npm i frontail -g
so i did with older OpenHAB Installation in Debian - works as expected
npm i frontail -g
Aaah, I understand.
Just a silly question:
I have rules which are running several times a day and I want to know if they were executed. Is there a way to get the information that those rules are still running ? Or do I have to have a permanently open window (as admin) with the log-viewer to see such information ?
Here a rule-example, which gives me every four hours information that itās still running
var countNTP = 0
var vCount = 0
rule "Zeit mit Zeitzone"
Item Dummy_4 changed to ON or
Item Current_DateTime received update
// logInfo("ntp","Zeit hat sich geƤndert")
var vTimeZoneOffsetString = "MEZ"
val vTimeZoneOffset = Current_DateTime.state.format("%1$tZ")
if (vTimeZoneOffset == "+02:00") vTimeZoneOffsetString = "MESZ"
CurrentTime2.postUpdate(Current_DateTime.state.format("%1$tA, %1$td.%1$tm %1$tH:%1$tM ").toString + vTimeZoneOffsetString)
TimeType.postUpdate(vTimeZoneOffsetString)
CurrentTime4.postUpdate(actualTime_gmt.state.format("%1$tH:%1$tM "))
if (countNTP < 479) {
countNTP = countNTP +1
else {
logInfo("ntp","Zeit hat sich geƤndert {} schon wieder 4 Stunden vorbei", countNTP)
countNTP = 0
Any idea to see such logs ?
Cheers Peter
If you want to check the log automatically, take a look on the LogReader binding. It allows you to define custom pattern and trigger some rule or update DateTime item.
A simpler approach might be to create a DateTime Item āLast run of rule xyā and update it to the current time when running rule xy.
You could also add an expire= timer to an item that causes you to get a message when the rule didnāt run in time.
Upgraded to 4.3 the other day. Tried viewing the new UI Log viewer, but itās always blank. Tried setting a few more parameters to INFO, but still nothing. Is there another setting I need to change?
Originally installed openhabian.
thx for info. I will give it a try
Cheers Peter
Do you have a reverse proxy in place?
Do you access openHAB through openHAB Cloud?
I also can confirm this. All sliders of dimmer items linked to an mqtt:dimmer channel are stuck at position 0 after upgrading to 4.3.
A workaround for me was setting a state description āstepā of 1.
I wrote exactly the same yesterday - temporaty solution is to use 2 browsers, anyway I see slower performance, in the previous version of OH everything worked instantly just click-view, click-item, etc. just quickly
Lots of good recommendations have been provided here. Iāll only add that you can change the logging level of openhab.events.RuleStatusInfoEvent to INFO and that will add a line to events.log (and to log viewer) every time the rule runs and another when it returns to idle. This could be used with @djalās suggestion to use the LogReader binding or to trigger a rule using the Generic trigger (caution, very advanced stuff).
Hi Rich, thx for your help and the hints. When reading here I found another thread where thereās an ongoing discussion about the āfrontail-problemā, and where you are posting too. So I can follow there what*s the next steps.
BTW: I found out that the web-socket problem
2024-12-20 14:52:47.155 [INFO ] [b.core.io.websocket.log.LogWebSocket] - WebSocket error: java.util.concurrent.TimeoutException: Idle timeout expired: 10000/10000 ms
2024-12-20 14:58:07.198 [INFO ] [b.core.io.websocket.log.LogWebSocket] - WebSocket error: java.util.concurrent.TimeoutException: Idle timeout expired: 10000/10000 ms
2024-12-20 15:04:27.120 [INFO ] [b.core.io.websocket.log.LogWebSocket] - WebSocket error: java.util.concurrent.TimeoutException: Idle timeout expired: 10000/10000 ms
was (is) initiated by the new log-viewer, which closes/stopped the connection, so one have to push the start-button (top-right) again.
