openHAB 5.1.0Mx: UPNP Issues
`2025-10-14 17:22:13.535 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘sonos:SYMFONISK:RINCON_38420B9457A601400’ changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING2025-10-14 17:22:13.572 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘icalendar:eventfilter:a5fe099ce2:805f02815d’ changed from UNINITIALIZED (NOT_YET_READY) to UNINITIALIZED (BRIDGE_UNINITIALIZED)2025-10-14 17:22:13.590 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘icalendar:calendar:a5fe099ce2’ changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING2025-10-14 17:22:13.608 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘sonos:SYMFONISK:RINCON_38420B9457A601400’ changed from INITIALIZING to ONLINE`
`2025-10-14 17:27:23.893 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'sonos:SYMFONISK:RINCON_38420B9457A601400' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): The Sonos player RINCON_38420B9457A601400 is not available in local network.`
`2025-10-14 17:53:31.795 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'sonos:SYMFONISK:RINCON_38420B9457A601400' changed from OFFLINE (COMMUNICATION_ERROR): The Sonos player RINCON_38420B9457A601400 is not available in local network. to OFFLINE (COMMUNICATION_ERROR)`
`2025-10-14 17:54:26.234 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘sonos:SYMFONISK:RINCON_38420B9457A601400’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): The UPnP device RINCON_38420B9457A601400 is not yet registered.`
Those are some older logs but - over there I’ve lost control after ~25 minutes from restart. Other addon, that have some mention of UPNP, is AndroidTV but from what I understood, UPNP discovery is only happening with Philips TVs. Other than that, there is nothing interesting in the logs
Discovery is one thing, taking an existing Thing offline is another. You’d need to enable DEBUG logging at least for the affected bindings, and perhaps for OH in general, to have much chance of capturing something of interest in the logs. Your log here indicates that it’s the Sonos binding that experiences the problem..? Do you have problems with your Philips TV at the same time as the problems with the Symfonisk appears?
After a quick peek in the Sonos binding, it seems that the above would be exactly what you’d see if there’s a network problem. That doesn’t mean this is the cause, but there’s no way to tell whether this is a problem with OH’s UPnP or with the network. Do these devices never reappear after having been absent without restarting OH? Do they always reappear after restarting OH?
If there are new problems in general with UPnP in 5.0, there was an update of JUPnP from 3.0.1 to 3.0.3 that affects these versions: 5.1.0.M1, 5.0.2, 5.0.1, 5.0.0, 5.0.0.RC1, 5.0.0.M4, 5.0.0.M3, 5.0.0.M2 and 5.0.0.M1.
I can’t tell if the changes made to JUPnP could cause new problems or not, but it’s a possible cause if the new problems started with these versions.
I enabled trace debug before but there is really no interesting information there (binding provides very little info)
I forgot to mention that I don’t have Philips TV - only Android TV - so that UPNP code shouldn’t affect it. I also don’t have that problem in 5.0 version of OH.
I have 2 times longer time, when I could power off and on without problems. If I see that device is not responsive after 5 minutes after power on, then only things that helps is restart of openhab app (not whole raspberry pi)
I’m sorry, I don’t quite understand what you’re saying. Maybe you could try to rephrase?
Enabling DEBUG logging for org.jupnp might shed some light.
I have Symfonisk speaker, which I power off when its not used. When I powered it on it was connecting to internet correctly within minute or two and I could control it via Sonos binding. Now, after upgrade to 5.1m1, after some time (can be few days, can be few minutes) it is stuck in “The UPnP device RINCON_38420B9457A601400 is not yet registered” state after powering on and only restart of Openhab helps.
I will try now DEBUG on org.jupnp and I will let you know if there is something valuable there.
Edit: Seems restarting (bundle:restart) jUPNP Core Library in karaf is enough to resume normal operation of Symofnisk
The clue is to figure out what has changed between 5.0 and 5.1M1 that could possibly impact this. I don’t have any idea, but many things are changed that I’m not aware of. It could be “anything”. I can’t see that there has been any relevant changes to the Sonos binding, and JUPnP is the same version as it was in 5.0. But, it could be something seemingly unrelated that makes JUPnP stop working. We either need some good idea of what could be causing it, or logs/thread dumps that reveal what’s going wrong.
Can someone please split the upnp discussion to a seperate thread? Very useful, it deserves its own thread.maybe @stefan.hoehn
@Nicholas_Waterton @reyhard If you have any more info/thread dumps or logs of relevance, please report it here.
@Nicholas_Waterton @reyhard Did these problems magically stop for you both?
Hi, after enabling logs, I had few days of it working correctly but I’m away since Friday so I’m not able to observe it. What I noticed too, that after restart of jupnp, control of Symfonisk was working but no info about tracks was displayed. There were some errors about it but I had power loss too, and lost logs from that period. Once I will be back I will try to look at it again but I believe it is still happening for me
I can confirm this. Upgraded from 5.02 to 5.1M2 and Sonos is not working anymore!
Then I thought maybe something did go wrong with update –> Back to 5.02 and Sonos working again.
Upgraded again to M2 but Sonos is still broken. The commands are working (Play, Stop, Volume) but no Status change . . . not for Control, not for Volume, not for Track.
I have no idea, but I have uploaded 3 DEBUG-Logs.
  • Restart Sonos Binding
  • Restart jUPnP Core
  • Restart jUPnP Transport
Maybe/Hopefully it helps
Sonos_Binding_Restart.log (138.1 KB)
jUPnP_Transport_Restart.log (52.7 KB)
jUPnP_Core_Restart.log (63.8 KB)
That’s not the same as what the others have reported. They have reported that it works for a while, then stops working. If you’re saying that it’s not working at all, it might be a different issue - maybe with the binding itself.
