token.
Thoughts?
2024-10-15 06:09:42.255 [WARN ] [l.handler.ICloudAccountBridgeHandler] - iCloud authentication requires 2-FA code. Please provide code configuration for thing āicloud:account:872293b897ā.
2024-10-15 06:09:42.256 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing āicloud:account:872293b897ā changed from UNKNOWN to OFFLINE (CONFIGURATION_ERROR): Please provide 2-FA code in thing configuration.
2024-10-15 06:10:26.757 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing āicloud:account:872293b897ā changed from OFFLINE (CONFIGURATION_ERROR): Please provide 2-FA code in thing configuration. to UNKNOWN
Upgraded to 4.3.0 M2 and now my groovy scripts are failing.
Initially, I had to clear the Openhab cache and that fixed many issues.
Here is the section of my Openhab Log that docuements the groovy script failure:
2024-10-14 18:30:13.715 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'XXXXXXXXXX' failed: org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed:
Script37.groovy: -1: unable to resolve class org.openhab.binding.omnilink.internal.action.OmnilinkActions
@ line -1, column -1.
Script37.groovy: -1: unable to resolve class org.openhab.binding.pushover.internal.actions.PushoverActions
Script37.groovy: -1: unable to resolve class org.openhab.binding.hue.internal.action.LightActions
Script37.groovy: -1: unable to resolve class org.openhab.binding.astro.internal.action.AstroActions
4 errors
I can provide more info. Any initial thoughts?
Thanks.
Same issue here, groovy scripts are not working since I updated to M2.
This is the error message:
Failed to pre-compile action: 2(org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script19.groovy: -1: unable to resolve class org.openhab.binding.doorbird.internal.action.DoorbirdActions @ line -1, column -1. Script19.groovy: -1: unable to resolve class org.openhab.binding.wled.internal.WLedActions @ line -1, column -1. Script19.groovy: -1: unable to resolve class org.openhab.binding.astro.internal.action.AstroActions @ line -1, column -1. Script19.groovy: -1: unable to resolve class org.openhab.binding.mqtt.internal.action.MQTTActions @ line -1, column -1. Script19.groovy: -1: unable to resolve class org.openhab.binding.solarforecast.internal.actions.SolarForecastActions @ line -1, column -1. Script19.groovy: -1: unable to resolve class org.openhab.binding.network.internal.action.NetworkActions @ line -1, column -1. 6 errors )
Iām running into a configuration warning since oh4.3m2 in OpenHAB related to my MQTT setup, and Iād appreciate some guidance. Hereās the warning Iām seeing in the logs:
2024-11-01 15:52:25.215 [INFO ] [ernal.GenericItemChannelLinkProvider] - Profile 'offset' for channel 'mqtt:topic:haspplate01:sensor_haspbme680_iaqaccuracy' is missing the scope prefix, assuming the correct UID is 'system:offset'. Check your configuration.
From what I understand, OpenHAB is expecting a specific UID (likely system:offset), but my current configuration might be missing this scope prefix. Iām not entirely sure where to adjust this in my setup, as the UID is not explicitly set in my mqtt.things or items files.
Hereās what Iāve tried so far:
Checked my mqtt.things and items files for any missing or incorrect UID specifications.
Verified the profile settings in my channel link configuration.
Has anyone encountered this issue before, or could you guide me on how to properly set the UID
Is this issue will be fixed before the official 4.3 release ?
It seems really a blocker for this new release as the addons not initialized correctly when not defined in a .things file.