Cheer and thx, Peter
Donāt have a reverse proxy setup and itās not something I specifically setup in OH. Iāve installed the openHAB Cloud service, but I havenāt configured it yet. I have my email address tied to a cloud account that Iāve been using for my 2.5.x setup. I suspect I canāt use the same email address, so Iāll have to open another email account. Iād like to keep the 2.5.x setup running until I can port over what I can and recreate what I canāt port over. So at the moment, only accessing the UI on the local network.
Just an fyi. I am having the same issue with mqqt dimmers being stuck at 0. I have no reverse proxy setup and I am running local only. My solution was to migrate back to M5. This seems to have fixed the issue for me for now.
UPDATE: This fix was short lived. It seems to only fix the sliders when viewed from my MacOS computer using Safari, but not Chrome. When I use iOS on my iPad the sliders are stuck at 0 and the sliders show no tick marks in M5 or the GA. Dropping all the way back to M4 does seem to correct this issue on all devices (MacOS or iOS) and Chrome and Safari.
The way how I can solve it: I compare the DOM step by step and set the CSS settings where there are differences changing the design into what I donāt want.
As an example: var(āf7-list-item-title-font-size) was 14px in the desktop design and 17px in the iOS-design. So setting it manually for the list items make the design as it should.
I just would like to link the discussion below about the problem with profiles with this one, as I think itās an important regression. Weāve got this problem with any channel.
Many thanks for this new version!!!
I did the upgrade and the update.log file ends with
SUCCESS: openHAB updated from 4.2.0.M3 to 4.3.0
In the GUI I see that most things are online but nothing is working. To check was is happening I open visual studio and load I get errors
and in the output window
Usage of deprecated config => openhab.host <= detected.
openHAB vscode extension has been activated
[Error - 3:07:40 PM] Connection to server is erroring. Shutting down server.
Could not reload items for HoverProvider
What is wrong?
Check your log files after a restart. They will probably give some leads to the cause.
In section for breaking changes:
It would be great to have that release very soon to convert the affected things automatically and avoid re-creating all of them.
What is the timing of that āsubsequent releaseā?
Will that release come in a month or two?
I hope itās not going to be OH5ā¦
Thank you.
I repeated the process with the same result. See logfile below
I find this line
Failed to compile rule āae8a316039ā with status āUNINITIALIZEDā`
2024-12-21 16:09:17.007 [INFO ] [org.openhab.core.Activator ] - Starting openHAB 4.3.0 (Release Build)
2024-12-21 16:09:17.607 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Amsterdam'.
2024-12-21 16:09:17.620 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'nl'.
2024-12-21 16:09:17.621 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Measurement system set to 'SI'.
2024-12-21 16:09:35.346 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2024-12-21 16:09:36.553 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://192.168.100.50:8080/shelly/wsevent's Observer
2024-12-21 16:09:40.418 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'hue:bridge-api2:001788fffe49a466' to inbox.
2024-12-21 16:09:47.077 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 4c...b9, base URL = http://localhost:8080)
2024-12-21 16:09:47.845 [INFO ] [.influxdb.InfluxDBPersistenceService] - InfluxDB persistence service started.
2024-12-21 16:09:48.404 [INFO ] [internal.ModuleHandlerFactoryStarter] - WebPushNotificationModuleHandlerFactory started by ModuleHandlerFactoryStarter
2024-12-21 16:09:48.626 [INFO ] [hab.ui.habot.tile.internal.HABotTile] - Started HABot at /habot
2024-12-21 16:09:48.644 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2024-12-21 16:09:48.818 [WARN ] [.googletts.internal.GoogleTTSService] - Missing client id configuration to access Google Cloud TTS API.
2024-12-21 16:09:48.819 [WARN ] [.googletts.internal.GoogleTTSService] - Missing client secret configuration to access Google Cloud TTS API.