I looked through your logs, and they don’t reveal anything of interest that I can see. They basically just unsubscribe and then subscribe to the UPnP services - all the “noise” in between is just OSGi doing its thing and not of relevance.
If you want to find anything of interest, you should try to capture logs while whatever doesn’t work occurs. It sounds to me like you’re saying that events aren’t getting through (OH subscribes, but the idea is then that evens should be generated when anything subscribed to changes). If so, traces of this might be logged by jupnp or by the binding itself, depending on “how far” the events make it, if they are generated at all. If they aren’t generated at all, the error must be in the jupnp library.
What @michaeljoos described also happened to me once (maybe even more often but I haven’t observed it before) - see quote from my post. I’m still away so far I wasn’t able to test it further
Things have happened elsewhere, and we are not aware that events are not working for the Sonos binding in M2. We also know why, and are working on addressing it.
When it comes to the “general instability” of UPnP, we’re also following some potential causes. Do any of you that experience these issues happen to have the UPnPControl binding installed?
No, never installed UPnPControl binding.
See my comment above:
Or do you mean “we are aware”?
Yes, the events aren’t coming through from the device to OH, which means that nothing that happens on the device will be reflected in OH without a “refresh” of some kind.
Hello @michaeljoos,
The fix for this was introduce today.
It should come in a few nightly snapshot and in release M3.
Sorry for the inconvenience.
Laurent.
Is there a way to run it with 5.0.2-1? I seem to have all the sonos issues but the upnp stuff also uses up memory and constant cpu:
PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
26138 root      20   0 6522048   1.8g  26180 S  39.3  24.2     12,33 java
28624 root      20   0 6522048   1.8g  26180 S   3.3  24.2  27:50.31 upnp-main-6
11908 root      20   0 6522048   1.8g  26180 S   2.6  24.2   0:00.09 upnp-remote-194
10770 root      20   0 6522048   1.8g  26180 S   2.0  24.2   0:01.59 upnp-remote-194
28621 root      20   0 6522048   1.8g  26180 S   1.7  24.2  19:48.98 upnp-main-3
11831 root      20   0 6522048   1.8g  26180 S   1.7  24.2   0:00.16 upnp-remote-194
11840 root      20   0 6522048   1.8g  26180 S   1.7  24.2   0:00.18 upnp-remote-194
11842 root      20   0 6522048   1.8g  26180 S   1.7  24.2   0:00.20 upnp-remote-194
11906 root      20   0 6522048   1.8g  26180 S   1.7  24.2   0:00.05 upnp-remote-194
28620 root      20   0 6522048   1.8g  26180 S   1.3  24.2  21:05.38 upnp-main-2
9868 root      20   0 6522048   1.8g  26180 S   1.3  24.2   0:02.82 upnp-remote-194
10606 root      20   0 6522048   1.8g  26180 S   1.3  24.2   0:01.50 upnp-remote-194
11561 root      20   0 6522048   1.8g  26180 S   1.3  24.2   0:00.55 upnp-remote-194
11830 root      20   0 6522048   1.8g  26180 S   1.3  24.2   0:00.29 upnp-remote-194
11837 root      20   0 6522048   1.8g  26180 S   1.3  24.2   0:00.24 upnp-remote-194
11905 root      20   0 6522048   1.8g  26180 S   1.3  24.2   0:00.06 upnp-remote-194
11907 root      20   0 6522048   1.8g  26180 S   1.3  24.2   0:00.04 upnp-remote-194
10730 root      20   0 6522048   1.8g  26180 S   1.0  24.2   0:01.55 upnp-remote-194
11843 root      20   0 6522048   1.8g  26180 S   1.0  24.2   0:00.18 upnp-remote-194
11910 root      20   0 6522048   1.8g  26180 S   1.0  24.2   0:00.16 upnp-remote-194
28660 root      20   0 6522048   1.8g  26180 S   0.7  24.2   2:46.58 upnp-async-queu
11532 root      20   0 6522048   1.8g  26180 S   0.7  24.2   0:00.60 upnp-remote-194
11839 root      20   0 6522048   1.8g  26180 S   0.7  24.2   0:00.19 upnp-remote-194
11841 root      20   0 6522048   1.8g  26180 S   0.7  24.2   0:00.26 upnp-remote-194
7641 root      20   0 6522048   1.8g  26180 S   0.3  24.2   1:00.40 OH-binding-upnp
14541 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:59.54 OH-binding-upnp
28629 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:34.48 upnp-async-5771
28639 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:34.38 upnp-async-5772
28646 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:34.51 upnp-async-5773
28648 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:34.47 upnp-async-5773
28656 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:34.39 upnp-async-5774
28657 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:34.40 upnp-async-5774
9846 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:00.45 OH-thingManager
11551 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:00.58 upnp-remote-194
11567 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:00.51 upnp-remote-194
11659 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:00.48 upnp-remote-194
11708 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:00.29 upnp-remote-194
11838 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:00.18 upnp-remote-194
11909 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:00.01 upnp-remote-194
11912 root      20   0 6522048   1.8g  26180 S   0.3  24.2   0:00.07 upnp-remote-194
I don’t think the specific issue he referred to exists in 5.0.2-1. There are other problems around UPnP, another issue was addressed a few days ago and will be in 5.0.3 when that’s available:
I believe that there are more problems than that as well, but the above fix has the potential to be related to excessive memory consumption.