2024-12-21 16:09:52.888 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to compile rule āae8a316039' with status 'UNINITIALIZED'
2024-12-21 16:09:52.890 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2024-12-21 16:09:57.765 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.100.89' with clientid 553cd2e9-881a-4419-b28f-b26e7758be29
2024-12-21 16:10:11.613 [WARN ] [network.InMemoryMessageExchangeStore] - coap Exchange[L45] with manual token overrides existing Exchange[L44] with open request: KeyToken[192.168.100.13:5683-]
2024-12-21 16:11:06.498 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastToday_Sunrise
2024-12-21 16:11:06.500 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastToday_Sunset
2024-12-21 16:11:06.500 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_Current_Temperature
2024-12-21 16:11:06.501 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_Current_Iconid
2024-12-21 16:11:06.502 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_Current_Condition
2024-12-21 16:11:06.503 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_Current_Apparenttemperature
2024-12-21 16:11:06.504 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastToday_Humidity
2024-12-21 16:11:06.505 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastToday_Maxtemperature
2024-12-21 16:11:06.506 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastToday_Mintemperature
2024-12-21 16:11:06.507 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastToday_Windspeed
2024-12-21 16:11:06.507 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ObservationTime
2024-12-21 16:11:06.568 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastToday_Sunrise
2024-12-21 16:11:06.569 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastToday_Sunset
2024-12-21 16:11:06.570 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_Current_Temperature
2024-12-21 16:11:06.570 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_Current_Iconid
2024-12-21 16:11:06.571 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_Current_Condition
2024-12-21 16:11:06.571 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_Current_Apparenttemperature
2024-12-21 16:11:06.572 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastToday_Humidity
2024-12-21 16:11:06.574 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastToday_Maxtemperature
2024-12-21 16:11:06.578 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastToday_Mintemperature
2024-12-21 16:11:06.579 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastToday_Windspeed
2024-12-21 16:11:06.581 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ObservationTime
2024-12-21 16:11:06.581 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastTomorrow_Iconid
2024-12-21 16:11:06.582 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastTomorrow_Maxtemperature
2024-12-21 16:11:06.583 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastTomorrow_Mintemperature
2024-12-21 16:11:06.584 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastDay2_Iconid
2024-12-21 16:11:06.584 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastDay2_Maxtemperature
2024-12-21 16:11:06.585 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastDay2_Mintemperature
2024-12-21 16:11:06.586 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastDay3_Iconid
2024-12-21 16:11:06.586 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastDay3_Maxtemperature
2024-12-21 16:11:06.587 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastDay3_Mintemperature
2024-12-21 16:11:06.588 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastDay4_Iconid
2024-12-21 16:11:06.588 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastDay4_Maxtemperature
2024-12-21 16:11:06.589 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastDay4_Mintemperature
2024-12-21 16:11:06.590 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastDay5_Iconid
2024-12-21 16:11:06.591 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastDay5_Maxtemperature
2024-12-21 16:11:06.591 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: OneCallAPIweatherandforecast_ForecastDay5_Mintemperature
2024-12-21 16:11:13.407 [WARN ] [network.InMemoryMessageExchangeStore] - coap Exchange[L179] with manual token overrides existing Exchange[L46] with open request: KeyToken[192.168.100.31:5683-]
2024-12-21 16:11:13.499 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'shelly:shellyht:701605' to inbox.
2024-12-21 16:11:18.730 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Stopped HABPanel
2024-12-21 16:11:18.954 [WARN ] [ROOT ] - bundle org.openhab.ui.habot:4.3.0 (335) BundleComponentActivator is not active; not scheduling Async Deactivate: org.openhab.ui.habot.notification.internal.WebPushNotificationModuleHandlerFactory id: 2
2024-12-21 16:11:18.964 [INFO ] [hab.ui.habot.tile.internal.HABotTile] - Stopped HABot
2024-12-21 16:11:19.020 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2024-12-21 16:11:19.091 [INFO ] [.influxdb.InfluxDBPersistenceService] - InfluxDB persistence service stopped.
2024-12-21 16:11:19.105 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2024-12-21 16:11:19.111 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: io client disconnect
2024-12-21 16:11:19.111 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 4c...b9, base URL = http://localhost:8080)
